Question about Linksys VOIP VONAGE PHONE ADPTR 2-PORT PAP2 Router
How to connect vonage to the internet - Linksys VOIP VONAGE PHONE ADPTR 2-PORT PAP2 Router
My Belkin F7D4302 router will not work with my vonage. I have a clearwire modem. If I hook modem into my my vonage first then to my router, my router does not connect to internet but my vonage does, If I...
It should work with the Vonage hooked into the WAN port of the modem, then the router plugged into the router. I had same issue with a Belkin router. Vonage Customer Service will help you at all hours: 1-VONAGE-HELP (1-866-243-4357)
24 hours a day, 7 days a week If you are calling to speak to our technical support team, please make sure you are near the Vonage phone adapter you are calling about and at the location where you intend to use your Vonage service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 20, 2011 | Belkin Computers & Internet
How should the D-link be setup to work with comcast and vonage? After I set vonage or internet do not work. I tried the comcast modem to d-link and d-link to vonage.
If you want to RECEIVE telephone-calls:
COMCAST ADSL/CABLE modem <---> VONAGE <---> wireless-router
Turn each piece off.
Turn on the COMCAST modem, and wait for its lamps to settle-down to a "steady" pattern.
Turn on the VONAGE router, and wait for its lamps to settle-down to a "steady" pattern.
Turn on the D-link router, and wait for its lamps to settle-down to a "steady" pattern.
Restart the computer that is connected to the D-link router,
and you should have Internet access.
Dec 01, 2009 | D-Link Vonage-enabled Wireless Router...
I have vonage telephone hooked up to my pc.how do i install my wrt54g router,what wires go where?
Who is your ISP. I think your modem is connected to the Vonage and Vonage is connected to the computer. If that is the connection then you can disconnect the computer from the vonage and connect the router there. From the vonage connect to the internet port of the router. then connect your computer to the router. Check if that works. If you are connecting the router to the modem, then you will need to set up the router as per the modem set up or type of ISP. Click Here for step by step solutions
Nov 17, 2009 | Linksys Wireless-G WRT54GS Router...
I have Vonage phone, and TimeWarner cable. My
Remove your router for the vonage equipment. Direct connect to modem. Does your internet ****? If yes its TW issue. If no its Vonage issue. Try it for a day
Hope this helps!
john
Oct 03, 2009 | Computers & Internet
Vonage told me to install my D-Link router between the vonage adapter and the computer and I don't know how or which wires go into which ports.
First of all: it would be good to know which vonage device you are using. This would help to be more specific.
But anyways:
  1. Connect a normal Ethernet cable form your DSL or Cable modem to the Internet (or WAN) port of your vonage router.
  2. Then connect another Ethernet cable from one of the LAN ports of the vonage device to the Internet (or WAN) port of you D-Link (The one that is separated from the 4 LAN ports.)
  3. Make sure that the D-Link is set to DHCP (Dynamic IP Address), so it can get it's IP address from the vonage router. (Look at page 14 of your manual. If you don't have one, you can get it here.)
  4. Connect your computer to one of the LAN ports on the D-Link.
If you have any more questions or this desciption is not clear to you, just come back here and leave a comment - I'm happy to help.
May 18, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
New computer (Vista) does not connect to internet. We have vonage VWR-VR D-link router and SBC Yahoo.
If you want this computer to connect wrielessly, go to Control Panel > Network and Sharing Center and click on Connect to Network. Select your router's signal from the list and click on Connect. It might require you to enter a network key. If you don't know your network key, call your ISP.
Apr 18, 2009 | D-Link Vonage-enabled Wireless Router...
Need to connect directv from hard line to vonage.
I had vonage with dish network and was able to buy a phonex system for wireless connection. Worked great.
Mar 22, 2009 | D-Link Vonage-enabled Wireless Router...
Vonage Phone Adapter and Motorola DSL Modem and Linksys NUltra
Your connection should be from DSL modem > internet port of Linksys router > Vonage phone adapter to port 1 of the router.
Nov 01, 2008 | Linksys WRT160N Wireless Router
Help!!!
Do you have the Vonage in front... or behind the router?
Behind: http://www.vonage.com/support.php?article=88
In front: http://www.vonage.com/support.php?article=1154
Also may need to log into your Router and setup port forwarding
http://www.vonage.com/support.php?article=1098&topic=20
Need more help.. let us know.
www.techvisitor.com
Jul 06, 2008 | Arris Wireless G Broadband Router (wr850g)
Linksys VOIP VONAGE PHONE ADPTR 2-PORT PAP2 Router Logo
18 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
