Question about LG Refrigerators
Temperature setting for lg refrigerator freezer
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Refrigerator won't cool. Freezer works fine!
Pierce, there was a service bullitin put out on this model. TDR-0010A-B. Had to do with normal freezer, warm fresh food compartment. Maytag issued a kit that included a new thermostat and damper assy. to solve this problem. Bullitin came out in 2002. If you are not having a defrost issue and all fans are running normal, I would call Maytag and inquire about the above posted bullitin, It may be covered. Catriver...post back.
Posted on Sep 04, 2006
  • 66 Answers
SOURCE: The Freezer freezes...and so does the Refrigerator!
your thromstae is bad
Posted on Feb 06, 2008
SOURCE: GE Profile Refrigerator PFS22SISBSS Bottom Freezer Temperature Indicators
I finally called GE about the non-working LED's and the temperature fluctuation. It's a known problem as many consumers have posted online. I called 800-386-1215 several times. What I found is I'd get different menu options nearly each time I called. The way I got to a 'helpful' human follows: Call above number; you will/may here a voice that states only 'for recalled appliances press 9' (may also have options for repair or parts) PRESS 0; next menu PRESS 5; you'll hear 'for less than 1 yr old press 1' and 'for more than 1 yr press 2'. In my case I pressed 2, then got a menu with 'for refrigerators PRESS 2'. Spoke to a woman who never denied that GE has a motherboard problem. She offered to provide a free motherboard but no labor. I asked (to be sure) if I would have to pay labor, she said yes or I could have $400 off a new crappy GE fridge. She said I would have to have a repairman come to diagnose the problem, then order the part and then come back to repair. I then said, 'You're telling me that I have to pay for TWO service calls to repair a known GE defect???? How much should I expect to pay for these TWO service calls???' She then asked me to hold, then came back on the line and told me that GE would pay the labor for the repair.
I also asked if GE was willing to do anything about the 25 cent door latch that cracked after 11 months (and is attached to the door gasket a $228.00 part) or the rusting wire freezer baskets and was told no. Hey, worth a try! The fact that they said no ensures that I will continue on my crusade to warn anyone who'll listen not to buy GE! Keep calling, after I got the right menu the wait was short the whole call was less than 15 minutes.
Posted on Sep 17, 2008
  • 531 Answers
SOURCE: Ge model PSC25MSTASS digital refrigerator setting
check for frost in the freezer back wall
Posted on Apr 01, 2009
What is the coldest temperature for lg refrigerators
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Jun 18, 2015 | LG Refrigerators
What temperature should freezer be set
Set at 0. That is the Fahrenheit setting equivalent to 32 degrees Celcius; the temperature at which matter freezes.
Sep 30, 2013 | LG LFC22740 Bottom Freezer French Door...
I have two door bottom freezer in my LG refrigerator...Freezer is defrosting its' contents..I lowered the temperature but it still persists...any solutions?
My bottom freezer LG is intermittently shutting down and thawing everything in the freezer (cooling stops in fridge part, too). $3,500 for a refrigerator that works only 18 months.
Mar 18, 2013 | LG Refrigerators
Bought a brand new LG bottom freezer fridge a couple of months ago. I like the refridgerator part to be cold, so we keep the fridge temp on 6 (1-7 are temp choices. 7 being the coldest). We had the freezer...
If designed as most combination units, one of the two controls influences the temperature directly, the other only determines how much of the generated cold air is allowed to enter the other compartment. The typical arrangement is that setting the freezer temperature determines how often often the compressor runs; the other diverts a portion of the cold air into the refrigerator side.
Using the common thermometer for cold temperatures (~$5 US), adjust the freezer temperature for 0 to -5 degrees F (the often recommended temp.), then the other control for the desired refrigerator temperature, suggested as 35-45 F. This is the most common practice.
If you cannot balance them the way you want, reverse the procedure, setting for refrigerator temp., then freezer.
Dec 13, 2010 | LG LBN22515 Bottom Freezer Refrigerator
LG LDC22720SW ECU reads 5-6-7 on freezer side
I have a similiar problem with my LG refrigerator. The freezer settings get stuck on 6 and 7, while the refrigerator side is showing nothing. Pushing the buttons to adjust the temperature does nothing. The whole time, my food is getting spoiled.
Jun 28, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Ie tube freeze
You may need to balance the distribution of cold air between the freezer and refrigerator section.
The temperature setting influences both and there is normally a control that lets you divide the cooling between the two compartments.
If you don't have one, get an inexpensive (<$5 US) refrigerator thermometer, normally a simple dial-type, and monitor your refrigerator temperature (maybe somewhere in the middle) overnight when not often opened, set the main control to get the temperature between 40-45 degrees F.
Then check the freezer temp.; it should be <10 degrees F (0 is better), then swap back to the fridge to correct the main setting.
Go back and forth until you have both compartments close to the mentioned ranges.
Jun 24, 2008 | LG LRSC26940ST 36" Side-by-Side...
Refrigerators Logo
90 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
