Question about Panasonic PT-47WX42 47" Rear Projection Television
Computer to TV Inter-connectivity
I want to connect my PC to the Panasonic TV... using the TV as the monitor, so I'm wondering if that is possible and if there is any kind of serial-to-s video cable, or serial-RCA cable, or any kind of connector that will work? Can it be done????
  • DC33 Oct 11, 2007
    I went to the suggested web site, but was unable to find a serial-to-s video cable, or serial-to-RCA, which is the only way I can practically utilize the TV as monitor for computer output.  Thanks!
  • 1,153 Answers
Yes, look at
Posted on Oct 08, 2007
Laptop to T.V. connectivity
This is my first time using this site, but I will try my best to assist you.
From what I understand, you want to connect your laptop display to your T.V. In turn using your T.V. as a "monitor".
So you were wondering if you could use a S400 to HDMI cable to accomplish this. Unfortunately I don't believe this is possible with that cable. To my best knowledge, S400 ports are only capable of transferring DATA between devices, not VIDEO. A VGA or HDMI cable will accomplish what you want. I don't think your laptop has a HDMI port, so I recommend buying a male-to-male VGA cable.
I looked up your T.V. and it looks it should have a VGA input port. This is what I did for my laptop and 32 inch LCD T.V. when i accidently cracked my laptop's screen.
It may not be High Definition, but you should be able to get fairly decent resolution. Make sure your T.V. is on the "Computer" input channel. (Or equivalent)
I don't recommend buying a VGA to HDMI cable converter as it usually doesn't result in improved quality.
I hope this helps! Good luck!
Jan 21, 2013 | Computers & Internet
Can i hook my 47inch tv to the monitor
You can't hook you TV to the monitor itself, rather the computer.
If your PC has a wide white connector (DVI) that is supplying signal to the monitor, you could use a DVI to HDMI adapter cable to connect your PC to your TV. This is also possible if your PC uses a small blue connector with 15 pin holes (VGA) by using a VGA cable to connect your PC to your TV.
Mar 17, 2011 | Acer AL1916W 19" LCD Monitor
We have a panasonic 32"inch lcd tv.we want to
hdmi Ports Qty 3 port(s) PC Interface VGA (HD-15) HDCP Compatible Yes
I read your tv has 3 hdmi ports and a PC input.
if your pc has hdmi out - the you use a hdmi cable from the pc to the tv on one of the hdmi inputs.
if your pc has a 15pin vga cable you can unplug from your PC monitor (or go buy a VGA cable if you want to keep one on the tv and one on your pc monitor - or if you are using a laptop).
when you unplug the computer from the monitor .. check the pins - should look to be about 15 pins in the connector. it that will plug into the tv- then you are using a vga cable. if it will not plug into the tv pc input .. don't force it. It could be a dvi connector . .take the cable off the PC and to radio shack and they can fix you up (you need a dvi to vga cable - not likely, but possible)
I always turn off a pc before disconnecting monitors - and plug into the other display before turning the pc back on.
Good luck.
Nov 29, 2010 | Panasonic TCL32U22 32 in. TV
Can I use my tv as a computer monitor?
You can use a video card that has composite out, but the picture will never be as clear as your computer monitor. for that you will want a LCD with vga connection.
May 06, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Video outputs
There are TV/Monitor hybrids out there. You could get a 60'' plasma widescreen and use it as your desktop monitor for example. But as far as watching 'streaming video' from like....HBO from your local cable provider, you will not be able to do it with this computer unless you purchase an add-on card (be sure you have the open PCI slot first).
You would need something like the cards listed in the url below (again, be sure your motherboard is compatable with it first).
Jun 05, 2009 | Sony VAIO PCV-RS720G (027242658103) PC...
Concerting TV to PC
to my understanding,LCD can only be connected as monitor ,not to become a computer itself.if ever it can be use as one, you'll need all the basic of the computer accessories.wireless modem can be use as long as there is a slot for or the unit is compatible for a wireless connection.check first if there is a socket for keyboards and everything before buying.since it can be connected only by vga cable, i assume that it is for monitor use only,unless you want to use two monitors at the same time.
May 14, 2009 | Televison & Video
Connect computer HDMI to Projection TV HDMI to watch web TV
use a s-video cable or a monitor ext cable and use fn+f4 to switch
pc mon to ext mon.
n.b. f key is usually f4 , models vary.look for square icon on f key.
fn+ that key; thats fn and say f4 pressed together.
Jan 28, 2009 | HP Pavilion dv6000z Notebook
Yes, you may be able to google it or download one from the company's website that made the monitor. Sometimes the monitor is not compatible with the computer until you download a driver. I'm assuming you're using A/V cables when using the TV with the computer. Often computers do not display well with a/v connections until you install a driver. Hope this helps.
Nov 03, 2008 | Computers & Internet
Connecting laptop to tv
1. If your tv has a PC input, use a vga cable, from any normal computer monitor.
2. If you use those HD connectors, match them to the correct colour coded inputs on the tv.
In each case, do all the connecting with the computer POWERED OFF. Then when connected, boot the computer, and allow Windows to auto-detect the 'new monitor', as it will 'see' it.
Then you shoud right click on your desktop, choose properties, and goto 'settings'. From there you will see monitors 1 and 2. click on the new monitor and 'enable' it.
You also have the option of 'extending' windows to the second monitor, as well as making this your 'default monitor'. Experiment to see what best suits your needs,
May 16, 2008 | Dell Precision M60 Notebook
Panasonic PT-47WX42 47" Rear Projection Television Logo
54 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
