Question about Royal Office Equipment & Supplies
Shredder making noise and will not shred - Royal Office Equipment & Supplies
SOURCE: DM15C stops after 4 seconds, open bin light comes on
I lived with the problem for 6+ Months -- drove me NUTS -- Today, I called Fellows -- Spoke to "JoAnn"... She said this works 80% of the time...
Pull out the bin -- put your foot inside to hold the shredder down -- pull up on the top of the shredder -- you WILL hear a POP as the plastic top disengages from the bottom but TRUST ME THIS IS OK! -- take off this top section (which houses the blades) -- flip it over -- you will see 6 screws total but it is the sets of 2 screws close together to focus on -- right next to the screws you will see a tiny glass sensor -- use a q-tip and alcohol to give them a wipe -- press the top back on -- bin back in -- you are DONE -- This took me less than 1 minute and it works as it did the day I got it! Go shred something!  :)
Posted on Jan 05, 2009
  • 541 Answers
SOURCE: It seems a sif soemthing is blocking the shredder
you will need to take it aprt. over time paper dust gets in the gears, transmission and bushings. you will need to remove all the dust and inspect the drive gears. mosyt of these come apart buy taking it off the stand. flipping it over, messy. removeing the bottm bolts/screws. then maybe remove trans mission cover.
Posted on Oct 29, 2009
  • 610 Answers
SOURCE: SHREDDER INDICATOR KEEPS COMING ON WHILE SHREDDING
look for two LED lights where paper falls into bin and wipe them off, but the sensors could be faulty as well. I have seen both.
Posted on Nov 11, 2009
  • 1218 Answers
SOURCE: I have a Royal RL170MX shredder. It has started
Try putting some oil on a sheet of paper and then shredding the paper with oil on it.
If that dosn't fix it....take cover off....(with the unit unplugged.) and check plastic gears in drive train.
Posted on Jun 28, 2010
  • 1218 Answers
SOURCE: I have a vf1700mx I
If the moter runs but the cutting shafts are not turning then you have likely stripped a gear.... unplug, open top to see which one the give Royal a call at 1-800-524-0799; they should be able to help with parts.
Posted on Aug 19, 2010
Shredder is making a loud noise when attempting to shred a document.
The shredding mechanism could be clogged to the max or someone tried to shred a credit card or plastic coated material.
Feb 06, 2017 | Shredder Office Equipment & Supplies
What kind of oil is used on the royal orca 9512x?
The shredder does not use oil. The noise probably relates to something jammed in the shredding mechanism or one or more damaged shredding elements.
Mar 01, 2015 | Royal Office Equipment & Supplies
Squealing noise when shredding
Have you tried putting any shredder oil on a piece of paper and running that through the shredder?
Feb 03, 2014 | Fellowes Manufacturing Powershred C-480C...
Shredder OM02750 from Office Max..we have been using it a lot recently and it makes a loud screeching noise when shredding and after shredding that it did not make before. We have used the lubricant...
I had the same problem with a similar type shredder. Unfortunately, the only solution I could come up with after doing a lot of research and trying several diferent things was to buy a new one... good luck
evary at calgary dentists
Sep 24, 2011 | OfficeMax 0M96431 Shredder
Shredder does not pull paper in anymore, it makes noise, does not shred
Add some paper shredder oil. A shredder needs oil to function properly, oil should be applied every month or more depending on how often you shred. Learn more here: http://hubpages.com/hub/Paper-Shredder-Oil
Jun 13, 2010 | Fellowes DM8C Cross-Cut Shredder
When I put paper to shred ,all I get is motor noise but no shred
You probably have a stripped drive gear. let me know what brand shredder you have.
May 14, 2010 | Office Equipment & Supplies
Shredder makes a horrible sound when shredding.
Just put a lightweight shredder oil on some paper and shred the paper...do this a number of times this will get the oil down into the cutting shafts.
May 01, 2009 | Royal VF1000MX Shredder
Our shredder is making a loud, grinding noise.
simply try resetting the machine. unplugging it waiting for about 30 seconds then plugging it back in, also is the unit mounted properly on the unit? It might be one of the gears that is not broken...if you have a warranty now would be a good time to call them as they will fix or replace the part for the unit.
Apr 10, 2009 | Medium Universal Office 38082 Shredder
Paper shredder not working
sounds like the cutting wheels have something jammed inside them , can you take it bak and return it ? or open it up and see if anything looks bad inside ?
Jan 07, 2009 | World Office Products Papermate PM-600C...
Makes noise but won't shred
Had the same prob with a Schneider shredder. The roll pin that secures the nylon driven wheel to the blades shaft was sheared. Easy fix in a way but original pin was a metric size.
Jul 13, 2008 | Tech Solution TS-2550 Shredder
32 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
