Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Water won't spay out of the nozzels under front plastic
Water will not spay out of the nozzels in front But it does come out underneth the machine. I cleaned it all up and blew air at the nozzels. Are there any suggestions. I can't figure out how to take the cover off to see if the tube came off. Thanks in advance Ooley
    President:
  • 1,673 Answers
There are 6 screw, 3 on each side, then the top will come off. When you put it back on, make sure the piston is attached to the bottom of the smart mix knob and that the knob is in the water setting.
Posted on Jan 17, 2008
SOURCE:
How to trouble shoot and repair at home Bissell proheat 2X water will not spray from floor nozzel ?
Check your User's Guide. Cleaning the filters may do the trick. Contact Bissell Consumer Care at 1-800-237-7691
Sep 17, 2014 | Bissell Vacuums
Model 5835-900 leaks when using the hand tool
Take the 4 screws that hold the hood out and remove the hood. Hook up the hand tool line and watch for where the water comes out. It is more than likely the tool valve has failed.
This is the part here:
http://vacuummedic.com/product.php?id=231
Good Luck!
The Vac Dr.
Dec 20, 2012 | Hoover F5835900 Upright Steam Vacuum
The water is not spraying out of the nozzel when I start to clean from my little green. Any suggestions and can i fix it?
Be sure there are no holes in the pipeline that run from the input to the nozzle. Try running it under hot water. Sometimes the chemicals and dirt get in there and dry up at the holes.
Feb 24, 2012 | Bissell Vacuums
My steam cleaner is not spaying water on the carpet?
I found that if the water is not hot enough it won't create the suction needed for the water to spray. If you have use it in the past it could be that the water tubing could be clod.
Jul 21, 2011 | Bissell 1770 Quicksteamer II Upright...
How do i remove the hood for cleaning out debris?
there should be three screws on this unit to remove the clear plastic hood.
first, remove the dirty water container, there will be one screw there to remove. It should be rather long.
next turn the machine over, there will be 2 more screws under the corners of the front of the machine (you can see the threads through the plastic on the top) remove the two screws.
Now comes the tricky part. Turn the machine back over so that its the right side up again, you will want to pull away from the machine and up, kind of like you are going to bend the plastic up. Once you have that done the entire cover will come off.
Good luck,
Mark
Nov 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Brushes will not turn
check under the unit for clogges, then check the hose going into bowl.
Feb 24, 2010 | Hoover F7431-900 SteamVac Vacuum
Severe water leak at the bottom when turned on.
It sounds like the tubing that is suppose to be hooked to two spray nozzles has come loose. You will have to take that dirt tank off, then turn the machine upside down and take the two screws out that hold the hood on from the bottom by the brushes, and then turn the machine back upright and take the screw from the top out. You should be able now to take the hood off and see all the tubing exposed. There is only one tube that goes to the spaying part in the front and see if it needs to be pushed back onto its' barbed fitting. Put that back on and put the hood back together. That should get you going.
Dec 02, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I just replaced the drive belt on a Guardian vacuum and am having difficulty putting the cover on. Is there a trick?
There is a collar on the power nozzel elbow where the elbow goes to the nozzel. You need to pry it off with a screw driver. Don't worry about it breaking. It just snaps off and on. This will make it easier to get the top aligned. Make sure that the front of the cover is touching the rubber bumper and lay the cover down to the back side of the nozzel. You will have to lean the elbow up when you are trying to get the cover down in place. You'll see what I mean when doing this. When you replace the screws, you'll have one that is shorter than the rest. The short screw goes in the hole on the front side of the nozzel on the part that the motor is not on. Hope this helps.
Oct 12, 2009 | Electrolux Guardian Bagged Canister Vacuum
I have a billell Pro Heat 2X without a manual. How do I fill it and what ratio water to cleaner?
The cleaner goes into the small bottom at the very rear of the machine. It is uses full strenght (don't add any water to it). You add clean water into the bottom clear plastic section on the front of the machine. The clean water bladder is soft plastic and it is filled from the top. When you start using the machine, the dirty water will get suctioned into the section surrounding this bladder. The machine will stop working when either the bladder is empty or the dirty water section is full. Remove the entire plastic section to dump out the dirty water.
Sep 19, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
No water
It is easy to take the top off. Mine has just 6 screws. Then you can see all the tubing and parts. For example, you can unclip the nozzles and see if water flows. Try blowing through the nozzle to see if it is plugged. Some people say the heating unit in the handle plugs up, particularly if you put soap in the water tank. I haven't dealt with this, but it should be easy to open the handle and bypass the heating unit.
Aug 19, 2007 | Bissell Powersteamer 1694 Upright Vacuum
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
