Question about NetGear WG111T 802.11g/b (E82321) Wireless Adapter
NETGEAR WG111T 108 MBPS WIRELESS USB 2.0 ADAPTER
I recieved above netgear wireless router from aol and was directed to buy an adapter - AOL suggested netgear WG111v2. I could not find this in PC World. So I bought the above adaptor. During set up I succeeded in completing Step 1 i.e. setting up the router. When I came to set up the adapter I did everything right but the system (Windows XP)could not pick up the adapter. After a point it started going round and round in circles asking me alternately to connect and disconnect the yellow ethernet cable. It would not get beyond this point. I have spoken to both NETGEAR and AOL each of whom asked me to contact the other. I don't know what else to do. Can you help please.
  • 1 more comment
  • snowpony Feb 21, 2008
    I have the exact same problem. Did anyone find a solution? So much for being 'wireless' in minutes. :-(
  • Anonymous Jan 04, 2009
    I have had the same problem, took the wg111t back & got a wg111 v3 but still wont work any clues
    i have had the same problem , took the wg111t back & got a wg111 v3 but still wont work
Configure router via ethernet cable in first instance. Then install adapter. May need to hange MTU for AOL as ISP.
Posted on Aug 12, 2008
SOURCE:
Netgear wireless adapter wg111t will not work work
It's impossible that the wireless router cannot detect your wireless adapter wg111t.
You try to test another one if still have a problem connecting with your wireless router.
If that router can see another wireless network available then maybe your Netgear wireless adapter have a problem incomplete installation or the wireless device is defective.
I have encounter like this before so maybe it's the same with.
Hope my tip will help you a lot.
Please rate me.
Thank you.
Sep 14, 2009 | NetGear WG111T 108 Mbps 802.11g Wireless...
My computer freezes when connecting WIFI adapter
Does this happen if you try connecting it into all USB ports? Try another USB port. Do you know if your USB ports are 2.0?
Mar 30, 2009 | NetGear WG111T 108 Mbps 802.11g Wireless...
Change channel router netgear for windows vista laptop for
It is hard to say without the netgear model and version, yet the concept is the same, open your web browser, type the ip address of the netgear in the address bar (you will need a password), then look for a menu regarding wireless or wlan or advance wireless configuration, and there you will see an option about channel selecction, just change it to match your laptop channel.
good luck.
Mar 28, 2009 | NetGear WG111T 108 Mbps 802.11g Wireless...
Cannot connect to wirless with adapter on new computer
Although this model appears to support Windows Vista according to the manual for it (ftp://downloads.netgear.com/files/WG111T_UM_04Feb07.pdf) the 64 bit version is not mentioned and, therefore, probably not supported. I'd take the wireless adapter back and find one that supports Vista 64 for certain. Some do.
Mar 27, 2009 | NetGear WG111T 108 Mbps 802.11g Wireless...
I have a wireless netgear usb adapter and nothing else, its not installed on my computer and I want to put it on, it wont work, what do i need to get my usb wireless adapter to work??? It is a wg111t...
You first need to install the driver. You can download it here:
http://kbserver.netgear.com/products/wg111t.asp (it should have came with your adaptor)
You must also have a wireless router available for this to work, or in an area that has WiFi available.
Jul 17, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear 108 Mbps wireless usb 2.0 adapter wg111t
i had the same problem. i tryed downloading the sofware from other computer and install it on the wireless computer. finally i just connected it directly to a lan line and update drivers with windows
Apr 08, 2008 | NetGear WG111T 108 Mbps 802.11g Wireless...
Netgear Wireless USB Adapter wg111t; installation
Hey there Kjantzi, I have found the site for Netgear, and as I read it the update is one of the options but the drivers and firmware are there as well. Check here:
http://kbserver.netgear.com/products/WG111T.asp
Choose the version for your OS on the left, and it gives you detailed instructions, including the update process, if needed. If you still have problems let me know. Good Luck!
Mar 27, 2008 | NetGear WG111T 108 Mbps 802.11g Wireless...
Wg111t wire network
run cmd ( windoowsxp) then type ipconfig you should see an address like 192.168.2.3 if not goto network conections and view all goto wireless connection -properties then tcip set for auto config and then ok make sure your router is set for WEP sercurity type in a ten digit hex code ( 28 34 f6 a7 c3) and then save . rescan for your network then log on make sure you have GOOD signal strentgh . the wg111t does not work well with belkin routers.
Dec 25, 2007 | NetGear WG111T 108 Mbps 802.11g Wireless...
NetGear WG111T 802.11g/b (E82321) Wireless Adapter Logo
171 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
