could be a problem with the switch itself or the connector on the motherboard ,you might have to take it to an authorised Dell center to get a quote.Is there current to the laptop?
Try with or without the battery.
You can't post conmments that contain an email address.
The power supply isn't getting a good power signal from the motherboard. Sometimes unplugging the 20 pin connector and plugging it back in a few times will clean a faulty connection. Otherwise your power supply is at fault.
Push the SELECT and RESET buttons together and turn the key ON,when the digits start flashing on the display push the SELECT button to choose kilometres or miles .
1. Refresh the Spooler.
To refresh the spooler, Go to Start, and in start search box or Run, type services.msc and press enter.
Now Remove the USB cable from the back of the printer.
Now on Services window, search for Print Spooler.
once found,
Make a right click on it and select Stop
Then Again make a right click on it and select start.
Perform the steps Stop---start 3 times.
Once done, close the services window.
Then steps to be done on the printer.
Press the Power button for 30 seconds while the Power cable remains out.
Then insert the Power cable. And power ON the printer, if it does not Turn ON automatically.
If the issue still persists, please post back.
Remove the battery the memory the ac cord .Press and hold the power button for twenty seconds.If you cant get to the memory don't worry about it. THE OBJECT OF THIS EXERCISE IS TO TRY TO RESET THE COMPUTER.
GOOD LUCK
Hi, While the pc is off turn it on by pressing the power button, immediately
after you press the power button start tapping the F10 button and keep
tapping until the recovery menu appears.
DID YOU CHECK THE CHARGER? CHECK FIRST USE TESTER TO CHECK IT.. THEN IF THE SAME PROBLEM CHECK THE POWER BUTTON IF NOT THE DC CONNECTOR YOU NEED TO OPEN THE UNIT IF UNDER WARRANTY BRING TO THE WARRANTY DONT OPEN IT....
Try the following first power cycle the netbook (take off your battery and unplug the unit then hit the power button a couple of times b4 putting power to the netbook). After that power up the machine and try to connect.Also go into the power settings and set mt wireless card to off on the "power save mode".The "power safe mode" options are explained further below.Hope this works for you
Turn the network adapter power save mode to off,here are the steps: - click "Start" - click "Control Panel" - click "Classic View" - doubleclick "System" - select "Hardware" tab - click "Device Manager" button - click "+" to left of "network adapters" - doubleclick "Atheros AR5007EG ...." - click "Advanced" tab - select "Power Save Mode" - select "off" - select "OK"
Place the key in the ignition switched off. Press and HOLD both the select and reset buttons before turning the key to the on position. Now let go of both buttons and the on screen digits should start flashing. Now press select to toggle between kilometres and miles per hour.
urgent travelling overseas shortly
is it working?
