Question about Bosch Axxis WFL 2060 Front Load Washer
The machine does not drain after full cycle. (40 degrees, short program) If you set the machine to drain mode you only hear a weak whining noise. There is water remaining inside after the cyle
  • MUGOGU Oct 22, 2007
    Yes, I called the repairman in and he replaced the pump. That was it. Everything is fine now. It cost me 50 dollars though.
Mugogu, I have the same problem.  did you ever resolve the issue?  Thx String
Posted on Oct 22, 2007
  • Anonymous Oct 22, 2007
    this is String again.  i was able to resolve my problem.  Refer to page 21 of the manual.  If you have not already...drain the water using the drain hose located behind the cover panel (lower right side when facing the machine) removed the pump camp and check for debris that may be interfering with the impeller.  I found a paper clip jamming mine up.  Once I removed it the drain function seems to be working again.
SOURCE:
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Roper washing machine whines intermittently throughout the entire wash, rinse and drain cycle.
Roper whining noise Washing Machines Questions ... - Fixya
www.fixya.com > Forum > Tags > whining noise > Washing Machines
Roper washing machines whining noise related questions and answers. Ask your Roper questions. Get free help from washing machine experts.
Sep 28, 2015 | Roper Washing Machines
Whining noise at speed 35/40 left front side wheel 2000 infinity qx4
Try driving at 35/40, so you can hear the noise, try swerving (just a little) to the left, if the noise goes away, when you swerve, you most likely have a bad wheel bearing on that side.
Feb 24, 2015 | Cars & Trucks
Why my AEG F55080vi stops after drain cycle (program beginning) and then it stops and I hear 2 beeps and 2 flash continuously?
Definitely, water drain time-out. Error code i20.
The pressure switch doesn't return to EMPTY (1-2) after two drain phases lasting 120 seconds.
Possible causes:
Drain circuit obstructed/blocked; drain pump
interrupted or jammed (foreign bodies); level
pressure switch blocked on FULL (1-3); hydraulic
circuit of pressure switch obstructed; wiring faulty;
circuit board faulty.
Thanks to your detailed description of failure I conclude that in drain phase (after starts drain pump) leaks water and causing a short circuit. I would thoroughly reviewed drain hydraulic circuit. If is alarm displayed and there is no water inside dishwasher then check heater and anti-interference suppressor.
Dado
Jul 12, 2014 | AEG Dishwashers
Washer making whining noise rinse cycle
Possibly a worn drive belt, or it needs tensioning.
Jan 06, 2018 | Whirlpool Ultimate Care II LSQ9549L Top...
E04 Error
E04 is a time out on the heating phase, to confirm this run a cold cycle, if the machine completes the cycle but sticks on any program above 40 degrees, best bet it's a faulty heating element.
Nov 27, 2011 | Bosch Washing Machines
During the spin cycles in the wash the machine makes a loud whining noise while spinning? As soon as the cycle is finished the problem goes away. Is this a faulty belt or what. Please help.
Either the belt or you transmission could be slipping and it making the belt work harder on a full load. Try running the spin cycle without water to see if you hear it. If you do then it is the belt, but if you only hear with water then it is your transmission.
Apr 18, 2011 | Frigidaire FEX831CS Top Load Stacked...
Homark dishwasher programs; ( Italian ?? )
just turn the timer around slowly and you will hear it start to drain
Dec 11, 2009 | Dishwashers
Whining on spin cycle
There could be something in the pump .If you can tip the machine back and remove the belt try to spin the pump pulley by hand if you hear the noise that's it if not call for service.
Jun 25, 2008 | Roper RAB2121KW Top Load Washer
Washer keeps stopping during any cycle
the humming noise could be from two sources and it is worth while doing a few simple checks first the drain pump is jammed with a foreign object. check nothing caught in the impellor second water not available - check taps turned on. also turn water off, undo fill hoses, put in a bucket and turn water back on try on drain or spin programs to check water drainage as well
Jun 19, 2007 | Tecnik TKL9260 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
77 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
