Question about RCA HD52W56 52" Rear Projection HDTV
52" rca\hdtv The tv is shutting down after it has been on a few minutes. You let it sit a few minutes and will start back up, but it will shut back down. It seems like when it gets hot it shuts off. Can you help me with this. Thanks, James
  • 3 more comments
  • jbolton1969 Nov 28, 2007
    Mine does the same thing, however it does it at different intervals. It will normally run fine, but it turns off sometimes when watching a dvd, or other video.
  • MikeinTampa Dec 02, 2007
    We're having the same problem. The tv turns on, then after a few minutes it shuts off. It'll turn back on then shut off again and stay off. We have the 52 inch HDTV, RCA. I don't know if this is the TV itself or if perhaps there may be a connection somehow with Verizon Fios. Do you also have Verizon in your homes? (with DVR?) - We bought our TV in 2004 and haven't had any problems at all until we switched to Verizon.
  • bassjam Dec 06, 2007
    Mine finally went on the blink. I took it to a t.v. repair man and it cost me $135. I think he said a circuit board was burned. I'm good to go now. Hope this helps.
  • freyjadawn Nov 13, 2008
    Our RCA HD shuts down after watching a DVD or playing video games. First time it was under extended warranty, 2nd  time it wasn't. Repair guy said it was a board, but said RCA doesn't make them anymore.  This is 2 circuit boards in 2.5 years. Guess the TV wasn't such a great deal afterall.
  • ropere Nov 30, 2008
    My tv shuts down several times a day and is sometimes hard to turn back on. I have an extended warranty and they have taken the tv into the shop twice. However, it continues to do this. Any suggestions??
Do not have Verizon. I wished I could figure this out. I first thought it may be a power over load, on a certain receptacle, however that was not it either.
Posted on Dec 06, 2007
RCA D52W20 TV powers on fine, then shuts itself off after 5 - 10 minutes. After 20-30 minutes, I can turn tv back on, but then shuts off again in 5 minutes.
it looks like the problem is in the 16v line..try to take it apart..and there's gonna be a 2200mf cap leaky.
that will solve your problem.
Jan 05, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA big screen plays for about half a movie and picture dims then shuts off. Sound still works. I shut off for a few minutes picture comes back on and shuts off again after few minutes.
These units are famous for loose connections around the high voltage transformer and also bad capacitors in the power supply. The deflection PCB has to be removed to fix this problem. You probably would need to have a repair shop check it out for you. Thanks
Oct 29, 2009 | RCA HD52W56 52" Rear Projection HDTV
Picture on TV shuts down but sound still on.
If this RCA TV has a Chassis number of ITC222 then you need to call a tech to swap out the deflection circuit board for a new or rebuilt board. This RCA Chassis is a TV Techs worst nightmare to repair.
Jul 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HDTV MODEL # D52W20 SHUTS OFF AFTER 10 MINUTE.
There is a common power supply problem with these that requires the replacement of four capacitors on the power board. This could be causing your problem.
Mar 25, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rear Projection TV shuts down after a few minutes.
My science teacher had the same problem.
After, he replaced the lamp it stoped over heating.
witch is most likelywhy the tv is over heating
Jan 21, 2009 | Zenith D52WLCD 52" Rear Projection...
Hdtv rca
You need a new lamp. Your lamp have been blown. You can purchase the lamp from rca or other vendors on the net or you local tv store and you can also install it yourself. The lamp is usually located in the back of the tv on the side of the protruding back. Next time you do install your brand new lamp, when shutting down your tv wait for your fan to shut off before disconnecting the power cord. Doing so will shortened you lamp life.
Dec 28, 2008 | JVC HD-52G786 52" Rear Projection HDTV
RCA 52'
You could have a tube leaking fluid out go back ck all the Tubes see if any of them has leaked anyfluid out on to boards. pull front bottom off of TV so you can see them . Let me know what you finded also second ribbon connector make sure it is in good.
Dec 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Won't turn on
those tvs will try 3 times before completely shutting down. you can try and take the back off and check CP150 it is a large capactior located near the middle of the board on the left hand side(looking from back) if it looks and feels like the top is vented or puffed out then that could be the problem. if not i suggest having a qualified service tech take a look because there are too many things that could be the root cause.
Apr 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" TV SHUTS DOWN AFTER A FEW MINUTES
this is the filment circuit having a problem. i think you will find it is a loose connection on a solder joint. Goodluck
Jan 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W56 52" Rear Projection HDTV Logo
147 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
