Question about Sony Walkman TCD-D8 Personal Cassette Player
Screw fell out - tape transport mechanism stopped working
Hi - my tcd-d8 suddenly stopped working. I discovered that a screw had come out of the inner workings which stopped tape movement in playback, FF and RW. I took it to an engineer who had it on his bench for over a month before telling me basically that he didn't know how to fix it. I have managed to get as far as removing the cover but the problem seems to stem from the next level down. It's very frustrating as I feel sure it's really just a question of putting the screw back in - if only I could be confident about removing the top layer. The electronics seem fine. Can anyone give me an idea about how to go about doing this or am I just going to make matters worse? Thanks, Cairoguy
No Dave am in Cairo. Will be back in Glasgow later this year though and may give them a call. Maybe time to move on to solid-state although I love the D8. Thanks
Posted on Jan 26, 2008
If you are in the UK, I recommend 'Richmond Film Services' who have an excellent engineer. David
Posted on Jan 25, 2008
SOURCE:
A vhf tape got stuck in the machine. I could see the tape itself was caught on some moving prongs. now i don't know the proper setting for the prongs and cannot get any vhs tapes to play.
Hi, if VHS tape is in you have only one solution..to disassemble DVD/VCR ..Can you do it ? you may try !!t
Here's how to do it..
* 1 Turn off the COMBO. and unplug it.
* 2 Remove the 4x screws off COMBO on the sides and take off the DVD/VCR casing.
* 3 Look for the Tape which messed up with VCR transport mechanism ,try to release tape of the transport with your hand..
* 4 Since EJECT feature works with power only ,while you keep the tape off from transport plug the device to power and turn it on..Don't worry,you will see the eject mechanism starts moving back on forth,keep the tape off it and let it eject..
* 5.When tape is out .If it destroyed badly normally you should not use it however if the recording in is valuable for you you can cut the chewed portion and
splice it back together .(Pls see the video included...How to fix a broken VHS tape.)
* 6 While it is open,place another Tape to see if mechanism works properly. and eject it...
* 7 Replace the casing and the screws. Plug the player in and turn it on. Now player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
http://www.youtube.com/watch?v=Q1PJWA2KGyg
Mar 13, 2011 | Philips DVD740VR DVD Player/VCR
Plays tapes to slow
some time u can push play and ff or the rew and it work
Nov 06, 2010 | Sony Walkman TCD-D8 Personal Cassette...
We changed the batteries but I am still getting static and in and out music....does my Walkman need to be repaired? FS393..are 2 AA enough?
Please do a good cleaning off the head the rollers and the transport section., This will remove off all the static noise to be relayed to the head. make sure you use a reliable solvent to do all the clean up. make sure the reel and drives are working fine. also the pinch rollers are running without chewing the tape. If so replace the rollers and the belts. Hope this helps.Good day
Jun 15, 2010 | Sony Walkman TCD-D8 Personal Cassette...
Sony tcd-d8 won't rewind
sounds like a belt slipping try renewing them they are fairly cheap to replace.sony tend to be very reliable but this is quite an old item now and belts degrade with time and use.farr64
Apr 30, 2009 | Sony Walkman TCD-D8 Personal Cassette...
No functions works....
This sounds like the internal drive belt has broken and the mechanism is not in a "final" position. The noise you hear is hte motor trying to get the mechanism back to a known condition. This should be a simple repair for any audio repair shop. Expect a parts cost in the $5 range. Add in the local labor rate for the total repair cost.
Dan
Feb 26, 2009 | Sony Walkman TCD-D8 Personal Cassette...
Distortion!
did you record them on the same unit?
It may be an alignment problem.
If it's the same unit, try cleaning the heads.
There are dat cleaning tapes too, but they beat on the heads.
Jul 31, 2008 | Sony Walkman TCD-D8 Personal Cassette...
Sony walkman TCD-8
Clean the heads or use a tape cleaning tape.
Feb 21, 2008 | Sony Walkman TCD-D8 Personal Cassette...
Playback problems started suddenly
I had the same problem. I fixed it by gently dropping the camcorder on the carpeted floor. I know it sounds silly, but it really works. I've had to do it twice, and it worked both times. I hope it works for you.
Jan 08, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Repair Sony DAT Walkman?
The "solution" by techman appears to be entirely inappropriate because the link he posts takes one to a company that repairs data storage units, NOT Digital Audio Tape (DAT) recorders.
Sep 22, 2006 | Sony Walkman TCD-D8 Personal Cassette...
Sony Walkman TCD-D8 Personal Cassette Player Logo
119 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
