Question about Ovens
Kenmore electric built-in oven control panel beeping
Kenmore built-in-electric oven: I first got an F7 error code and beeping. Turned off unit at breaker for 2hours then turned back on. Was able to set clock, but now it beeps and telling me to push start oven when oven not selected. Pushed clear but that's not helping still tells me to push start. So, I pushed start waited a few seconds, then pushed clear. It still is asking me to push start and beeps. What can I do or am I at the mercy of a repairman and at least a $100.00 bill?
  • 5 more comments
  • Anonymous Nov 20, 2007
    error code f7 and beeping.
  • mcac Dec 13, 2007
    we have a f7 flashing and a beeping noise, when we push clear it goes away for 1 minute then starts again
  • MOSESCAT Dec 16, 2007
    HAVE THE SAME PROBLEM. THIS IS THE SECOND TIME. THE FIRST
    TIME COST US 60.00 FOR REPAIR. THIS TIME, THE F7 HAS LOCKED
    UP THE ENTIRE PANEL.
  • MMarqu Jun 05, 2008
    It is 9 PM and I got the F-7 and beeping. I couldn't clear it so just pulled the fuse for tonight.
  • Anonymous Jul 17, 2008
    Mine isn't a double oven but I'm having the same problem being described with my GE electric oven. First it will ask me to 'push' (I assume start) '350 degrees' when I haven't selected it. About a minute after pushing clear/off to stop the beeping, F7 appears with more beeping. The only button that will work at all is clear/off. I've tried to turn off the breaker, but was unable to find it (I'm renting and it's a weird house) and I am unable to find where it is plugged in...so I don't get relief from this.
  • Anonymous Jul 30, 2008
    F7 signal on, and beeping
  • dale emerson Feb 20, 2009
    my maytag oven is 8 years old, this is 2nd time F7 error has occured. clock assembly as well ]as entire touch pad were replaced in or about 2006
    Scholar:
  • 30 Answers
There is a probelm with the control panel ribbon. You can fix it for about a penny. The panel has a printed ribbon cable that plugs into the relay board. The ribbon cable is actually two cables pressed together, which can be seperated by simply lifting them apart. The ribbon cable has a defect in that the plasic insulation is defective, causing the leads between the two ribbons to cross, or short circuit. Simply place a thin sheet of paper between them, and make sure you push the paper down all of the way to the plastic housing, fold over the edges around the cable, you are done.
Posted on Nov 08, 2009
  • peterfilleul Dec 27, 2010
    Thanks turbo (and others), 27th December 2010
    Had the old 'F7 and beeping' routine on a pretty old Kenmore single oven in Montserrat in the West Indies - no chance of a maintenance guy call out here - so followed the three screw removal, insulating with a strip of paper between the ribbon cable elements suggestions and (Bob's your uncle) it's back to life accepting clock and temperature instructions. Thanks chaps for the useful guidance.
    Peter
We had the same problem. F7 error code and beeping. We turned off at the breaker- left it off for hours turned it back on and still f7 and beeping. We call repairman to come out and he removed the cover on control panel (3 screws on bottom of controll panel and it pops off). He unplugged the ribbon keypad connection - Cleaned the ends with a pencil eraser and said it is fixed and we would not have a problem.
Well, that was a fast way to spend 60 bucks but it has been a week and the oven has been great. No more beeps or error codes. SAVE YOUR MONEY DO IT YOURSELF!
Posted on Mar 28, 2009
Kenmore gas oven with electric ignighter doe not work ,the is no gas going there
Posted on Sep 04, 2009
On my Kenmore built in electric oven the digital lights are dimmed out. Is there someway to fix this without replacing the whole control panel? The replacement panel costs $387.
Posted on Jan 23, 2010
2 Suggested Answers
  • 30 Answers
SOURCE: kenmore electric built-in oven control panel beeping
Try this first!
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. If that does not work, repalce the defective parts yourself. You can do it for about 30% of what a repair company would charge. it's either got to be 1. Control panel 2. Relay panel. Good luck!!!
What do I do about oven beeping?
Could be control module, but not sure. I had issues with a code a long time ago, and the broiler kept coming on and wouldn't shut off, so finally had to shut it off at the breaker. Turns out the control module is fried. But just a thought.
Apr 28, 2015 | Kenmore Double 27" Electric Built-in Wall...
F76 error code on ge oven
One of the most common problems with GE electric built in ovens is the error code "F7? shown on the display. I've seen it many times before and today I had a service call for the same problem again. The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic Range Control) or "clock" senses one or more buttons on the control panel stuck. It could be displayed in any mode: "cook", "clean" or even more often in the "time of the day" mode. In order to fix it, the control panel has to be replaced. This is a very simple job and you will need just a 1/4? nut driver and a Phillips screwdriver. - See more at: http://www.askgene.com/2007/06/23/oven-error-codes/ge-oven-error-code-f7-and-how-to-fix-it/#sthash.pVUT3Nzb.dpuf
Oct 14, 2013 | GE Ovens
My oven beeps and show error code F7 on the panel. Help!!!
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | GE 27" Built-In Double Electric Convection...
''F7'' Error Code
HI. This is the result of a failed function key. This is an integrated part of the main control board. Unfortunately, this is not repairable, and the main control board will need to be replaced, asap.
Dec 20, 2009 | Kenmore Ovens
Kenmore electric built-in oven model 911.47702201 just started showing 2 error codes and beeping. F7 is in red and on the left side of the display, E8 is in green and flashing and is on the right side of...
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. Good luck!!!
Nov 04, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
The F7 code appears with a beeping noise. How do I turn off the beep for good.... selecting clear/off only works for a few seconds
Well, F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Thanks
May 27, 2009 | GE Built-In 24" Double Electric Wall Oven
Oven shows F7 error problem with irritating beeping sound
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
May 13, 2009 | GE Profile JKP56 Electric Double Oven
Error code f7 on Kenmore wall oven 911.41165791
Try this first!
Apr 07, 2009 | Kenmore Ovens
Kenmore double-oven (electric)
F7 stuck keypad
Sep 22, 2008 | Kenmore 47722 / 47724 / 47729 Electric...
Try this first!
Aug 08, 2008 | Kenmore 42161 / 42169 Electric Single Oven
Ovens Logo
1,355 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
