Question about Harman Kardon HK695 Computer Speakers
How to turn up the volume on computer - Harman Kardon HK695 Computer Speakers
Volume too loud when using DVD player
where is the DVD player? If it's on your computer, turn your computer volume down. If it connected to your TV, turn your TV volume down. If it's a portable, it should have a volume button.
Mar 06, 2015 | Televison & Video
Volume on monitor
Take it in and have it bench tested.
Terry
Dec 16, 2013 | BenQ FP Computers & Internet
The volume on my z313 I hook it up to my computer is to low
There should be a volume level adjustment on the speakers.
Verify the master volume on the computer is turned up as well as the volume of the app in use is turned up.
Oct 21, 2013 | Logitech Z 313 - 2.1-channel PC multimedia...
HOW TO VOLUME the speaker even if the volume is 100 already.why is it low?
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Volume problems on computers often happen for a variety of reasons.
Volume troubleshooting, however, is one of the easiest problems to troubleshoot because there are only a few things that usually cause the problems.
Usually the problem isn't even an error but just merely an adjustment that needs to be made.
Test your speakers.
This is the first thing you should check if you can't hear anything coming out of your computer. First try turning up the volume know and make sure you are in fact turning the volume knob and not a tone or balance knob.
Make sure the speakers are completely plugged in to the wall and the computer. Test with another set of speakers or headphones after you have done this.
Check the computer volume level.
On the taskbar is a volume icon, which usually looks like a small speaker.
Click on the icon and turn the volume up.
Make sure it has not been muted.
Double clicking on the icon will bring up a panel of several volume controls.
Try turning up the volume on each slider.
Go to Control Panel and choose "Sounds and Audio Devices."
Under the volume tab, click speaker volume and turn up the level if needed.
Turn up the application volume. Most programs that use sound have an additional volume control just for that program.
Find the volume control and turn it up.
Usually it is located in the lower right or left corner on the program, but you may have to search for it.
Troubleshoot the sound card.
Download the latest drivers from your sound card manufacturer's website.
Go to Control panel > System > Hardware > Device Manager. Click on "Sound, Video and Game Controllers."
Click on your sound card, select the driver tab and then click on "Update Driver."
Point to the file where you saved the latest drivers from the website.
After this, restart your computer.
The speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a can of compressed air or fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
If this doesn't solve your problem, try reseating the sound card into your computer.
Hop this helps
Nov 11, 2012 | Lenovo Computers & Internet
Volume loss
Laptop or Desktop ?
Try swapping the speakers around to see if the problem is in the speaker itself.
Test your speakers.
Hope this helps
Nov 10, 2012 | Audio Players & Recorders
I cannot turn up the volume on my monitor
The Samsung B2030 LCD Monitor has no speakers, you cannot turn the volume up on it. Instead turn the volume up on the speakers, or on the computer itself.
Aug 26, 2011 | Samsung B2030 LCD Monitor
How do you turn up the volume? It only goes down.
To the best of my knowledge volume control on LCD monitors is controlled by the device that it is hooked up to. You probably have an 1/8" headphone type cable plugged into the back of it which runs down to your computer and is plugged into the Line Out / Speaker jack. So when you turn up the volume on the computer it should turn up the volume to the speakers in the LCD Screen. Let me know if you need more help, and if this fixed your problem please mark this as solved. Thanks.
Jun 30, 2011 | ASUS LCD Monitor
Volume button
go to start menu -> control panel -> sound and audio devices. you will find volume control. or another method is just click on the volume icon which is located at the right bottom of your windows desktop.
Jun 20, 2008 | Computers & Internet
Computer Speakers
Try turning the volume on the computer volume control up and turn the volume control on the speakers down, or try the other way, turn the volume control on your speakers up, and the volume control on the computer down. I've had this problem before and this was the way I found a resolution.
Jan 05, 2008 | Audio Players & Recorders
Harman Kardon HK695 Computer Speakers Logo
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
