Question about Acer Aspire Z5700 PC Desktop
No power nothing works - dead
Lg flatron L192ws DEAD CAN IT BE FIXED. shows no lights - nothing. Changed power leads but still dead.
A dead monitor indicates a power supply problem. If unit has an external power supply and you have have substituted it with another known working supply and the unit still does not work, then the problem lies within the monitor's circuits. Yes, it can be repaired, but it might just be cheaper to replace it due to high labor costs.
Jan 27, 2014 | Computers & Internet
Dryer is dead .does nothing
Try turning off the power at the main house breaker, then turn it back on. If nothing happens you probably blew a fuse in the control panel.
Jan 20, 2013 | Roper Dryers
My haier htr20 tv wont power up..tv is completely dead.
Check the main power regulator section circuit.
May 20, 2012 | Haier HTR20 20" TV
My hard drive wont read it worked before dont know why
A disk-drive has several major components:
* the electronics circuit-board
* the power/data external connectors
* the motor that spins the disk-drive
* the read/write mechanism that moves above the recording surface
* the recording surfaces
No power means no "spin", and nothing happens.
Dead motor means no "spin", and nothing happens.
Dead electronics on the circuit-board means that nothing happens.
Damaged read/write mechanism.
Damaged recording surfaces.
Feb 26, 2011 | Hitachi Computers & Internet
My car seems to have a dead battery, nothing lights up. However the battery is not dead, I have it tested twice and it works. Also I can jump start the car to work fine. So I have a dead car, the power...
yes. check you battery terminals and connectors clean them then tighten them bk up snugg prob a bad connection due to corrosion or loose connectors.
Jan 29, 2011 | Ford Focus Cars & Trucks
Worked fine yesterday - will not turn on today - kitchen
When you say the machine is dead do you mean you are getting no LED lights at all or do you mean it is not booting up? No power and no post are two different things. With no power you get absolutely nothing at all. With no post you may have some LED lights but nothing comes up on the screen. You said power and power supply tested ok. How are you testing it? I need more info please.
Feb 07, 2010 | IBM ThinkPad T40 2373 Notebook
Laptop Dead, Wont power up
its power button doe not work please change it as soon as possible
Apr 14, 2009 | Acer Extensa 5420-5687 Notebook
Emerson MW 8115SS
Remove screws, remove cover, replace 20A 125v fuse. Should work.
Nov 16, 2007 | Food Mixers
Dead laptop
Check the ac adapter is the proper one for that laptop. Check the power jack is not damaged or loose. let laptop site without battery or power for a few hours. remove battery and retry power. try another ac adapter if that doesn't work, you may have a reset button but not likely to solve the problem. sounds like motherboard is damaged, or something blew.
Aug 27, 2007 | Compaq Presario M2000 Notebook
Acer Aspire Z5700 PC Desktop Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
