Question about Home
The wall of my bathtub was cut too short and water leaks to downstairs how can i fix it
The wall of my bathtub was cut too short when installed and water leaks to downstairs if it gets into the space between the tub and the wall my father has tried caulking and even gorilla gluing these white strips there but it still leaves a space how can i fix it my mom just had surgery on her hand and sitting to take a bath is not an option because she can not lift herself up
    Master:
  • 274 Answers
Fill the space with liquid foam filler made for water areas. this will seal and fill the space, keep it below the surface as it does expand and will go above the tubs line. let it dry the recomended time and cut off the excess with a razor blade. once thats done then you can caulk normally to hide the foam.
Posted on Nov 21, 2013
  • 19 Answers
SOURCE: Bathtub caulk turning dark color in spots?
Ibelieve it is mold and the best thing to do unfortunately is re caulk it but use amold resistant caulking(kitchen and bath dap)
Posted on Feb 02, 2009
  • 150 Answers
SOURCE: install bathtub without existing drain
it is generally not allowed under the water regs to discharge waste water into anything other than a drain.I would suggest you install a discharge pump, typically the saniflow type which will allow you to run the waste across the room and discharge the waste into the vanity basin drainage.Should you choose to install this be aware of the waste pipe configurations shown by the instructions
Posted on Mar 20, 2009
  • 63 Answers
SOURCE: bathtub whirlpool leaks. problem is that the tub
Stop leak in a bottle absolutely does not work, look closely there should be some sort of access panel (maybe well hidden) to get under there.
Posted on Mar 24, 2009
  • 62 Answers
SOURCE: Lasco whirlpool tub leaks. Water runs out on
Sorry, the tub will have to pulled out to find out what is leaking so it can be fixed. There is just no other way UNLESS you can open up the wall on the blind side of the tube. (but its probably and exterior wall...if the house is vinyl sided, it can be done. If brick, you'll have to pull the tub). If you just wanted to convert to a tub only, maybe Bathfitters has an insert solution...
Posted on Jul 11, 2009
  • 67 Answers
SOURCE: We are ready to install
The gasket is installed on the outside of the tub. Use plumbers putty under the male end on the inside of the tub as it stays permanantly flexible and will not mildew like silicone caulking can. Do not silicone or use plumbers putty on the gasket. The gasket will seal nicely under pressure from the connections.
Posted on Aug 03, 2010
Replacing jet
When you installed the new jet, did you install a new gasket on the wall fitting or use 100% RTF type silicone?
In order to seal a wall fitting that is cracked an leaking, the replacement must have either the gasket or silicone to seal the wall fitting against the wall of the tub or it will leak when filled with water.
Rod
U S Parts Center
Jan 03, 2014 | Jacuzzi Home
Bathtub wall was cut short and is leaking to downstairs when we take showers
Fill the space with liquid foam filler made for water areas. this will seal and fill the space, keep it below the surface as it does expand and will go above the tubs line. let it dry the recommended time and cut off the excess with a razor blade. once that's done then you can caulk normally to hide the foam.
Nov 21, 2013 | Home
The shower pan came with no installation instruction, it looked so well designed that I thought it would easily drain fully by just putting it in place. However since I have know completed the project I...
sounds like you will have to remove the tile and shower pan. The pan needs to be level along all walls. Use a level. I had to cut wood shims to support the pan and keep it level before screwing it to the side walls
Mar 11, 2011 | Home
I have a Jacuzzi brand bathtub/whirlpool 6 years old. One of my jets leaked and created a significant damage downstairs. How can I fix the jet, how can I prevent other jets from leaking? Can I just kill...
The gasket around the jet may be leaking because it is deteriorating or the flange nut on the outer side of the jet has loosened up. Check all jets for loose hardware.
Sep 12, 2010 | Jacuzzi Home
The bathtub drain pipe [below the tub] is cracked is there any easy fix without removing tub, etc  it maybe could be reached by cutting out part of the adjacent wall otherwise, the water spills onto...
You can do all your fixin underneath where you say it is leaking on the slab if there is room for you to crawl under why remove the tube, more trouble than it is worth.
Jul 18, 2010 | Home
WE ARE NOT RUNING THE WATER AND IT SOUNDS LIKE SOME ONE IS RUNNING WATER MY GAS BILL IS $150.00
well that can be a problem the first thing you have to do is check for water leaks under the house or between the walls that can be one of the reasons why the heater is emptying so often, I can tell you that one time I had to fix a problem like that the guy was paying a lot in gas and the water line behind his bathroom sink (between the wall) was punctured a tiny hole but it was constant so he had to pay me to fix the leak and the roof and the walls on the apartment downstairs.
So most likely there is leak somewhere in your water line inside the house; before you pay a plumber try to find it yourself (so you don't have to pay for his time) if you do find it then call the plumber to fix it and check again.
if it works for you don't forget to rate me
thx
May 16, 2010 | General Electric GE SmartWater Household...
Jul 11, 2009 | Whirlpool Lasco 7460621R Dossi-32 , White
Bathtub drain leaking
Since two plumbers have tried and failed, I'm assuming that the problem is none of the obvious ones. I have two ideas for you, the second being the most effort, but also the most likely.
(1) If you have ceramic tile on the walls around the tub, sometimes cracks between the tiles will develop or the grout itself will develop leaks (become very porous). This would not necessarily show visible cracks, but could appear to be a drain problem since it will only leak during/after use. For this, you would need to patch the grout where needed and seal it well.
(2) You may have a leak in the piping under the tub. Since you mention a light fixture downstairs under it, it is likely that you can "create" access to the piping. This would require cutting a section of drywall out immediately under the drain and approaching the light fixture, about a foot wide should be enough to give you a decent look. Cut the drywall carefully so you can use the same piece to close the hole, with a little spackle, when you are done. Once open, turn on the water and watch to see where the leak is coming from. At that point you (or a plumber) should be able to identify what to do.
If your older house is "really" older and you have plaster instead of drywall, do the same thing, except you obviuously can't use the old plaster to fix the hole when you are done.
Jun 26, 2009 | Lefroy Brooks Bath Waste Trap for Exposed...
Bathtub whirlpool leaks. problem is that the tub
Mar 24, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
How do you caulk a bathtub?
First, use a utility knife to remove as much old caulk as possible. Buy caulk(and caulk gun) that is WATER based, DO NOT buy silicone. Cut the tip for about a 1/8 inch hole. Do one wall at a time. Start on a short wall and squirt a bead as best you can. Use your finger to pack it in then wipe it with a wet but well wringed out old t-shirt until your happy with how it looks. Repeat on other walls. John
Please Rate this solution!
Mar 15, 2009 | Whirlpool Home
Home Logo
44 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
