Margin shift left-right xerox wc pro55 - Office Equipment & Supplies
    Novelist:
  • 107 Answers
Paper registration needs to be adjusted by trained technician. Please call for service.
Posted on Nov 29, 2013
2 Suggested Answers
  • 95 Answers
SOURCE: My HP 2410 photosmart printer
probably a simple alignment problem. Go into your maintenance section and there is an option to align . Run this and it should realign your printing. Hope this helps!
Posted on May 09, 2011
I cannot release de left margin on my Xerox Memorywriter 6010. I press de Mar Rel Key and don't have success. Please, Help
Have you tried oiling it w/3-n-1 oil? Often the sticking problem is nothing more than it needs lubrication.
Feb 11, 2015 | Xerox 6010 Memorywriter Electric...
I cannot release the left margin on my Xerox Memorywriter 6015
When at the L. margin press the Mar Rel key not the L. mar key.
DickyO
Oct 24, 2012 | Xerox Office Equipment & Supplies
Occasionally, I still have to use a typewriter for some forms. I inherited a Xerox 6015 Memorywriter but I have no manual. Is there one online that I can download? Specifically, I'm trying to figure...
hit the carriage return key to put carriage at left margin. then hit your margin release key, then backspace key to put your carriage where you want it. then hit left margin key and that should set new left margin. good luck.
razors
Jun 06, 2011 | Office Equipment & Supplies
How do I eliminate the margin so it prints out to the edge? I have done a search for a full bleed. No reference.
Unfortunately, Xerox solid ink printers don't print full bleed. It is a shame because in theory, the machine is capable of it but it would require a firmware/driver programming/design update which Xerox are unlikely to do.
Jan 19, 2011 | Xerox Phaser 8860MFP Printer
HP Deskjet 5650 is printing off-center. The printing field is shifted to the right, so the right margin is non-existent and I lose a bit of the printing. How can I fix it?
I think the horizontal printing starting point can be adjusted by holding down buttons (??) when powering up. Right now my left margin is 3/8 inch too big -- photos have that much white space on left margin with borderless printing. I am trying to figure out the key combination.
Jul 27, 2010 | HP DeskJet 5650 InkJet Printer
How to use the margin release for Brother EM-530
Is Margin Release on it's own separate button on the EM-530? If so, then to move beyond a margin:
  • Use Return or Tab to go to the left or right existing margin.
  • Touch Margin Release.
  • Use the Backspace or Space bar to go beyond the margin in question.
  • If you want to set a new margin, then go to the location you want to have it and touch the Left margin or Right Margin button.
Some models may require the CODE key to access one or more of these functions. If the function name is not printed on the top of the key, but on its front or on the surrounding plastic above the button, press and hold the CODE key while touching that button (just as you hold the Shift key to type capitals). The CODE key might possibly have a different name; chances are it's color will match the functions it works with.
Jan 05, 2010 | Brother EM-530 Typewriter
I have xerox pro55 and shows paper jam, to remove paper from 3 and 4 but there is no paper present, can it be a bad sensor and where is it
Perhaps you could start here:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=408,E=0000000001794573056,K=108,Sxi=19,Case=obj%282623%29
Are you sure there is no paper jammed internally?
Nov 27, 2009 | Office Equipment & Supplies
Paper Jams and Margin Incorrect
Check the humidity of your paper, type and weight. Nothing more than 32# will run through the tray, any heavier should go through the bypass to prevent jamming. Margin follow the internal tutorial for moving your margins. Xerox machines do skew 3 degrees left for some reason or the rollars that feed from tray 2 need to be changed.
Peter
Apr 01, 2008 | Xerox Phaser 7750DN Laser Printer
k24674
