Question about Home
Bathtub wall was cut short and is leaking to downstairs when we take showers
The wall of my bathtub was cut too short when installed and water leaks to downstairs if it gets into the space between the tub and the wall my father has tried caulking and even gorilla gluing these white strips there but it still leaves a space how can i fix it my mom just had surgery on her hand and sitting to take a bath is not an option because she can not lift herself up
    Master:
  • 274 Answers
Fill the space with liquid foam filler made for water areas. this will seal and fill the space, keep it below the surface as it does expand and will go above the tubs line. let it dry the recommended time and cut off the excess with a razor blade. once that's done then you can caulk normally to hide the foam.
Posted on Nov 21, 2013
4 Suggested Answers
  • 62 Answers
SOURCE: Lasco whirlpool tub leaks. Water runs out on
Sorry, the tub will have to pulled out to find out what is leaking so it can be fixed. There is just no other way UNLESS you can open up the wall on the blind side of the tube. (but its probably and exterior wall...if the house is vinyl sided, it can be done. If brick, you'll have to pull the tub). If you just wanted to convert to a tub only, maybe Bathfitters has an insert solution...
Posted on Jul 11, 2009
  • 67 Answers
SOURCE: We are ready to install
The gasket is installed on the outside of the tub. Use plumbers putty under the male end on the inside of the tub as it stays permanantly flexible and will not mildew like silicone caulking can. Do not silicone or use plumbers putty on the gasket. The gasket will seal nicely under pressure from the connections.
Posted on Aug 03, 2010
SOURCE: Jetted bath tub has stopped working. Motor hums
I had this same problem on my tub, which uses a GE motor. I looked at the motor, and on one end (the end opposite where the water comes out) there is a hole in the middle. In that hole is the head of the shaft, which has a regular screw tip. Turning this turns the motor. I filled the tub, inserted a slotted regular screwdriver and turned it about 10 times clockwise, then 10 times counterclockwise. You should see the whole motor turn. Doing this loosened it up, and then it started.
Once it started, all kinds or residue came out, which was probably why it had stopped working. I hadn't used it for a while.
After getting it running I'm going to run some cleaning solution through it, and make sure I run it more often to prevent this in the future.
I'm not a professional, just a guy trying to fix his own tub. So take my advise with that grain of salt.
Posted on Nov 24, 2010
Water leaking below shower
You may have a very small access panel on the front of the shower pan or through an access point in a cabinet on the backside of the shower wall. I have seen the shower tail piece get cut too short and as a result is becomes disconnected from the "P" trap under the shower.
Apr 04, 2014 | Dutchmen 2010 Grand Junction 345RE
The wall of my bathtub was cut too short and water leaks to downstairs how can i fix it
fill the space with liquid foam filler made for water areas. this will seal and fill the space, keep it below the surface as it does expand and will go above the tubs line. let it dry the recomended time and cut off the excess with a razor blade. once thats done then you can caulk normally to hide the foam.
Nov 21, 2013 | Home
I replaced an Moen spout for my shower unit. Water flows thru the Spout and when level is pulled water flows thru the shower head. But there is water leak somewhere (reverse flow?). The ceiling below it...
if you have copper piping,you probably twisted the pipe when,you tightened the spout ,and broke pipe. If you are'nt able to get into the wall on the shower side, cut a hole on the other side of shower wall to repair it.
Aug 04, 2011 | Garden
My moen tub faucent leaks when i have t shower head on
If you are saying that water is still coming out of the tub spout while the shower is on that is not a big deal a rather normal. If it bothers you a lot then you will need to replace the tub spout as the diverter in the spout has gone bad or is going bad.
Now if you are saying that the shower is leaking behind the wall when the shower head is being used then the threaded joint at the shower head arm is leaking and will need to be undone and put new pipe dope on the threads and reinstall it or it may be just lose and if that is the case remove it and reinstall it anyway.
If the water is leaking behind the wall and the above is not the case you will need to get into the wall and see where the leak is coming from and take the necessary steps to fix it.
Hope this helps and good luck.
Feb 06, 2011 | Home
50 year old ranch home. Bathtub has hot and cold faucets and lift diverter for shower. Shower has rarely been used in this room, but recently guest tried using the shower, causing a literal...
when the water diverter is used it leaks, the problem is the pipe that runs up to the shower head is either rusted trough , not connected or not even there. You will need to cut an access panel in the back of the wall and inspect the plumbing, unless there is one already there. I am guessing that even if you replace everything it should not be more the $100. The cheapest place to purchase your items would be on eBay, of course if you can't wait Wal-Mart carriers what you need. Good Luck Tim
Jan 06, 2011 | Home
I have a Moen shower faucet that is six years old(copper sweated plumbing). My wife noticed water dripping profusely from the downstairs ceiling during my shower. The screws holding the face plate were...
Try removing the handle, then the face plate. With a flashlight handy, check inside the wall around the valve to see if you see any leaks. Then, try the valve by pulling the stem (may need a plier to grab this). Keep checking inside the wall. Next, try the shower, and again watch in the hole you have. You may find that the connection(s) to the valve is/are leaking, particularly at the top of the valve where the shower pipe heads up the wall. Or, it may be that the shower head's arm is leaking somewhere above. If you only see water dripping down from above, try the flashlight with a small make-up mirror to see if you can see where it's coming from. Sometimes the pressure in the shower head builds up from the flow restrictor, or the head's spray holes may need cleaning out (try soaking the head in a solution of CLR [stands for Calcium, Lime, Rust] available at most home improvement/ hardware stores). Sometimes the shower arm (the bent 1/2" diameter pipe that the shower head mounts to) isn't fastened in tightly enough. A good trick to help here is to wrap the threads with teflon tape, then apply teflon paste also. Wrap the tape clockwise around the threads so that it doesn't unwrap when you screw the pipe back into the fitting in the wall. Also, make sure the threads in the fitting in the wall are cleaned out, and don't let any debris contaminate the new teflon paste as you slip it back through the hole in the wall. If you find that the pipe out of the top of the valve is leaking, I recommend you call the plumber. He/she can likely fix it without taking the wall apart.
Aug 27, 2010 | Moen & One Handle Tub & Shower Faucet
Leaking form shower facet also leaking from
id say your tub spout or shower pipe is leaking and running down behind remove both and replace teflon tape see if it stops
Mar 14, 2010 | Home
Bathtub drain leaking
Since two plumbers have tried and failed, I'm assuming that the problem is none of the obvious ones. I have two ideas for you, the second being the most effort, but also the most likely.
(1) If you have ceramic tile on the walls around the tub, sometimes cracks between the tiles will develop or the grout itself will develop leaks (become very porous). This would not necessarily show visible cracks, but could appear to be a drain problem since it will only leak during/after use. For this, you would need to patch the grout where needed and seal it well.
(2) You may have a leak in the piping under the tub. Since you mention a light fixture downstairs under it, it is likely that you can "create" access to the piping. This would require cutting a section of drywall out immediately under the drain and approaching the light fixture, about a foot wide should be enough to give you a decent look. Cut the drywall carefully so you can use the same piece to close the hole, with a little spackle, when you are done. Once open, turn on the water and watch to see where the leak is coming from. At that point you (or a plumber) should be able to identify what to do.
If your older house is "really" older and you have plaster instead of drywall, do the same thing, except you obviuously can't use the old plaster to fix the hole when you are done.
Jun 26, 2009 | Lefroy Brooks Bath Waste Trap for Exposed...
Water is leaking from my downstairs air conditioning vent
I seriously doubt it's the AC. It may be the draing in the upstairs shower, If it's a water line it is a very small leak and is probably puddling in you ceiling. if not nbeing absorbed. Best thing is contact your homeowners insurance because you are going to not only have a plumber to deal with , but a mols issue as well. Sorry, good luck.
May 31, 2009 | Heating & Cooling
Walk in shower leak into room below
I would unscrew shower head pipe and either pipe dope it or tefilon the threads and then reinstall it. I would also take the handle(s) rosettes off and look for a leak from there with a flashlight, while shower is on. I believe the most comon leak for walk in showers are the door seals. Are you sure it is not coming out from under the door? Another test that yuo may want to preform is to Stopper the drain, fill the shower pan with water and watch for bubbles, or look for leaks from below.
Mar 20, 2009 | Home
Home Logo
49 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
