Question about 3Com OfficeConnect Wireless 108Mbps 11g PoE Access Point IEEE 802.11b/g Wireless Access Point (3CRGPOE10075USFT)
3com wireless the router never start, just keep rebooting, i can´t see it from my computer. the ip is in the same range, but the router never show. i connect to it by console port and i can see a error while it is rebboting. panic: trapmon detect a fatal error. please help me
  • Ramez May 11, 2013
    I had same problem.
    You have to change configuration for board data: [Boot]: S name: Atheros AR5312 default magic: 35333131 cksum: 11a1 rev: 4 major: 1 minor: 0 pciid: 0013 wlan0: no 00:03:7f:fe:00:00 wlan1: yes 00:03:7f:fe:00:02 enet0: yes 00:03:7f:fe:00:01 enet1: yes 00:03:7f:fe:00:03 uart0: yes sysled: yes, gpio 7 factory: yes, gpio 0 serclk: internal cpufreq: calculated 180000000 Hz sysfreq: calculated 45000000 Hz memcap: disabled watchdg: enabled
  • 49 Answers
Problem like this is a manifestation of a corrupted firmware. Try to upgrade the routre's firmware.
Posted on Oct 25, 2007
SOURCE:
Configuring a 3COM 3CRWDR200A-75 router as a repeater
SETTING A ROUTER AS A REPEATER 1. Connect your computer to the repeater router's RJ45 port with a LAN cable. 2. Open a browser, then enter the router's URL configuration's IP address, This is usually something similar to 192.168.0.1 3. Enter the configuration user name and password. The router will display the various router settings. 4. Go to the page that changes the IP address of the router. Changed the IP address so that it is not the same as the main router on the network, or any other network devices. If the main router on the network is set to 192.168.1.1 then the repeater router should use a higher number (ie. 10), such as 192.168.1.10 or higher, depending on how many devices are on your network. 5. Disable the repeater router's DHCP server. This setting should be on the same page as the IP address, (this may be different depending on the make of the router). When the main router is operating normally, this server assigns an IP address to every device that is connected to your network. Because this router is used as a repeater, the main router on your network will still issue the IP addresses. 6. Also turn off the DNS server, if it is activated. This function will be taken over by the main router. 7. Disable any firewall settings on the repeater router. This is usually in the "Security" section, depending on the make and model of your router. 8. Remove all in the "Port Forwarding" section. Some routers may refer to this as "Applications and Gaming," and it allows less-restricted access to the internet. 9. Set the operating mode switch to "Gateway" or "Switch" if applicable. Also, if the repeater router is a wireless router then disable the wireless access or set it to access point only. 10. Save the settings for each page, and reboot the router. When the router boots up, the changes will allow it to act as a simple repeater. 11. Now, place the repeater router in a new location and connect both routers with a Ethernet cable in each of the router's RJ45 LAN ports, and power it up both routers.
Nov 17, 2012 | 3Com OfficeConnect® (3CRWDR200A-75) Router...
I cannot connect to my 3Com OfficeConnect Wireless (3crwps10075-us) Print Server 3crwps10075
Check you firewalls. Sometimes you will have to allow certain mac addresses or certain ip addresses (may be less secure than the mac address), then change sharing level to full, before things begin to work.
Please post back and let me know if this helps!
Feb 21, 2012 | 3Com OfficeConnect Wireless...
How to connect wire less connection with my laptop,
TCP/IP stack repair options for use with Windows XP with SP2 & Vista.
For XP, Start, Run, CMD to open a command prompt.
For Vista, Start, Programs\Accessories and right click on Command Prompt, select "Run as Administrator" to open a command prompt.
Reset WINSOCK entries to installation defaults: netsh winsock reset catalog
Reset TCP/IP stack to installation defaults. netsh int ip reset reset.log
Reboot the machine.
Aug 11, 2008 | Linksys WRT300N Wireless Router
Can't access 3Com OfficeConnect Router browser
you go to start, run, type cmd. and then type ipconfig. locate the ip for default gate way. Use the ip to go to your browser.
Aug 10, 2008 | 3Com OfficeConnect Router
3com officeconnect wireless 11g cable/dsl router
router default ip gateway will be the 192.168.1.1,so you can able to give the same ip address,so you configure only other ip address & try it.
May 25, 2008 | 3Com OfficeConnect Wireless 11g Cable/DSL...
I HAVE INSTALLED THE WIRELESS-G PCI ADAPTER THAT CONNECTS TO THE WRT54G ROUTER. I HAVE CONNECTED MY COMPUTER AND EVERYTHING SAYS THAT NOW MY COMPUTER IS WIRELESS. WHEN I GO WIRELESS I GET THE MESSAGE THAT...
Once everything is attached you have to reboot everything so your router can assign IP addresses.
If your wireless pciG has a static IP address that is not in the proper range e.g. (if the router is 192.168.0.1 and your desktop is 192.168.15.1 then you can not log into the router, the router has to assign IP addresses in its range of 0.2-0.50)
If your IP address is assigned dynamically, then everything has to be re-booted so the router can assign the address in it's range.
Mar 26, 2008 | Computers & Internet
Open Questions:
See all 3Com OfficeConnect Wireless 108Mbps 11g PoE Access Questions
Computers & Internet Logo
223 people viewed this question
Top 3Com Computers & Internet Experts
john smith
didi2005
Håkan Sterner
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
