Question about LG DLG5988 Gas Dryer
LG DLG 5988 Gas Dryer Does not heat and does not dry
My 2 year-old LG 5988 does not heat up and does not dry my clothes. The drum spins, but no heat is generated. The lint screen is cleaned after every use and there is no lint visible in any of the readily visible areas. When I put my hand in front of the vent on the outside of the house, air appears to be flowing unobstructed. Also, the cooling light goes on as soon as the dryer starts.
  • 10 more comments
  • hopkid Nov 04, 2007
    Similar, if not the same problem. There is a small amount of heat generated; the burner still ignites and runs. The 'cooling' light is ALWAYS on. It seems that drying time has doubled in the past month. The dryer is practically air drying to clothes. The exhaust is clear and blowing fine. Any ideas?
  • Anonymous Dec 03, 2007
    I have the same problem.
    As soon as the unit is started the cooling light comes up and no heat is made to dry the clothes.
  • Beach94Ag Dec 07, 2007
    Same problem here.
  • oxmelxo Dec 25, 2007
    its heating but cooling sensor is always blicking.
  • Anonymous Jan 04, 2008
    EXACT same problem. Anyone have a solution? I bet the computer chip is fried....takes a technician to fix it.
  • Anonymous Feb 08, 2008
    Same problem. For the second time in two years. Having a difficult time finding a reliable repair person. Will tell everyone we know not to purchase an LG brand appliance!
  • maria134 Feb 24, 2008
    I have the same exact problem with mine.  Everything appears to work normal (the drum turns, the indicators on the face of the dryer are lit which tells me my clothes are drying).  Once I hear the beep that tells me the clothes should be dry and the dryer stops, I check the clothes and they are cold and moist.  Please help.  This dryer is not even 3 years old.  The vents have been cleaned; we checked the exhaust system as the manual indicates but not go.  It would be great to get a solution online.  I am almost certain that it's an easy fix.  Hope I'm right.
  • alanshih27 Aug 12, 2008
    Sorry I don't have a solution...I'm LOOKING for one!  I have the EXACT same issue as everyone here.  Soooooo frustrated over a 1000 dollar dryer!
    LG Sucks.
  • Anonymous Sep 26, 2008
    Same problem. Dryer turns on but only ignites occasionally. Have had two motors and two valves replaced. Still doesn't work. Tech told us it's a flaw in the design.
  • r0berts Oct 13, 2008
    This just started happening to me. Clothes wet and damp even after three times through cycles. No heat at all. Does anyone know what the problem is - I hate to call a repairman if I don't know what I'm looking for.
  • Anonymous Jan 19, 2009
    My LG DLG5988W sensor stays on all the time.. Clothes take forever to dry.. if they dry at all.. it seems there are many with the same problem with no answer from LG as to how to get it fixed..NOT A HAPPY CAMPER!!
  • cookbookgirl Feb 09, 2009
    Why don't we all bombard LG with complaint calls? I am sick and tired of expensive appliances needing repairs after the 1 year warranty runs out. We need to stand up to the companies that don't produce quality products. If enough of us do it, they will notice.
Same problem after 1 year of use. In the past couple of months, the Sensor and Cooling mode light stay on and unit does not dry.
Posted on Mar 09, 2008
Same exact problem for a year and a half now....soooooo frustrated with a 1000 dollar dryer.  NO LG
Posted on Aug 12, 2008
Tromm LG gas dryer 5988 gas wont turn on says DRYING but it's not Everything else works
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 06, 2010 | LG DLG5988 Gas Dryer
LG DLG 2526W dryer running but no heat
heatman101
May 22, 2010 | LG D2526 Gas Dryer
Not drying clothes no heat
The problem is the ignitor...
Check out this tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Apr 13, 2010 | LG DLGX7188 Gas Dryer
I have LG DLE2101W just installed yesterday. It
I found your manual and learned yours is a GAS dryer... the FIRST check is to be SURE the gas valve to your dryer is OPEN.
There is a Troubleshooting section, but NOTHING about no heat?
Know that LOW gas pressure CAN be a issue too!
I did find this:
"If the dryer no longer heats then the heating element may have failed, but it is not the most common cause. The most common cause for a dryer to stop heating is a blown thermal fuse."
The SECOND Link will be VERY helpful...
More help?
Cause 1 Thermal Fuse
Cause 2 Gas Valve Solenoid
Cause 3 Igniter
LG DLE2101W Support Manuals Warranty More LG
LG Dryer Not Heating
Thermostat
IGNITER
Dec 24, 2017 | LG Dryers
My Maytag Atlantis MDG6400AWW will not heat up. The drum spins but the clothes don't dry!
my dryer timer is not turning off and it does not get hot,I check glow coil.its working but it does not fire up.I smell gas some time
Apr 16, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
It takes at least 2 60 minute cycles to dry clothes. Not even 2 years old yet. Not a new problem has always been this way. What is the deal.
Check the blower fan which is mounted underneath the drum on my DLE2514W front loading LG dryer. I experienced poor drying along with a loud thump at the start of each cycle. At first I thought it was a bad roller but later found that the blower fan had separated from its bracket so it was not turning with each turn of the moter but rather spinning freely.
Apr 14, 2009 | LG DLE3777 Electric Dryer
LG DLG7188WM runs but no heat
I believe that it does. All of these parts should be functioning properly in order to dry the clothes well.
Jan 14, 2009 | Maytag Neptune MDG5500AW Gas Dryer
LG DLG 2524W gas dryer
call svc tech under warrenty, also sensor rellies on clothes touching two shiny strips to sense the dryness of the clothes ussaly in front or rear of drier drum or rather back or front wall inside wet clothes short the bars and stalls timer when they are dry does not short bars so sensor knows dryness by resistance of short tilt drier front or back where ever bars are to make shure clothes main tain contact lots of time this cures the promblem
Nov 18, 2007 | LG DLE2532W Electric Dryer
LG DLG5988 Gas Dryer Logo
3,121 people viewed this question
Top LG Dryers Experts
jimorris77
Craig Butler
Craig Butler
Marvin
Marvin
Are you a LG Dryer Expert? Answer questions, earn points and help others
