Question about Panasonic Televison & Video
Panasonic plasma tv blinking 4 times - Panasonic Televison & Video
djchillsnyc
  • 152 Answers
SOURCE: Panasonic th-50-px50u power indicator blink 6 times - no pic
hello, 7 blinks means you have a fualty ss board its bad or needs service
SS Board (SS Data Energy recovery and data driver)
thats the fualt for 7 blinks
Posted on Dec 14, 2008
  • 1170 Answers
SOURCE: panasonic plasma TH-50PZ80U shuts off and blinks 4 times
Heat is the enemy of electronics, and these sets operate hot. You might wish to unplug the TV for an hour or more. If this power reset does not allow the TV to turn on component failure is indicated. These sets are assembled using the wave soldering process they are known for having cold solder connections. The safety circuitry shuts the TV set down when it detects a problem. This model of TV has over 3,000 parts which include millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Integrated circuits and transistors can go bad. This can cause other components to become defective, which can have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment. I wish I could tell you there was a quick fix or button to push that would fix the TV but that is not the case or the solution needed to get the TV operating correctly.
The 4 blinks signifies problems with the Power SOS P Board. If replacing that dosn't solve the problem, then you'll need the help of a technican. I cannot conclude into that, because the error codes do not tell exactly what will be needed to repair the TV. This requires testing.
I hope that solves your Problem, If so kindly accept it.
Thank You, Arjun.
Posted on Apr 11, 2009
ZJLimited
  • 17970 Answers
SOURCE: Panasonic TC-P42G10 Plasma TV the red light is
From other forums about TV faults; You may want to check out another set of posts at http://community.crutchfield.com/forums/t/5022.aspx?PageIndex=1
I did see this though which was nice - although I am not sure how useful it would be to someone not electronically proficient.
BLINKS PROBLEM MALFUNCTIONING PART
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards (SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards (SC floating voltage area)
8 blinks Driver SOS 3 SS Board (SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board with IC8001 (Pesks Lite 2)
That the four blinking lightsindicates a power supply failure, and need repair from techinical service if this have warranty.
Good luck.
Posted on Dec 03, 2009
eagle338
  • 4889 Answers
SOURCE: All of a sudden my
Your tv has a faulty power supply board also called SOS-P board. Take of the back panel and look for any obvious defects. Start by checking the capacitors for cracked/swollen/leaky capacitors. If the tops of the capacitors are not flat then it indicates that the components are faulty. If you find any you should replace them with exactly the same values. Ex: 40v,1000mF
If you don't find any a component level repair might still be possible so if you are skilled in electronics and know how to use a meter you can start by downloading a service manual. Unfortunately I don't have one for this model but you can download it from the link below
http://www.service-docs.com/store/catalogue.php?cat=278&exp=&resultpage=62&shop=1
Once you have it post back and I will help you troubleshoot this issue.
Sai.
Posted on Jan 22, 2010
toolkits
  • 1099 Answers
SOURCE: Panasonic TH-42PZ77U HD Plasma tv has 10 blinking lights
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Jun 02, 2010
Tv Panasonic viera blinks 4 times red it does not start
If you go here it explains the SOS codes for a plasma TV
https://www.scribd.com/document/15964494/Plasma-Symptoms-and-Cures
Oct 22, 2017 | Panasonic Televison & Video
Panasonic 42 inch television
HEY !!
ITS A CIRCUIT BOARD PROBLEM ... IC MAY HAVE BLOWN OFF ...
Jan 01, 2008 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
No picture. TV blinks 8 times
I have come across 6 blinks; 7 blink and even 10 blinks.
the video below may throw some light. Not sure if the blink codes are universal across models. Panasonic plasma tv 7 red blinks of *****
Apr 02, 2016 | Panasonic Viera TC-P65S1 65 in. HDTV...
My Panasonic plasma Tv does not have sound. How do I fixed that
Sound no picture on 50 inch samsung plasma ps51d450a2m - HDTV ...
www.tomsguide.com/.../58009-4-sound-picture-inch-samsung-plasma-ps...
Jul 1, 2015 - 4 posts - ‎3 authors
There is sound and no picture on plasma tv, remote works at times but ... My pioneer elilte has this mode, and it is pretty easy to completely turn ... When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
Problems with blu ray player and plasma tv - HDTV ...
Nov 16, 2014
I do not have audio out on my tv how do i connect so ...
Dec 18, 2013
All channels on my tv have sound except channel 3 ...
Jun 29, 2010
More results from www.tomsguide.com
No picture or sound in my Panasonic TH-P42UT30A plasma ...
Dec 07, 2015 | Panasonic Viera Th-50px60u 50" Plasma...
Plasma went out... red light blinking 4 times...
It sounds that the Y-Sustain or its driver sections has the fault. Visit this site for more details. Faults with Panasonic Plasma TVs are described in detail there. Blinking indications and faulty boards will be almost same to most of the Plasma TVs. Check this link, and select the site. Pull up older posts there. Sometimes, ads related to each post might help you to get details of availability of spare board.
Jul 20, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
I purchased a Panasonic TC-P50s30 50" Plasma TV
You did a good thing; really!! Keep that TV aside you always.
Jul 11, 2017 | Panasonic 50 in. Plasma TV
Televison & Video Logo
14 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
