Question about Twinhead Durabook N15RI-2 Notebook PC
Number keys not working - Twinhead Durabook N15RI-2 Notebook PC
Some of my letters are not working
If numbers are appearing instead of letters then -
You have press the NumLk key (number lock) and this changes the right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock.
Sep 03, 2012 | Toshiba Computers & Internet
Number lock not working
Most times you have to press an hold the FN key at the lower left portion of the keyboard to get them to work. If you'll notice, the numbers on keys jkluio789 are in blue and so is the FN function key.
Jun 06, 2012 | Computers & Internet
Number key not working on laptop
If you are talking about the number symbols that are on keys U,I,O,P,J,K,L,M then notice what color the number symbols are on those keys. Normally they are blue or might have a square around them. That means you have to press and hold the key that is the same color or has the square around it on the left side of the keyboard. Normally you would Press and Hold the FN function key at the lower left hand portion of the keyboard, then hit the key for the number you want. Notice that the FN function key will be the same color as the numbers. If it's not the FN function key then it will be the key that has the square around it like the numbers has.
May 23, 2012 | HEWLETT-PACKARD Pavillion DM1-3020US...
My key bord U,I,O,P,J,K,L,M. keys not working when i press these buttons numbers showing plz tell me wich key i press that these keys work properly
You have press the NumLk key (number lock) and this changesthe right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock).it is near the F12 function key. When the NumLk has been enabled a LED light is turn on toindicate this function has been selected.b>
Apr 04, 2012 | Acer TravelMate Computers & Internet
Acer laptop number keys on right not working.
You have hit the num lock key. Lookin at pictures I could find on the internet, the Num Lock key is next to the backspace key, and above the number 7 key.
Hope this helps
Mar 30, 2012 | Acer Aspire Computers & Internet
My number pad on my keyboard is not working, how can I reactivate it?
At the top, left corner of the number pad, there should be a key that says "Num Lock." This key toggles the functionality of the number pad keys between Numbers and Directions.
Press Num Lock once and the numbers should start working again.
Press it again, and the keys should go back to the Directions (up, down, left, right, Page Up, etc.)
Jan 11, 2011 | Gateway Computers & Internet
Capslock needs to be on to get lower case and number keys dont work yet number lock will allow symbols to work but not then letter keys that have small numbers in left hand corners. Problem is on a Sony...
Please check if the accessibility option is enabled to convert your number pad to mouse keys, if you have a full numberpad.
Since you have not specified what it the model number of the computer, i am giving your common steps.
Also check restart the computer in safe mode (keep tapping the F8 key while you restart and choose the safe mode option using the up and down arrow key and hit enter) and check if the number keys work.
Dec 26, 2010 | Sony VAIO VGP-WKB1 Keyboard
My number keys arent working because i was hold shift for more than eight seconds the a message popped up then i clicked ok
Try holding down the shift key again for 8 seconds and read the window to cancel the filter keys.
As for your numbers not working, there is a NumLock [number lock] key on your keyboard. Try hitting that and see if your numbers work.
Hope this helps.
shibumi
Jan 26, 2009 | Targus USB Ultra Mini Keypad Keyboard...
My numbers aren't working and my num loc is on
i got it!! hold down the 2 shift keys for a few seconds then bamm!!
Sep 08, 2007 | Targus USB Ultra Mini Keypad Keyboard...
Twinhead Durabook N15RI-2 Notebook PC Logo
Top Twinhead Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Lee Durbin
Lee Durbin
Carl Rick
Are you a Twinhead Computer and Internet Expert? Answer questions, earn points and help others
