Question about OfficeMax 0M96431 Shredder
Shredder making noise and will not shred - OfficeMax 0M96431 Shredder
4 Suggested Answers
  • 35 Answers
SOURCE: The shredder jammed (too much paper) then stopped
Chances are, the overfeed caused the teeth of the gear that operates off of the motor to break.
This is very common in less expensive machines. I don't know if OM will let you return it because I don't know there policy. Most of the time retailers will attribute broken gears to abuse, which in turn is not warranted. These machines are mainly mass produced in China and obviously are very cheap. The labor and part (s) to repair are more expensive than replacing the machine.
If you do, look for a higher quality German machine i.e. Intimus, Olympia, HSM or Dahle. They cost more but they have a nationwide service arena and parts are always available.
Posted on Mar 08, 2009
danforddan1
  • 192 Answers
SOURCE: shredder won't shred
They may be a compression switch on the lip where it sets on the bucket. This it to prevent it from running while its off its buckette. If this is not all the way in it wont run. Look for that clean any safty switch or buttons you find.
Slap it with your tax booklet and call me in the morning. Good luck DFD
Posted on Apr 16, 2009
SOURCE: Shredder OM02750 from Office Max..we
I had the same problem with a similar type shredder. Unfortunately, the only solution I could come up with after doing a lot of research and trying several diferent things was to buy a new one... good luck
evary at calgary dentists
Posted on Oct 09, 2011
Shredder is making a loud noise when attempting to shred a document.
The shredding mechanism could be clogged to the max or someone tried to shred a credit card or plastic coated material.
Feb 06, 2017 | Shredder Office Equipment & Supplies
What kind of oil is used on the royal orca 9512x?
The shredder does not use oil. The noise probably relates to something jammed in the shredding mechanism or one or more damaged shredding elements.
Mar 01, 2015 | Royal Office Equipment & Supplies
Squealing noise when shredding
Have you tried putting any shredder oil on a piece of paper and running that through the shredder?
Feb 03, 2014 | Fellowes Manufacturing Powershred C-480C...
Shredder OM02750 from Office Max..we have been using it a lot recently and it makes a loud screeching noise when shredding and after shredding that it did not make before. We have used the lubricant...
Sep 24, 2011 | OfficeMax 0M96431 Shredder
Shredder does not pull paper in anymore, it makes noise, does not shred
Add some paper shredder oil. A shredder needs oil to function properly, oil should be applied every month or more depending on how often you shred. Learn more here: http://hubpages.com/hub/Paper-Shredder-Oil
Jun 13, 2010 | Fellowes DM8C Cross-Cut Shredder
When I put paper to shred ,all I get is motor noise but no shred
You probably have a stripped drive gear. let me know what brand shredder you have.
May 14, 2010 | Office Equipment & Supplies
Shredder makes a horrible sound when shredding.
Just put a lightweight shredder oil on some paper and shred the paper...do this a number of times this will get the oil down into the cutting shafts.
May 01, 2009 | Royal VF1000MX Shredder
Our shredder is making a loud, grinding noise.
simply try resetting the machine. unplugging it waiting for about 30 seconds then plugging it back in, also is the unit mounted properly on the unit? It might be one of the gears that is not broken...if you have a warranty now would be a good time to call them as they will fix or replace the part for the unit.
Apr 10, 2009 | Medium Universal Office 38082 Shredder
Paper shredder not working
sounds like the cutting wheels have something jammed inside them , can you take it bak and return it ? or open it up and see if anything looks bad inside ?
Jan 07, 2009 | World Office Products Papermate PM-600C...
Makes noise but won't shred
Had the same prob with a Schneider shredder. The roll pin that secures the nylon driven wheel to the blades shaft was sheared. Easy fix in a way but original pin was a metric size.
Jul 13, 2008 | Tech Solution TS-2550 Shredder
OfficeMax 0M96431 Shredder Logo
37 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
ROCKIT957
Randy Schumann
Randy Schumann
Colin Stickland
Colin Stickland
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
