Question about HP PSC 1410v All-in-One Printer
Printer cartridges I put new cartridges in and the printer still will not accept them? It keeps saying print cartridge error!
  • 2 more comments
  • joaopt Nov 17, 2007
    I've also tried to replace the black cartdrigde twice and it pops up the same error. With the empty one I have no problems.
  • Erina1216 Nov 22, 2007
    I also have the same problem! I have wasted so many cartridges thinking that was the problem. I can still scan, but not print...
  • Anonymous May 22, 2008
    I have the same problem. There is nothing on the cartridge and they are snapped in place. I just keep getting the same error messages. I have replaced the cartridge several times and done every suggested trouble shooting thing from HP.
  • foxylady62 Jun 02, 2008
    it keeps telling me my cartidges are not in place. I have tried everything. I have shut the computer down and taken the leads out of the printer too. Still the same when i turn on again. Cartridge light (orange) keeps blinking all the time.
  • 35 Answers
Are you trying to use brand new HP cartridges? If you are using an off brand cartridge (even if it says it will work with an HP printer) these do NOT always work. If they are HP brand then you might not be removing the plastic from them all the way (check for plastic covering the metal contacts on the bottom and the back of the cartridge which could be imparing contact). Also, make sure you are seating them properly. Some cartridges require you push them firmly into place. It shouldn't take a LOT of force to do so, but it would require more then just sliding it into place.
Posted on May 09, 2008
Both lights on printer flashing
If you set to black and wite it should also print pictures by the way, it does not accept grayscale because it won't be able to print in grayscale photo quality.
Aug 20, 2008 | Canon PIXMA iP1600 Printer
The steps below should help you override the error and make the printer accept the cartridges and allow you to print.
    • 1
      Remove and replace the print cartridge. If that doesn't solve the error, move on to Step 2.
    • 2
      Remove the print cartridge from the machine.
      • 3
        Wet the end of a cotton swab with rubbing alcohol.
      • 4
        Wipe the copper colored contacts on the print cartridge with the cotton swab to clean.
      • 5
        Wipe the contacts in the printer where the cartridge sits.
      • 6
        Replace the cartridge and try a test print. If removing residue for a clean connection didn't solve the error, move on to step 7.
      • 7
        Turn off the printer.
      • 8
        Unplug the printer from the power source and leave it unplugged for 15 to 30 minutes. This will reset the printer.
      • 9
        Plug the printer back into the power source and turn it on.
      • 10
        Print a test page.
    May 20, 2012 | Lexmark X1240 All-In-One InkJet Printer
    Just put in a new black cartridge and it wont print anything. Keeps saying alignment problem and prints a bunch of tourquoise designs in stripes. got the alignment note to go away but still nothing on...
    It could be that one of your cartridges are not seated well in the carrier or one of your cartridges are faulty or just needs cleaning:
    1. Open the printer cover.
    2. Remove both cartridges from the printer.
    3. Close the printer cover.
    4. Unplug and re-plug the printer into the power source to reset it.
    5. When the printer turns on, re-insert one cartridge first. Close the cover.
    6. Check for any errors.
    7. If no error appears, re-insert the other cartridge.
    8. Replace whichever cartridge is causing the error to appear. Or you could also insert a different known working cartridge to determine if the other is faulty.
    Jul 27, 2011 | Lexmark X5470 All-In-One InkJet Printer
    Printer says to insert black print cartridge in right stall
    Refer to printer manual as some of them require you to reset the software to accept new cartridge.
    Manual here if you do not have one
    Dec 03, 2009 | HP Officejet 7210 All-In-One InkJet...
    Put new cartridge in but error light keeps coming on even after reboot how do i fix this?
    Remove the cartridge and put it in again.
    If it has a reset button, push that.
    If you have "refilled" your cartridge the answers will be different. Did you?
    Sep 25, 2009 | Canon Pixma iP2600 Photo InkJet Printer
    Printer keeps showing : Press enter to align cartridges. After doing this it then prints out an alignment page and shows: Alignment failed please: Press enter Alignment failed. This goes on and on. I have...
    I have found that if I put in an old aligned page the printer reads it as and the alignment is accepted. As for the cancelled message being in the window, I have had this problem too. I've ignored it and selected the copy button and it took the command. The only problem with hitting cancel is that you cannot turn off your printer. Every time you do you have to repeat the aligning and cancellation process.
    May 02, 2009 | HP Officejet 5610 All-In-One InkJet...
    Hp psc 1410 printer error message
    I fixed the problem I was having by re-installing the program, which then told me exactly what the problem was. It was the color cartridge.
    I then put a new cartridge in and it worked!
    Jan 29, 2009 | HP PSC 1410 All-In-One InkJet Printer
    whats your printer model?clean the catridge contacts and the print head insert it again properly then switch off and on,do a hard reset from the menu button ,and make sure your using a genuine catridge most especially if your printer is hp product.that should work
    Aug 23, 2008 | HP OfficeJet 6310 All-in-One Printer...
    Refilled Cartridge
    How can I Reset Memory For Lexmark X4550
    Feb 14, 2008 | Lexmark X5150 All-In-One InkJet Printer
    HP PSC 1410v All-in-One Printer Logo
    Ben Johnson
