Question about Kingston (SDCZ2-512-A10-KT) (SDCZ2512A10KT) .512 GB Hard Drive
Removing write protection on usb - Kingston (SDCZ2-512-A10-KT) (SDCZ2512A10KT) .512 GB Hard Drive
Cannot format usb says write protected but there is no write protection for the usb
Reinhard, Check the attached links,instruction and guides on removing USB write protection, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
2 ways to fix write protected USB drive or SD card
How To Fix Write Protection Errors On USB Stick
How To Disable Write Protection from USB Key
How to remove write protection on generic usb disk drive
Jun 16, 2016 | Electronics - Others
How to remove write protected on my 2.0 flash drive 64GB usb. I don't have a button on the side to disable it. Please help me.
Visit following link.. it will guide you how to remove write protection from USB.
http://www.pcadvisor.co.uk/how-to/storage/how-erase-write-protected-usb-drive-or-sd-card-summary-3633096/
May 14, 2016 | Electronics - Others
How to tke write protection off a pny attahe? - Hard Drives ...
www.tomshardware.com > Forum > Storage
Tom's Hardware Guide
Sep 22, 2012 - 6 posts - ‎3 authors
Hello, I have a 64 gig attache 2.0 flashdrive. ... I could not see a write protect switch in the PNY product guide, but just ... I've been trying to do this for nearly a year and today found the tool to format my 64GB PNY flash drive. ... the Link you provided and downloaded the recovery tool for my PNY USB 64 Gb ... USB Flash Drive is write protected and shows up as ...
Nov 11, 2012
Remove write protect flash memory USB - Flash Media ...
Nov 30, 2009
More results from www.tomshardware.com
how do i take off my write protection off
Jan 16, 2016 | PNY Attache 64GB USB Flash Drive
Write protection
Write protection means you can view the information stored in it but you can't write and transfer the information to it.
For removing the write protection follow the below mentioned steps:
1. Right click on the USB stick
2. Go to properties and uncheck the read only or write only protection option.
May 12, 2013 | EDGE Tech Corp Edge Diskgo Mini - Usb...
How to remove the write protection in a usb
1.Turn on your computer and plug in the drive after your operating system has loaded.
2.Open "My Computer" and search the list of drives until you find your USB drive letter.
3.Right-click on the name and click "Properties." Once the options have loaded, go through the tabs until you see the option to remove write protection. If this does not work, go to the next step.
4.Visit the company website for your USB drive. Go to the help or support section and search for "write protection."
5.Click on the download section and search for "write protection software remover." Download the program and install it on your computer.
6.Open the software program. Go to "Option" and click "Remove Write Protection" to unlock your USB drive.
>>>>"M.J Trusedell"
Aug 16, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Gmail.comhow to remove file protected from pen drive data traveler and also please send any link to down load the software
Kingston Data Traveler2.0 USB Device 4gb write protected remove cannot remove write protected file from usb plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz send me this solution
email addres- Ijazdoger@yahoo.com
Feb 26, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to remove usb write protection
  • 2
  • 3
  • 4
  • 5
  • 6
  • Read more: How to Remove Write Protection From a USB Drive ' eHow.com http://www.ehow.com/how_4924168_remove-write-protection-usb-drive.html#ixzz1BY4ve3fh
    Jan 20, 2011 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
    My verbatim USB 2 GB is write protected. I am not able to remove write protection. Please suggest to solve the problem.
    It has password protection. Open My Computer on your PC, insert the USB drive, open the password file, enter your password, then select the option to remove password protection from the USB drive. If this does not work, contact Verbatim for a solution, these USB flash drives have lifetime warranties.
    Nov 12, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
    Write protected 4 GB GENX USB
    I ve a 4 GB genx USB that.It become write protected. How do I remove the write protect so i can reformat it? The device doe't have a write protection switch. What's wrong with it?
    Jan 16, 2010 | Electronics - Others
    How to remove write protect on my usb flash drive
    On USB stick, there is a "Lock/Unlock" slide bar on the opposite end of USB port. It uses the symbols of a "lock" and an "open hasp lock" to show that the device is "locked" (write-protected) or "unlocked" or not write-protected. remove the lock
    Oct 08, 2008 | Computers & Internet
    Kingston (SDCZ2-512-A10-KT) (SDCZ2512A10KT) .512 GB Hard Drive Logo
    37 people viewed this question
    Top Kingston Computers & Internet Experts
    Cleverer2
    Computer Links
    Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
