Question about Luggage & Travel
What is the difference between an adapter and a voltage converter?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • 54 Answers
An adapter is usually a travel converter that simply allows one kind, size or shape of plug to physically fit the socket.
A voltage converter is a gadget that stands in between the plug and the socket and converts the voltage released by the socket so that the plug and therefore the device itself don't get ruined by the wrong voltage.
These two kinds of converters can be combined and have different converting options, to allow its use in multiple regions.
Posted on Nov 21, 2013
Replacement power supply - can i convert AC to DC output connector?
I'm not clear on the four pins of the DC power supply for the speakers. Do you think there two different voltages needed??? It's not worth trying to convert your ac power supply/ It would take a few parts and you will not end up with 18 vdc. You can purchase a 18 v dc adapter for as little as 15.00.
Jun 16, 2014 | Altec Lansing M604 Computer Speakers
How I can convert 110volts to 220 voltage in Craftsman charger 145301 because in the Peru country we use 220 v. thanks.
_Some_ chargers will allow a range of input voltages. This will probably be "Input: 100-240V" or something like that written on the charger. __You need to be sure__. Others may have a switch from one voltage to the other. The trick here is to make sure the switch is in the right position. In both cases you may also need a plug pin adapter. If the charger you have has neither of those abilities then you either need to get a different charger from Craftsman, or get a voltage converter, which will give both the right plug for your wall sockets and convert from 220V (from your wall) to 110V (to the charger). Unless the charger has voltage range or a switch, you can't just use a simple plug pin adapter.
Feb 20, 2011 | Craftsman Drills
Hello. I purchased a panasonic tv in germany and now am in US I would like to use it here in US, what do I need to do in order to convert it for US? Adapter? Converter? Is there a switch on the TV? Thank...
check the manual for the tv, it may be dual voltage if not then you need a transformer, to stepup from 115V to 230V (nominal voltage). It may have problems with the TV signal as well, as the US is different to europe. Again check the manual first.
cheers
tech240
Sep 13, 2010 | Panasonic Televison & Video
Wii power problem!
You are not getting the correct voltage into the Wii, this can happen one of three ways. (1) The power converter you have is not converting the power correctly, (2) running on converters are not exactly matching the correct voltage and wattage has strained your power supply and damaged the Wii, or (3) the power supply itself just failed as a result of any number of normal electrical conditions.
Jun 09, 2010 | Nintendo Wii Console
VOLTAGE CONVERTER?
You need to obtain an AC adapter designed to work with your laptop and also run on 110 to 220 Volts.. Depending on your Laptop manufacturer, you may be able to obtain one specifically designed for your laptop. You can also find these devices online. look for 2 things... the ac adapter and the plug converter kit... lots a different ones, so look for the type you need for the locale you are going to. Some universal kits covers all the major types.
Apr 12, 2010 | Computers & Internet
I'm going to Europe and wanted to know how to convert electricity so when I plug in my computer it won't fry the computer
This is a copy from the Radio Shack site. The quick answer is go to pretty much any electronic store or most travel stores and buy a Foreign Power Converter.
AC to AC Power Conversion (Foreign Voltage Converters) Purpose of Converter / Explanation of Operation AC-to-AC voltage converters, or travel converters, are designed to convert the voltage used in a foreign country to the voltage required for a particular AC device. These converters are either transformer-based or solid-state, and this affects what type of devices the converter can power. In addition to converting the power, you will often need to also use a plug adapter. Plug adapters are generally either built into the converter, or provided as separate parts. They are also sold separately, for use with multi-voltage devices that are designed to convert the power internally.
Selecting a Converter These are one of the more confusing of the power conversion devices. Because of the range of voltages, plug types and converter designs, many customers find that they need help determining exactly which converter they need. To aid in that process, we have put together a short worksheet to help you determine what type of converter is needed: We recommend that you print out thi sheet when taking a number of different devices to a different country.
First, you should determine the electrical requirements (voltage, frequency, and wattage) for the device(s) you will be taking with you. This information is generally on a label or embossed into the back or bottom of the device. Make a note of the voltage(s), frequency or frequencies, and the wattage indicated for each device.
  • The voltage may be given as either V, VAC or VDC. The standard voltage for US devices is 120 V. Devices that are designed to operate using different input voltages will be labeled, such as 110/120 V, or 120/240 V.
  • The frequency will be given in Hz. The standard frequency for US devices is 60 Hz. Devices that are designed to operate using different frequencies will be labeled, such as 50/60 Hz.
  • The wattage will be given in either watts (W) or volt-amps (VA). If the wattage is not listed on the device, you will need to contact the device's manufacturer for this information. If you have the maximum current consumption (in amps), you can calculate the wattage by multiplying the voltage (V) times the current consumption (A).
Next, you will need to know the electrical requirements for the country you are going to be visiting.
Next, you will need to compare your equipment requirements to the country's information to determine whether you need a Step-up or Step-down Voltage converter.
  • If your equipment accepts the voltage and frequency provided by the country you will be visiting, then only a Plug Adapter will be required.
  • If the voltage of the target country is higher than the voltage required by your device(s), you will need a Step-Up Voltage Converter.
  • If the voltage of the target country is lower than the voltage required by your device(s), you will need a Step-Down Voltage Converter.
Once you know what type of converter or adapter you need, consult our list of travel power conversion products to find one that meets your requirements.
Cautions
  • The AC outlet in many foreign bathrooms is for low-wattage devices only. To avoid damage to your converter and/or attached device, check with your host or hotel before powering a high-wattage device (such as a hair dryer) from this plug.
  • Do not use a voltage converter with electronic devices such as televisions, VCR's and computers unless the device indicates that it can handle both 50 Hz and 60 Hz.
  • Do not use heating appliances, such as hair dryers, irons and coffee-makers, on a transformer-based voltage converter.
  • Do not use non-heating electronic devices, such as calculators, electric razors and portable audio players, on solid-state voltage converter.
  • Do not use 110-120 VAC Surge protectors or Uninterruptible Power supplies on a 220-240 VAC system. Even with a step-down power converter, damage could occur as the two power systems are wired differently.
Sep 22, 2009 | Toshiba Satellite L305D-S5895 Notebook
Use Sony ICF-C1IPMK2 in Europe
A transformer type (Linear Mode Power Supply) AC to DC power adapter with a 9.V nominal output, measures about 12.V without load when tested with a multimeter. A power adapter with a nominal output of 7.5 V, measures a little over 9.V. Considering a number of people across different forums reported the adapter's measured power output as 12.V, I think the nominal rating of the AC to DC adapter should be 9.V. However, keep away from Switch Mode Power Supplies.
Jul 21, 2009 | Sony ICF-C1IP White Powered Speaker System...
Its fuzzy at the start and then resets over and over again
even though the adapters allow you to physically plug in the N64, the voltages/amps might be different. try to use a voltage converter, and please, don't let your N64 fry.
Jul 02, 2009 | Nintendo 64 Console
Wii Poer voltage Damage
The problem is that the voltage in NZ is different (higher) than that of the USA, and the power adapter (gray box that plugs into the wall) has blown. Replace the power adapter and use a voltage converter that lowers the power to 115 (or 110/120) volts, and you should be good to go. ;)
Jan 28, 2008 | Nintendo Wii Console
Luggage & Travel Logo
109 people viewed this question
Top Luggage & Travel Experts
Dave braun
Dave braun
Tom Chichester
Bobby Lewis
Bobby Lewis
Are you a Luggage and Travel Expert? Answer questions, earn points and help others
