Question about Durabrand DWT1905 TV
PLAYSTATION HOOK-UP How can I connect a playstation console to this TV? The TV only has 1 audio and 1 video jack but the game console has 3 male ends. The remote has a game button, but when I turn it on nothing comes out of the TV and nothing shows on the screen. Help.
I have a ps2 also so just hook up the yellow and white plugs. It will work if you connect those 2 right but you must have a remote to turn it to game mode or no lucc. This is where i'm at right now trying to find my remote..hahaha
Posted on Dec 29, 2007
No audio out of a/v HD reciever. HDMI cable going from PS3 to reciever. HDMI out to tv. Tv audio only. No surround
Not all recievers can sample audio from the hdmi jack, some of the earlier generation simply allowed the sound and video to pass thru,check the owners manual you still migty have to hook up an optical cable from the ps3 to the reciever.
Feb 22, 2011 | Sony Playstation 3 (PS3) Console
How do i set up my old playstation 1???
Connect the cables to the ports on the back of the PlayStation console marked "audio out" and "video out." Make sure to match the same-coloucoloured plugs on the cables and the ports - yellow to yellow, red to red, white to white.
Connect the other ends of the audio/video cables to the ports on the back of the television or VCR marked "audio/video input.
Connect the AC power cord to the PlayStation game console and plug it into a wall socket for power.
Turn on the television, VCR (if included in the connection) and PlayStation console.
Press a button on the remote control to access the audio/video inputs for your television or VCR. The button will be labeled "video," "aux," "auxiliary," "tuner" or "line TV/video." You may need to set your television or VCR to channel 00, 90, 91 or 92. If the remote control does not have the buttons described here, check the product's instruction manual.
Regards.
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
How do you set up a ps3?
I would suggest you follow these procedures, hook up your PlayStation 3 to a television. You must decide whether your TV supports high definitions (HD) resolution or not. For HD resolution, you must use a HDMI cable or a component video cable. These cables also support standard definition (SD) resolution. If you only have an SD television, you can use an S-video cable or an AV cable. These two can't support HD resolution.
Connect the PlayStation 3 to any audio equipment such as a A/V receiver or home entertainment system. Connect using a digital audio cable or, alternatively, run an HDMI cable to your A/V receiver then another HDMI cable to the television set.
Plug in the Ethernet cable, then connect the other end to a 10Base T jack from your home network. This connects you to the Internet and the world of online gaming.
Attach the AC power cord to the PlayStation 3, and then plug it into a surge protected wall outlet. Don't plug in the power cord until all other connections have been made as a chance of shock exists.
Perform the initial set up of the system. Turn on the power of the TV and game console, and follow the on-screen prompts. The pre-installed software guides you through the set up process.
Take care.
Jul 18, 2010 | Sony Playstation 3 (PS3) Console
Trying to hook up a PS3 to a regular older TV (Zeneth). What do we need to make this work
hello just the black lead that has 3 coloured jack plugs on the end and scart block. on the tv at the back there might be 3 scart sockets av1 av2 av3 or e1 i'd connect it to av3 good luck
regards
shaun
Jul 17, 2010 | Sony Playstation 3 (PS3) Console
I hooked hdmi to tv. i went thru ps3 settings for video n audio n swithch audio to the red n white output. now i have sound thru surround sound but my video is flickering n i cant c so i can undo it
Make sure the Component AV Cable is connected to the AV Multi Out port on the back of the PLAYSTATION 3 system. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the ON/OFF button long enough to reset the Video Output Settings.
3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jul 01, 2010 | Sony Playstation 3 (PS3) Console
Have an RCA F27636BC TV. Can u hook a DVD player
How to hookup TV
If you have a TV with only a single coax input and you want to hook up components like DVD players and VCRs, here's how to do it.
What you need to connect your DVD player or game players to a TV that only has a VHF/UHF 75-ohm F-connector ("coax antenna input").
1.) RF Modulator with Stereo Audio Inputs.
2.) 6 foot long coaxial cable with male "F" connectors. This cable goes from the modulator to the TV. The modulator also has a coaxial input to plug in your antenna or your VCR.
3.) 6 foot long Video and Audio Cables with "RCA" plugs. The cables connect the yellow, red and white outputs from your DVD or game player to the yellow, red and white inputs of the modulator.
Works with X-Box, PlayStation, Nintendo or other devices that output audio/video via the RCA plugs and you want to connect them to your coaxial only TV.
Nov 24, 2009 | RCA F27636BC 27" TV
PLAYSTATION HOOK-UP
i have a tv that only has the audio out put and video out put as well . and my playstation 2 works on it. just plug the white and yellow ends in to your tv and it will still work without you unplugging any cables. hope this helps.
Apr 02, 2008 | Sylvania 6427FF TV
Playstation hook up
Hi Audrey, you need to get some a av cable ie the av with the 3 av connections on both ends, then i would buy a av - skart adapter so it will plug into any tv, i would say for both around £10 for both.
and it will get you up and going..
All the best
John
Jan 02, 2008 | Sony PlayStation Portable (PSP) Console
Hook up all my components together
Hi knit, You need a 4 port A/V switch. Ebay has one: http://cgi.ebay.com/4-Port-AV-Audio-Video-S-VIDEO-Selector-Switcher-w-Cable_W0QQitemZ150168531361QQihZ005QQcategoryZ73390QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Oct 05, 2007 | Sony PlayStation 2 (PS2) Console
Connecting ps2 to my TV
did you hook the yellow up to a green jack labeld Y on the back? What kind of tv do you have? Some component inputs (the ones with the green Y jack) are not compatible with the video input you have, some are.
Jul 08, 2007 | Sony PlayStation 2 (PS2) Console
Durabrand DWT1905 TV Logo
180 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
