Question about Dryers
Whirlpool Calypso Dryer Electrical Problem
After the dryer has completed a drying cycle, it will not turn back on (after the door has been opened and closed). If the dryer is unplugged for about 15 minutes, it will work again after it is plugged in. Also, the display sometimes comes on by itself and reads "36" (casual cycle). None of the panel buttons fail the diagnostic. We have replaced the control board to no avail. The thermister and moisture sensor both test fine. Even when the panel appears dead, there is 120v at the control board, and yet pushing on any of the buttons will not result in any response. We have checked the door switch, centrifugal switch, belt switch and all high limit heater switches.
  • 1 more comment
  • mblake214 Feb 21, 2009
    how much is it to replace the control panel?
  • Anonymous May 09, 2009
    I also have one of the first calypso dryers. Got rid of the washer after about 2 years, didn't get the clothes clean. the dryer has been fine until 2 days ago. I hit the touch-up button and it ran for about 17 minutes and stopped for no reason. Now it won't do anything. The display lights up but it will not run.
    SAG1972
  • Anonymous Mar 13, 2014
    The front control panel is not responding when I push buttons. The dryer stuck on if I close door it runs - the only way to stop it is open the door. None of the buttons will respond when pushed in
Problem resolved. Although the membrane control panel passed the diagnostic test, it was defective. Probably a low voltage conductor went to ground, allowing the buttons to operate but throwing the control board into error mode.
Posted on Nov 11, 2007
SOURCE:
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Whirlpool gas dryer doesn't dry
Make sure vent hose in back of dryer is not blocked or stopped up.
Mar 16, 2014 | Whirlpool WGD94HEXR Duet Steam Dryer gas
My Whirlpool gas dryer is not working
Instructions
Check that the dryer door is closing completely. Remove anything that blocks the dryer door from closing.
Ensure the "Start" button is pressed firmly to start the dryer cycle, the dryer is not overloaded and the clothing is not balled up. Any of these things can prevent the dryer from operating and/or drying the clothes.
Use a level to confirm your Whirlpool dryer is sitting flatly and evenly on the ground. Adjust the dryer as necessary for it to be level as the dryer will vibrate and make unnecessary noise when sitting unevenly.
Examine the inside of the Whirlpool dryer drum and in the space around the drum for loose change, pens, hair ties and other items that could have been left in the pockets of clothing. These items will cause noise and potentially cause the dryer to become inoperable.
5
Examine the Whirlpool dryer's lint trap for excess lint. Remove any lint from the trap and place it back into position. Always clean the lint trap between dryer cycles. Inspect the area around the dryer and in the ventilation and exhaust systems. Remove any built up lint and clean the area thoroughly. Built up lint is a fire hazard and can cause operating issues.
6
Check the gas shutoff valve if your Whirlpool dryer is gas powered. Ensure the shutoff valve is turned all the way to the "On" position.
7Check the electric plug and ensure it fits securely in the outlet.
8
inspect both the fuse box and circuit breaker for any electrical problems. Replace any blown fuses, if necessary, and reset the circuit breaker if it has been tripp
Jan 09, 2013 | Whirlpool Dryers
Whirlpool Tumble dryer low heat, taking three cycles to dry one load
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 21, 2012 | Whirlpool Dryers
I have a Whirlpool Calypso Electric Dryer with digital touchscreen selections. However the only selection that will remain lit and useable when pressed is the delicate cycle. The time for that cycle can...
Robyn, We would like to inquire further about your post with you. Please respond back to this email address [email protected] with your name, user id (Robyn), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 17, 2017 | Whirlpool Dryers
Whirlpool Gold Calypso Sensing not drying. Dryer worked for three loads today and now when i close the door I press normal dry and then the start button but it won't start. To the right the...
underneath the lint trap is the sensor, it is dirty. You will need to clean it, just be gently as if not you may break it, when you look down the lint trap it has two screws. Here is a web site that will help with the dissemblance of the dryer :
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
under the heating element it says open up a dryer just click on that Good Luck Tim
Feb 19, 2011 | Whirlpool GEQ9800P Electric Dryer
Whirlpool Calypso dryer GEW9868KL2
It is one or two things. Motor start switch or the motor itself.
Aug 11, 2009 | Whirlpool GEW9868K Electric Dryer
Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Jan 24, 2008 | Whirlpool LER3624JQ Electric Dryer
Dryers Logo
897 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
