Question about Homelite 33cc 38cc 45cc Chainsaw Oil Pump Pa01396
How do you take oilpump out of homelite33 chainsaw
Chain oilpump clogged
You haven't stated the make and model, but it's a relatively simple process to access the oil pump and blow out with an air-line. Also make sure your oil tank is empty, remove the oil cap and blow through the main oil line back into the tank.. This can then be flushed out.
May 10, 2016 | Garden
How.do/i.remove.oilpump
well you failed ot mention the make and model so let me say this, most chainsaws oil pumps are easy removed by taking off the bar and chain , this requires the removal of the clutch cover not a big deal you neeed to take that off to get bar and chain off , then it's a quick twist of a phillips screw driver and out it pops , dont let that little hose go fall back inside unless you enjoy fishing , cus your gonna be fishing for it back , i use a lasso ! of crabbing line string on the hose to keep it close up top
, dont forget to clean your bar oil passage out of saw dust !! i like brakeclean for this job , but dont spray on paint job !!!
Feb 28, 2015 | Garden
Need a exsploded view of a oilpump assembly on a 1955 ford customline 272 engine
Your question may have been mis-categorized under Homelite chainsaws. It maybe should be under engines.
Sep 15, 2014 | Homelite 240, 245 Oil Pump Cover
The oil pressure indicator light came on and flashed and a ding sound then it said "STOP" turn off engine. Not sure what is wrong. Oil level is ok.
it can be that your oilpump is packing up or your oil switch is faulty.the best bet is to do a oil presure test to check oilpump then you can work from there
Apr 23, 2011 | 2002 Volkswagen Passat
I have a 86 ford f-250 w/ a carbed 460.no fuel to carb. was told i had very low oil pressure.would changing oilpump and assending unit fix my propblem? do i have to pull motor to change oilpump? what...
If you're not getting fuel to the carburetor, check/change your fuel filter, check the fuel pump. And for the oil pressure you can change the oil pressure sending unit to see if thats the problem, for the oil pump the oil pan has to come off, it can be changed without pulling the engine, however you still have to lift the engine up.
Feb 16, 2011 | Ford F-250 Cars & Trucks
Tring to time oilpump but when hole on oilpump shaft is inline the timing mark moves out of timing hole working on harley 63 sportster
Bring the engine to top dead center and find a way to lock the engine in that position. When you lift the oil pump into position, you'll notice the the oil pump drive gear rotates when it engages the pinion gear. You have to turn the pump backwards so that when it rotates while you lift it up, the hole comes into alignment with the slot when fully seated against the case. Just like timing the distributor or magneto.
Mar 05, 2010 | 1979 Harley Davidson XLH 1000 Sportster
Oil not getting to chain
check that the oil gallery in the bar are clear.blow out with air if you have it.
Jul 18, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Oil pump on w reg gilera runner,
its a piagio ,what else do you expect but a honda .
Oct 25, 2008 | 2000 Ford Focus
Homelite 33cc 38cc 45cc Chainsaw Oil Pump Pa01396 Logo
43 people viewed this question
Top Homelite Plumbing Experts
richie46
Gil Shultz
Robert Dean
Robert Dean
Level 1 Expert
Are you a Homelite Plumbing Expert? Answer questions, earn points and help others
