Question about VillaWare 2010 Waffle Maker
Waffle Iron voltage supply wire
I have a vintage Montgomery Ward model 94MW2149A 120V/950W made in September 1949. The 120V supply wire to one of the heating elements has broken. This wire is aprx. 14 guage twisted strand with a asbestos insulation. I can not find any wire locally that is heat resistence to replace and repair this unit. What can I use for a replacement wire? Thanks David Sewell
3 Suggested Answers
jerryg50
  • 1689 Answers
SOURCE: waffle iron top not heating
I don't know for your model type, but in many of these the heating element can be replaced. Check with an ohm meter to know if the element is actually defective, or if it is the thermo safety cutoff fuse that is blown.
If you were to do this yourself, and you know about appliance servicing, have instruments to check for proper temperature and current draw, and you will need the proper crimp-fittings (stake-ons), and crimp tool to do any of the wiring inside.
Jerry G.
Posted on Jun 27, 2008
SOURCE: Seasoning Waffle Baker and Grill
FIrst, make sure there is some kind of fat or oil in the waffle batter recipe. This is the biggest difference between waffle and pancake batter. Go to Sams or a restaurant supply store and get a spray product like waffle-off. Spray lightly aftter every few waffles. Use lightly as heavy spray can cause build up. If you can't find this product use one of the PAM type sprays for BBQ grills or maybe an olive oil based product. Regular Pam sprays build up faster as they are not really designed for this. Don't try to wash the grids between uses as they need to keep the oil coating. (Like using a cast iron skillet) They will turn a dark brown. Just brush off crumbs or use a damp rag. Make sure the waffles are completely cooked as when not completely cooked they will seperate and be very difficult to remove. They are cooked when the steam stops coming from the sides. This will take 3 - 6 minutes. Don't preheat with the iron open or allow it to stand open for any longer than necessary. (It can overheat)
Posted on Jun 29, 2008
Manuel for 1950 Montgomery Ward Sewing Machine
Search for:
Make Model manual
you may find one for your model or a similar model. Most of these machines did not vary much. I believe these were machines were made in Japan and badged for Montgomery Ward.
Apr 22, 2018 | Montgomery Ward Sewing Machines
I need a manual for Montgomery Ward sewing machine model #uht j1914
I could not find one for your specific model but I did a similar one here:
Montgomery Wards Sewing Machine Instruction and Service Manuals
#51 should be a close enough match for you to discovery the different functions you are looking for
Jul 16, 2015 | Montgomery Ward Sewing Machines
Where can I find a user manual for my vintage Montgomery Ward automatic zig zag sewing machine?
well since M W went belly up many years ago I doubt you ever will find one .check with an OLD sewing machine repair shop if you can find one
May 27, 2015 | Montgomery Ward Sewing Machines
How To clean Vintage Sunbeam CG Waffle Iron Grids?
Here is a link to the actual CG & CG-1 (12 page) owner's manual.
It will tell you how to clean it properly.
http://www.meba.com/manuals/SunbeamWaffleBaker.pdf
Jul 17, 2014 | Sunbeam Cg-1 Vtg Waffle Maker Iron...
Need the manual and recipe
Here's a manual for my W252, which is similar to your model.
Feb 14, 2014 | Toastmaster 442A Vintage Waffle Iron
Plug gets hot on my vintage sunbeam CG waffle maker
You can replace the power cord on these models easy enough, as the cord is actually attached to a small black, plastic box that can be opened to replace the cord. You can find cords at home improvement or hardware stores. Before going this route, make sure the wall outlet you are plugging the waffle iron into, is properly grounded. You can check this by using a small outlet testing tool that lights up green or orange if installed properly or improperly. It also checks for reverse polarity, in addition to bad ground.
Jan 13, 2013 | Sunbeam Cg-1 Vtg Waffle Maker Iron...
VillaWare 2010 Waffle Maker Logo
326 people viewed this question
Top VillaWare Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Angel Joseph Jr.
Angel Joseph Jr.
Are you a VillaWare Kitchen Appliances - Other Expert? Answer questions, earn points and help others
