Question about GE JGRP17 Gas Single Oven
Oven Problems HELP
I am havinf problems is igniting the oven part, the broiler is working OK. Coouple years ago I had the Reair tech from GE and fixed the problem cost me opver 200 bucks.
    President:
  • 331 Answers
Morris, the problem with your oven is the igniter. The igniter is wired in series with a safety valve. The safety valve monitors the amount of electrical current flowing through the igniter when you ask it to "bake".  When the igniter gets "weak" it won't allow current to flow through it properly, this will keep the oven from heating.
Before you begin the repair, you should have the new part on hand. The part number is WB2X9154 and can be purchased at your local appliance parts retailer for about $50.00. Here's one online for $65.00.
First, UNPLUG YOUR OVEN!
To replace it... Remove the racks and lower panel (oven floor). This will expose the burner manifold where the igniter is mounted.  (It's the round thing on the manifold near the back... it has 2 wires going into it.) You'll need a 1/4" socket or nut driver to remove it.
(*TIP---> before removing the screws from the igniter, put a few drops of liquid dish soap on the threads to lubricate them. If you do this, you will not strip the threads of the screws and it will ease their removal.)
The new igniter kit will have two ceramic wire nuts in it. Cut the two wires off of the old igniter and strip them back about 3/8". Then connect the wires of your new one to the wires in the oven using the ceramic wire nuts provided. Then mount the new igniter and rebuild the oven.
(*TIP---> The new igniter is very fragile! [that's why it came wrapped tightly in bubble wrap] Handle it gently!)
There ya go! Total job time? ~45 minutes.
Posted on Oct 11, 2007
SOURCE:
My Ge oven does not work but the burners on top work fine and the broiler works as well what could be the problem
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 01, 2011 | GE Ovens
Our GE oven will not work. The stove and the broiler both work but the regular oven will not! Any ideas?
Oven not Working or
Oven not Heating
heatman101
Feb 19, 2011 | GE Ovens
My ge exl oven does not work, broiler and burners work
heatman101
Jan 09, 2011 | Ovens
Bake feature on oven won't work ignition light glows but flame won't spark. broiler works
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Dec 10, 2010 | GE 30 In Freestanding Gas Range ...
My GE JGBP32GEL Gas oven will not light. Electric pilot does not glow. Broiler work fine.
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Dec 07, 2010 | GE Ovens
My oven doesn't heat up the broiler works but not the oven
heatman101
Nov 23, 2010 | GE Ovens
Oven will not ignite, it is approx. 8 yrs old. 2 years ago the ignitor was changed for a similar problem. Everything works on stove even the broiler. Very dissapointed in the GE profile since I have had...
Jim your ignitor has gone bad once again.
You can turn off the gas supply,remove the oven racks,remove the oven base pan,remove the flame spreader to access the ignitor.
Place a clamp on amp meter over one wire of the ignitor and turn the control on for bake. If the ignitor does not glow at all. It is bad. If it glows and reads 3 amps or less on the amp meter it is still bad.
A proper functioning ignitor will light and re-light the burner in 45 seconds or less.
Jan 01, 2010 | GE Ovens
My GE Single Gas Oven won't light, the broiler works. My husband can put in the part, what part do I need.
heatman101
oyuou
Nov 09, 2009 | GE JGRP17 Gas Single Oven
GE Oven does not ignite, bute Broiler does.
Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
Oct 14, 2017 | GE JGRP20 Gas Single Oven
Top Broiler works, oven does not work at all
hi yes you could replace the broil for the bake but they are very fraglle so i would buy a new bake igniter replace
May 18, 2008 | GE JGRP17 Gas Single Oven
GE JGRP17 Gas Single Oven Logo
Top GE Ovens Experts
William Miller
William Miller
Ekse
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
