I found this online at
www.sandisk.com under warranty and manuals link.
I believe they have an excellent Return Authorization system, that if you truly have trouble with your disk player and it's still under warranty, gather your receipts and get on line to get an RMA. I have successfully returned to disc players that were infact faulty (FAT problems) and received two replacement players. Get on it right away. Look at the manaul online too. IT can be very helpful. I've included the Battery info, and the link for the manual at the end.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
