Question about EliteGroup NFORCE4-A939 (NFORCE4A93910) Motherboard
Boot Issues About 3 weeks ago my computer started freezing. I trouble shooted and thought it was my Video card. I got it replaced but still have the issue. Power supply is good, memory is good Hard drives are good. If I unplug the power for like 30 min I will get a boot all the way to windows. About 5 min later it locks up and I have to restart. But from that point on I don't understand. I hit the power button and the power supply turns on as well as all fans (motherboard fans included) and all my hard drives and cd drives turn on. But my video card does not turn on and my USB and keyboard never turns on. Ill let the computer sit without power hooked up and the process starts all over again. Help Please
  • Pntwrs Oct 10, 2007
    What would cause my power do go? Its not all that old just over a year.
    What would make my power go? Its just over a year old.
I've seen the same problem fixed it with new power supply. The old one was losing full power.
Posted on Oct 09, 2007
Error 0xa0000001 in window
Possibly but it may be caused by many other issues.
This is from Microsofts web answer;
There are many reasons why your system may crash due to these stop errors. The most common scenarios are: Faulty drivers, Hardware issue (especially RAM) or Anti-virus software problem.
You may want to try the following and check if it helps.
Method 1:
Run Memory Diagnostics test to check for any memory problems. Refer the following link for the same.
How do I know if my computer has a memory problem?
Method 2:
Update the chipset, video card, display and network adapter drivers to the latest by visiting the computer manufacturer's website.
Update a driver for hardware that isn't working properly
Update drivers: recommended links
Method 3:
A clean boot helps to verify if any third party application services or startup item is causing this issue.
You may refer the following KB article to put the computer in clean boot:
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
After the trouble shooting steps please refer to clean boot link to put the computer back to normal start up mode.
Jan 20, 2014 | HP Pavilion Computers & Internet
The game freezes when kratos cut the man down which is eaten by a bird. when the man falls in the fire ,the flames goes around kratos and then the game freezes
Computer freezes is usually related to hardware, meaning the video card, random access memory (RAM), or another component may be underperforming. Software can also lead to a frozen computer, as can issues with drivers, the operating system, and malware; A virus or spyware infection on your computer might also be the source of freeze issues.all these things can stop a computer from working properly.
1.If the freeze happens every time a certain hardware device is plugged in or switched on, the device itself might be to blame. Check drivers update for the device, and download and install them to erase any bugs that might exist in your version. Similarly, if the freeze only happens when using one particular application, that program might also be the root cause.
2.Run the System Restore utility from the System Tools section of the Accessories folder on the Start menu to roll back Windows to a previous version of the registry. This will fix prior registry issues without affecting personal files and settings.
3.If your computer still keeps freezing up after you take the solutions above, I suggest you to download a software to deal with it. The choice is sure to be more effective and simple, but there are few free utilities for this issue. Windows Boot Genius is a excellent one if you wanna take this solution.
source:http://windows-repair.net/computer-freezes.html
Jan 13, 2013 | HP Computers & Internet
No video signal
You can try these Trouble Shooting steps:
Monitor Self Test:
1. Physically test the monitor autonomously from the computer.2. Switch both the monitor and the computer off, and then disconnect the VGA cable le from the computer.3. Turn the monitor on, pressing the power button for about three seconds. The self-test screen will come up .4. If the image is clear, bright, and shows red, green, and blue, the monitor is working properly. Video issues may be due to the video resolution in the computer, and not the monitor.5. If the image is not apparent and intense or the colors are not accurate, then the trouble is with the monitor or some of the (OSD) settings. In this case, test your particular monitor's information for OSD.
Safe Mode:1. Restart your computer. 2. Before the windows logo you should gently tap the F8 key repeatedly until you are presented with a Windows XP Advanced Options menu. 3. Select the option for Safe Mode using the arrow keys. 4. Then press enter on your keyboard to boot into Safe Mode. 5. Do whatever tasks you require and when you are done reboot to boot back into normal mode.
Video Card:1. Unplug all of the cables.2. Unscrew the tower.3. Remove the video card from the PCI slot.4. Use an eraser to erase the coper pins on the video card. It will remove the dirt from the pins.5. Insert the video card in the PCI slot.6. Screw back the tower.7. Plug back the cables.8. Turn on the pc. It should be working after these steps.
Thank you for choosing www.fixya.com.If you have any other issues under the sun, just post your questions here and we will provide you the answer.
Dec 01, 2011 | HP Pavilion a1700n PC Desktop
Weird problem: Okay, everytime I try to play a
Try updating or reinstalling your flash player. If that doesn't work, try using a new browser.
If it's still not solved, it might be an issue with your video card driver. Try updating that.
Hope this helps. :)
Mar 03, 2011 | YouTube Videos
15" Dell monitor is blank-connected
there can be many issues why there is no screen on this other computer.
1. video card failure
2. No system boot "bios issues"
3. Cables not connected correctly
4. Bent pins
First you want to do some trouble shooting. If this monitor works with a computer and not working with another then obviously there are some issue with the computer itself.
Have you check the resolution that Windows is putting out?
Try booting in SAFE mode this will set the computer's resolutions to the lowest so you can see a image. Most monitors in this caliber cannot handle certain high resolution signals.
We are here to help please update us with any more information you may have such as:
Are you see-ing any boot up screens?
Do you hear the system actually boot?
Thanks for using Fixya.com I do hope this was very helpful information for you.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 30, 2010 | Dell E153FP 15" LCD Monitor
Not reading Games
bad laser. need to have replaced
Jun 06, 2010 | Sony Playstation 3 (PS3) Console
My computer comes up with a black screen
try and start in safe mode
then see if your driver is correct in my computer property hardware devices
Jan 17, 2009 | ATI RADEON HD 2400 PRO Graphic Card
NFORCE4 -939 MOTHERBOARD PROBLEM
Well if you like you can pay for the live chat and I can help you if you like. I work on computers for a living. It would be to hard to truoble shoot this typing a paragraph at a time.
Feb 13, 2008 | EliteGroup NFORCE4-A939 (NFORCE4A93910)...
Mach speed
Unplug the the dsl & any other device except the keyboard & mouse. Double check the video cable at both ends monitor & PC. Boot up system. If the system starts shut down & connect 1 device. Boot the system. OK? continue to do this. On the dsl there is a reset button. With it unpluged from power use a pen & hold in the reset for about ten seconds. Reconnect the power & reconnect the Rj45 to the PC. Boot system.
Jan 26, 2008 | Mach Speed VENOM MSA2-6100V Motherboard
JVC camcorder says "Please Wait"...
PRESET the camera two or three times and try.
Jun 29, 2007 | JVC GR-D270US Mini DV Digital Camcorder
EliteGroup NFORCE4-A939 (NFORCE4A93910) Motherboard Logo
67 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
