Hotpoint WML 730
Washing Machine stops when programed it will pump out and fill and then stop. if you leave it it will keep trying and then stop seconds later. Leave it for some time the lights starts flash Horizontaly
  • Jonathan Hume
    Jonathan Hume Nov 21, 2013
    I have been told that there is a sequence of butons to pus at the same time to clear any faults? All pumps are ok as it pumps out fine and the impeler is spining ok. could there be a fault shown by the flashing lights.
  • Washing Mach... Master
  • 17,129 Answers
Possible this seems to be an error. You need to start by check the inlet water flow, check the free flow, if not check the inlet valve or the valve drive. Also check the drain pump and see if there is no clogging, Now switch on and check voltage on the inlet valve, if absent check the main program controller. If water flows check
Posted on Nov 21, 2013
4 Suggested Answers
mumma_1
  • 903 Answers
SOURCE: wash enhance & on/off flashing
The only time the lights kept flashing on my Hotpoint machine was when the outflow pipe going into the ubend was blocked,
Check for blockages, but make sure that you have a bucket or pan ready to collect the water flow.
I hope this helps
Posted on Nov 24, 2008
SOURCE: my hotpoint aquarius wd440 has flashing lights
First of all try cleaning the filter inside the back as described by others if this does not work there is a filter in the top. how you clean this is quite easy. all you do is remove the top of the machine by undoing the 2 screws at the back then pull top top backwards when you have removed the top you well see a large metal casing on the left if you are looking from the the back of the machine the filter is in there to remove the casing you pull the small pipe off then undo 5 star headed screws then gently pull the casing off noteing that there is a large pipe at the front when you have remover the casing you will see the filter (the small pipe you removed at the start fits on this filter) clean the filter then put it all back together.
Posted on May 17, 2009
  • 3 Answers
SOURCE: All lights flashing on Hotpoint WF541G washing machine
It's probably a loose connection in the wiring in the machine. Seems to be a problem with the WF741 machines and is most likely a similar issue with yours. The probability is that the vibration from the machine is enough to work some connections loose. If you have someone competent to do this, then check that all connectors are pushed firmly onto their circuit boards. (I have posted a separate reply to this issue for the WF741 model on here.) See if this helps.
Posted on Oct 27, 2009
Hotpoint wml 730
Sounds like it could be an unlevel washer. That is one thing to check.
Make sure the filter is clean. The filter is located behind the kick panel and will be a screw in filter. You will need a shallow bowl or pan to catch the excess water. Clean the entrance for the filter is clean and free of dedri.Make sure to unplug your machine before this procedure.
There are other problems it could be but, lets try this and see if it helps.
Aug 27, 2014 | Washing Machines
How do i remove the drum from a Hotpoint Aquarius WML 560 P
There is not much you can do to remove the drum of your WML 560 P Washing Machine...you can remove the bearings and door but you can't remove the drum personally. You'll have to take it in for service but here is a manual for you which you can read through to see if there is anything about removing the drum. Click on the link below to be directed to your Hotpoint Aquarius WML 560 P User Manual homepage...
Hotpoint WML 560 Instructions For Use Manual
Aug 26, 2014 | Washing Machines
Hotpoint aqualtis washing machine model AQXXL 129 PM , runs through the cycle then stops at times leaving water in the drum and all lights flash why ?
the pump could possibly be jammed. you will need to drain the machine and remove the filter to check for any obstruction
May 17, 2014 | Hotpoint Washing Machines
I have a hotpoint Aqrius wml 560. Everytime I put the washing machine on there an dreadful smell come's out from machine. I have tried putting machine on hotest temp empty but still I get this...
Locate the area from where the smell is emiting. You need to see the rear bottom to see the pump and the motor. Check after the smell is noticed - remove the power and touch the pump and motor - If so there is fault on one of them. If not check the capacitor to the motor, the program controller unit. Your observation is most important to confirm.
Jul 09, 2011 | Washing Machines
Spin not working properly, sounds ok but clothes are too wet once complete and the independent spin cycle leaves clothes soaking!!!
Sounds like a small blockage in the outlet pipes, possibly just in the filter but check all outlet pipes. Just done one the other day and it was a clothes button that had passed out of the machine through the pump to the outlet pipe but had turned sideways inside the outlet pipe.
Jan 25, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
327 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
