Question about Phoenix Gold Xenon-600.1 Car Audio Amplifier
Phoenix gold xenon 600.1 power problem
I have a problem wiht my PG xenon 600.1 amp. It turns itself on and off as it pleases. It even came on when the remote wire wasnt even plugged in! I dont know much bout amps so i was wondering if this is a problem that can be fixed and where can i send it to get fixed.
  • 631 Answers
Sometimes problems like this are caused by tiny strands of wire in the amp. These can cause catastrophic amplifier failure. If you pull the cover off of the amp, you should be able to see the strands (if they're present). If that's not the problem, you should send the amp back to PG for repair. Before you pull the cover, completely disconnect power from the amplifier.
Posted on Oct 09, 2007
No sound from subs
You need power to the amp. If the light on the amp is not on then your amp is the problem. Get power to it.
Nov 10, 2013 | Phoenix Gold Xenon-400.1 Car Audio...
Can i use a 300 watt amp for 2, 800 watt woofers
yes, but you would not get the same performance as you would if you gave them the suggested power. I have found that it is always better to use a more powerful amp than your subs are rated for (as long as it is clean, high quality, low distortion power). I have had the best luck with name brand amps (kicker,rockford fosgate,phoenix gold,etc...). I hope this will be helpful to you.
Jul 30, 2012 | Phoenix Gold Xenon X10D4 - 10" D4...
I have amono 600.1 amp
if its mono there is nothing to bridge
Jul 12, 2009 | Phoenix Gold XENON 600.1 600 Watt...
My PG Xenon 600 watt amp will not power my subwoofers
hello it sounds like your problem may be in the remote/power wire that goes from the back of your radio deck to the amplifier. the amp should have a wire connection that says remote,p.con, or antenna. and its usually the smallest wire connector located by the power and ground wire. this wire goes to the solid blue wire coming out of the deck. you can conect the wires together any way you want. i usualy shave off a little pice of the wire cover and wrap the wire coming from the amp around the bare wire then cover it in electical tape or cut the blue wire from the deck at a fit length and use a wire nut and put the two cut ends in and also the wire coming from the amp. also make sure the amplifire dose not have power to it just to be safe. wouldent want to fry anything.
There is also the left and right wires(ususaly red and white) that go on the back of the deck to the amp.
also chek the volume on the amplifire
Apr 12, 2009 | Phoenix Gold XENON 600.1 600 Watt...
Crossover
i have lost my manual to the phoenix gold 600.1 xenon amp. i want to set it up by the book can you help me ?
Apr 25, 2008 | Phoenix Gold Xenon-600.1 Car Audio...
Pheonix Gold Xenon 600.1 power problem.
Do your speakers move in/out smoothly if you push on them?
Have you tried disconnecting the speaker wires from the amp to see if it would remain on?
Apr 11, 2008 | Phoenix Gold Xenon-600.1 Car Audio...
Led light keeps flashing on my phoenix gold amp
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . Remember to disconnect all power including ground for about to 1/2 hour to discharge capacitors. You might get lucky and get a reset. .A thumbs up would be greatly appreciated if this answer is helpful to you. led-light-keeps-flashing-phoenix-gold-zb4bomd1rt4qms0dqd12kkt2-3-0.jpg
Aug 07, 2007 | Phoenix Gold Xenon-600.1 Car Audio...
Phoenix Gold Xenon-600.1 Car Audio Amplifier Logo
175 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Mark Skinner
Jose Velazquez
Jose Velazquez
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
