Question about Philips FW930R Shelf System
PHILIPS FW930R 3701
My CD player is working. However, after two or three minutes it stops. I was told that the lens is going bad. Is this true?
  • Anonymous Apr 14, 2009
    my 3 disc changer skips badly
  • 93 Answers
Maybe there is some dirt & dust on the lens. Try to clean it.
Posted on Oct 11, 2007
My music system will mot play CDs
Hi, Although CDs are still the preferred method of audio distribution, CD players are quickly being phased out in lieu of MP3 players. If your old CD player stops working, it might be a little panic-inducing, but fear not. If the CD player turns on but does not play CDs, then the problem is not with the power cord or the circuity (which are generally more expensive to repair rather than fix) but with the lens. There are several troubleshooting steps that you can take to fix a CD player when it won't play.
Instructions
Things You'll Need:
* Glass/lens cleaner
* CD cleaning disk
* Dry duster
Remove excess dust from the CD player. Dust is the number one enemy of electronics, and it can corrode even the most resilient device. Make sure to dust in between buttons, knobs, power cord(s) and audio-out ports. Note: use a dry duster, as moisture will harm your CD player further.
Use a disk-based lens cleaner to remove ground in dust or dirt from the CD player's lens. These lens cleaners look like a regular CDs, but have specially-made bushes on the reverse side that gently remove excess dirt from the CD-reading lens. Simply put the CD in your player, and press the "Play" button to clean the lens. Do not run the cleaner more than once, as excess brushing can cause scratches on the lens.
Polish the lens. Use a glass or eyeglass cleaning solution and a lint-free cloth to gently polish the reading lens. Clean it by using a low amount of pressure and softly polishing the lens and its surrounding area using soft, circular motions. Do this for about a minute or two and then allow the player to sit for a few minutes before trying to play a CD.
Tips & Warnings
If the CD player does not turn on or off, or the power indicator flashes infrequently, the problem is with the power cord or the circuit board, in which case the CD player will not be able to be repaired.
If the CD player still does not work after these steps, the lens has probably been scratched, and the CD player will need to be replaced.
Mar 01, 2011 | Philips Audio Players & Recorders
I have tesco cd-rw and will not work on the Philips CDR880 CD Player what cd s doo i have too get
try checking with the Philips web site BUT usually Maxwell or other good named brands that cost more DO work.
A friend has a theory that all CD-RW and CD-r are made the same and when a batch is quality controlled to good quality go to the quality firms as they will be more reliable and the poor ones go to the stack it high sell it cheap firms.
This may be true because I only get problems with the "cheap" discs - which I don't buy any more!
GOOD LUCK
Feb 26, 2011 | Philips CDR880 CD Player
THE CD PLAYER STOPS AFTER ABOUT 2O MINS any idea why
Check the laser lens inside the unit - inspect it for dirt or dust. Clean with "Q" tip and alcohol. If the problem persists, the laser might be going out. Check the lens to verify it moves up and down. Check the lens to observe a red beam. If these processes do not occur - the laser is bad.
Nov 01, 2010 | Philips HTS335W Home Cinema System 5.1...
I have a Philips model #FWM575/37 Cd/Tape/Radio combination player. It is only 3 years old and the CD portion is not working. CD starts playing, then stops and can't get any CD to work.
You may just get away with cleaning the lens of the CD player to restore it to normal, use one of the brand name makes of CD Lens Cleaners.
Jan 06, 2010 | Philips FWM575 Shelf System
MY cd player is not playing cd
If you can gain access to the lens, try cleaning the lens using a cotton swab and alcohol. If that fails to resolve the problem, the optics are starting to fail. You should be able to find replacement optics for around $40 or so.
Dan
Aug 11, 2009 | Philips Audio Players & Recorders
Won't read any disc
Could be dirty lens. I'd almost bet bad run of CD-r's though. Does the drive recognize finished cd's? If so it the CDr's.
Mar 25, 2008 | Lite On SHW-160P6S (SHM160P6S04) DVD RW...
Shelf stereo turns off by itself and stops working all together.
how loud u cranking it? cause i've tested my stereo to its max...and it suddenly dies...reason: its juss like a small scale car stereo system...the built in AMP cant handle the out-put..
Feb 04, 2008 | Philips FW930R Shelf System
Philips CD Recorder
Have you tried cleaning the lazer lens with a cleaning disk?
May 19, 2007 | Teac CD-RW880 CD Player / Recorder
Philips FW930R Shelf System Logo
56 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
