Question about Canon PIXMA Office Equipment & Supplies
ERROR E08 CANON PIXMA E500 - PIXMA Canon Office Equipment & Supplies
3 Suggested Answers
  • 56 Answers
SOURCE: e07, e08, e02, e15 error
Canon Pixma Mp258 Error Code and Possible Solution
P02 (Carriage error)
1.Make sure no foreign material stuck to the print head railway.
2.Clean and check the print head encoder strip cable (timing **** film or encoder strip is a white line on the back of the box set of ink lines may be missing or mess up the ink.P03 (Line feed error): an error in transmission line entering the line feed (LF) is a signal telling the printer to move to another line or a whole new line that would not otherwise have reached the end of the line.
1.Check wire print head position (timing **** disk film) on the side of the machine.
2.Check PCB logic board.
P05 (ASF sensor error) sensor for paper feed error.
1.Try to replace the following:
•ASF / PE sensor unit.
•Drive unit.
•PCB logic board.
P06 (Internal temperature error): caused by abnormal heat inside the printer.
P07 (Ink absorber full): the Ink Wastepad (sponge) inside the printer is full
1.Replace the wastepad inside the printer or install waste ink bin outside the printer
2.then Reset counter protection.
P08 (Print head temperature rise error): caused by thermal print head temperature exceeds a threshold.
1.Replace the new cartridge print head and / or change a new logic board.
P09 (EEPROM error): caused by corrupted or defective EEPROM chips of the printer.
1.Replace the logic board.
P15 (USB VBUS over current): caused by too much current, try removing the USB cable and then plugin again, if solve the error, try to replace with a new USB cable. If the error still exist replace the logic board.
P20 (Other hardware error): The failure of other hardware.
1.Try to replace the logic board.
P22 (Scanner error): a scanner malfunction.
1.try to change the scanner unit or change a the logic board.
E13 or E16: Ink has run out
1.Pressing the Stop / Reset button for 5 to 8 seconds until the led screen display number 1.
E04, E05, E14 or E15: Cartridge may not be installed properly
1.Reinstall the ink cartridge.
Posted on Jun 15, 2011
SOURCE: Help me Please ..!! i want to reset my Canon Pixma e500 series
hi folks. joana here....Please help me. I've encountered an error code with my canon e500 series namely P22. while trying to resolve it by print test, Error 5012 suddenly popped up.. I don't know what to do.. please help
Posted on Nov 25, 2012
How to resolve erreur code E000051-0000 whith canon ir 2800
the Canon E500 printer is one of the most advanced printer which is build upon the latest printing technology. The printer comes in medium-size device and is reasonably light weight of around 5.3 kg. The black plastic body has no sharp edges, and the design is fairly pleasant to appear. The trays of the Canon printer Pixma E500 are quite flexible to use according to Canon Pixma E500 Printer Supportprofessionals. Its glossy finished touched feature makes the printer most eye-striking among users. But here in this blog, we will be introducing you guys with various Canon Pixma E500 error codes that you need to know.
List of top Canon Pixma error E500 codes
Error code 1: Canon E500 Error Code E02 (E,0,2)
  • This error symbolizes that printer is out of paper or is incapable of feeding any document.
Error code 2: Canon E500 Error Code E03 (E,0,3)
  • This error signifies the Paper Jam.
Error code 3: Canon E500 Error Code E04 (E,0,4)
  • The error signifies that the "fine cartridge" is not installed accurately.
Error code 4: Canon E500 Error Code E06 (E,0,6)
  • As stated by Canon Pixma E500 Printer Technical Support experts, the paper output cover is not in a closed state.
Error code 5: Canon E500 Error Code E07 (E,0,7)
  • The ink absorber is complete and users need to reset the counter.
Error code 6: Canon E500 Error Code E08 (E,0,8)
  • Here the error signifies that the ink absorber is almost in a full stage. Users are then required to press the "black or color" button to resume it in a proper.
Error code 7: Canon E500 Error Code E16 (E,1,6)
  • The ink in completely finished as of now. You are required to tap on the "Stop/Reset" button to resume the printing process.
Error code 8: Canon E500 Error Code E17 (E,1,7)
  • The front tray is totally closed.
Error code 9: Canon E500 Error Code E30 (E,3,0)
  • The error code defines that the size of the original cannot be accurately detected or even it is possible that the document is too small when the "Fit-to-Page copying" is selected.
Error code 10: Canon E500 Error Code E31 (E,3,1)
  • The machine is surely disconnected with the computer.
Error code11: Canon E500 Error Code E40 (E,4,0)
  • It shows that the protective material of the Canon Pixma E500 printer for the FINE cartridge or the tape is still attached.
Error code 12: Canon E500 Error Code E50 (E,5,0)
  • Scanning of the print-head alignment sheet has failed to function
Error code 13: Canon E500 Error Code P02 (P,0,2).
  • This is a critical error which shows that the printer is in malfunctioning stage.
Error code 14: Canon E500 Error Code P10 (P,1,0).
  • This error signifies that the mechanical printer is in total malfunction stage.
So, these are few topmost errors of Canon Pixma E500 printer that users need to be aware of. Our professional team of Canon Pixma E500 Printer Support experts is always available for you to help overcome with any kind of unexpected issues. Call us or even you may drop us an email to our professional email ID.
May 16, 2015 | Canon IR-2800 Copier Reconditioned
Canon pixma e505
Assuming your using Windows 7.
http://www.downloads-drivers.com/2013/04/canon-pixma-e500-drivers-for-windows-7.html
Sep 21, 2014 | Canon PIXMA Office Equipment & Supplies
How to fix Canon pro9000 error E08 or iP2770 error 5B00
Your B500 is most likely a waste ink full message, so try this
http://ekohasans.blogspot.co.nz/2011/08/how-to-reset-canon-ip2770-error-5b00.html . You need to download a service tool and reset the waste ink levels, then dissable the machine to remove clean and replace the waste ink pads. You could get away with just doing the waste ink reset but beware ink overflowing from the base of the machine. The E08 error also seems to be a waste ink and may also need a service tool to reset.
Apr 26, 2014 | Canon Pixma Pro 9000 MARK II InkJet Photo...
Canon mp495 e08
INK ABSORB MOSTLY FULL RESET COUNTER
Mar 29, 2014 | Canon PIXMA MP495 InkJet Printer
Install print pixma e500
You can download the Canon printer drivers from their support WEB site. Please click on this link and select your model printer to download : - http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Nov 12, 2012 | Canon Pixma MP500 All-In-One InkJet...
Nov 04, 2012 | Office Equipment & Supplies
PRINTER E500 ERROR 5b02
How to solve error 5b02 on canon printer E500
Oct 15, 2012 | Canon Pixma MP480 All-In-One InkJet...
How to install canon pixma E500 without CD
HI how can i install e500 pixma without cd
Aug 20, 2012 | Office Equipment & Supplies
791 people viewed this question
old marine
old marine
