Question about Philips 190B6CB/27 19" LCD
Philips 190b Monitor
Had this monitor for around 3-4 years. The problem is that it keeps 'shutting off'. The power light is still green but there is no image at all and if I turn it off then on again it will be ok for between 3 secs to 10 mins. I have all power options set at 'never turn off', the power supply should be fine, all plugs in properly etc. Is this just old age & time for a new one?
    New Friend:
You probably have a bad power capacitor/ bloated power capacitor. You can replace them if you are good with a soldering iron.
Posted on Jul 13, 2012
  • alex205
    alex205 Jul 13, 2012
    Scholar:
  • 113 Answers
Yes, i am in the industry and their average age is 5years, after that expect retirment... sorry :(
Posted on Oct 09, 2007
SOURCE:
How to increase contrast 190B
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps you
Oct 25, 2011 | Philips 190B4CG (Gray) 19" LCD Monitor
190b Philips monitor and the volume bar keeps popping up
change task bar properties...otherwise intall monitor software cd..
Mar 13, 2010 | Philips 190B6CB/27 19" LCD
Monitor is blank. Green power light is on steady.
Self test failed means Monitor is bad.
Check input settings, whether DVI mode is selected.
Dell Monitor has 3 year warranty by default, Contact Dell Techncial support
Jan 13, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Cannot remove the Brightness window that pops up on my Philips 190B monitor.
Press and hold the menu button for 30 seconds
If it doesnt work call your H/w vendor
Aug 27, 2009 | Philips Computers & Internet
I have a monitor HANNS-G It worked 3 years. And exactly after 3 years warrant policy ended my monitor got a problem. It looks like there is a problem in power connection on front buttons. After I connect a...
This is a problem with the power supply unit inside the monitor, there is no easy way out here. If you keep on using your monitor like this eventually it won't switch on no matter how long you wait. Keep on using it like this for the time being without switching off anything but ultimately you will have to take it in for repairs or otherwise purchase a new screen..
Aug 02, 2009 | Microsoft HannsG HU171D 17" LCD Monitor
Philips 190B - flickering screen
Its looks that Inverter board not work well for CCFL cus a CCFL inverter is a device (an inverter) for providing drive power to a Cold Cathode Fluorescent Lamp CCFL
Jun 17, 2009 | Philips 190B6CB/27 19" LCD
E173FP monitor fix
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mark
Mar 25, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Monitor won't turn on without help.
Do you have a second monitor or can you borrow one to check if the fault lies with the monitor or the PC?
If the monitor is at fault then there is not much you can do yourself. I suggest you contact Dell and get them to replace it under warranty. Most LCD monitors have a 3 year warrantly, at least they do in the UK.
cheers
Aug 04, 2008 | Dell E177FP LCD Monitor
Philips 190B6CB/27 19" LCD Logo
1,121 people viewed this question
Top Philips Computers & Internet Experts
Ekse
Herb Box
Herb Box
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
