Question about Maytag MSD2756G Side by Side Refrigerator
Maytag Elevator Shelf
Wife took shelf out and it came apart, played with the shelf for two days but am not sure how exactly to put it back together or in??
  • Anonymous Jan 14, 2008
    I have the same problem with the elevator shelf and almost all of the shelves on the Maytag Plus. Right now everything is out of the frig, except for the bottom drawers. The cold control section freezes food even when it is turned down.
Let me just say, your post helped me, because I realized that I was not going crazy.  But, I was able to find the manual on this frigerator, which was key.  There was one phrase in the manual that gave me help - "when the glass shelf is pushed to the rear, it will align the rear latches.
Manual from whirlpool website: http://shared.whirlpoolcorp.com/assets/pdfs/literature/MSB2154ARA.pdf
So, the rear latches must be installed in such a way that the sliding glass shelf not only touches them, but pushes them into the correct position.
This fact helped me to try different positions, each time testing to see if the glass shelf would do anything.  Finally, I realized that there is a triangular shaped part of the rear latch.  The hypotenuse of the triangle is what comes into contact with the little nub on the underside of the glass shelf.  The nub on the glass shelf pushes the rear latch along the hypotenuse of the right triangle, and into the correct position.
Here is a picture of it installed in my frigerator,which I am sure will tell it better than any words:
Posted on May 31, 2009
  • Dawn Vesely
    Dawn Vesely Oct 03, 2015
    So where do the little blue clips go?
  • Uncurly DIY Brazilian Keratin
    I would like to add only one thing: when you're replacing the shelf, any shelves above it must be removed because the elevator shelf needs to be threaded onto the metal tracks on the back wall inside the refrigerator. And the way to do that is at the top of the tracks, where they stop before reaching the top of the interior cabinet.
SOURCE:
I took my fridge apart to clean it and now I can't recall the proper shelf positions. I have a Maytag RSW2400
the fridge has a number of positions for the shelves to suit different heights of the items you are putting in the fridge
set the shelves that best suit what you have
Dec 10, 2016 | Maytag Refrigerators
How do I change Bang & Olufsen Beosound 2000 door belt?
I just did that ; took an 031 oring or was it an 032; and you have to pull the whole drive mech out; it is tricky and if your not small mech inclined don\'t do it; There is a few gears and they work in tandem so when you put it back together it has to be just right; if you take it out take pictures of it as you take it apart because you will never remember how it goes back together; easy to get out; a pain to put back together. And it will all come apart just to put that oring in.
May 31, 2013 | Bang and Olufsen Beosound 2000 Shelf...
He back part has come apart from the base as my wife took it out the car. I can not work out how to snap it together..
Hi I'm not sure if you've fixed your car seat but I'm a nanny and broke the car seat exactly the same way, took it out the car and that was it. It took me ages but you need to tip the base and put the back on the wrong way so imagine it as an L when it together take the back of and tilt the base onto where the child's legs hang. Then take the hooks on the back with the head rest facing up and slide it in behind it should just glide in.
Oct 20, 2012 | Graco Junior Maxi Ece R44/04 Booster Car...
I am getting an E3 Error message on my temp
Do this...
The e3/e4 problem is the "connectors" for the fans to the middle separator shelf are put in the pathway of condensation. This causes them to get wet and rust. PLEASE NOTE: If you decide to attempt this fix, you take full responsibility for your fridge and the outcome. If you don’t think you can do this…DON’T! Call a licensed electrician. Here is how I resolved my e3 issue: 1) Unplug the fridge
2) Remove all wine and the metal shelves
3) Remove the 2 screws from the middle separator shelf, one on each side on top
4) Remove the 4 screws from the backboard, one in each corner
5) Slide out the middle shelf slowly, on the right hand side towards the front of the shelf there will be 4 connectors you must disconnect before removing the shelf (they are tucked into the shelf). With one hand on the backboard and one on the shelf, slowly take them out together
6) Once you have the backboard and shelf out, you'll see there is a black and white connector, each having a red and black wire on each side
7) These are the fan connectors that are causing the issue. Mine were brown/green and damp (not good for electricity)
8) Using wire cutters, cut as close as possible to the "black" connector on each side to remove it. You will have 4 wires left, 2 from the backboard and two from the shelf (both having a red and black)
9) Take some of the sheath (cover) off of each wire
10) Take the red wire from the backboard and the red wire from the shelf and twist the metal portion together
11) Cover w/ electrical tape!!! Or you will have the same e3/e4 issue
12) Repeat step 10 and 11 for the black wires
13) Move onto the "white" connector and repeat steps 8 - 12
14) Put the backboard and shelf back in the fridge. Be careful not to pull the backboard and shelf apart or your connection may come apart
15) As you slide the shelf in, make sure the wires you disconnected in step 5 are in the "channel" on the side of the shelf or the shelf won't slide properly.
16) Reattached the 4 connectors and then re-attach the backboard and the shelf with the screws
17) Plug the fridge back in
18) Put the metal shelves and wine back in
Feb 06, 2010 | Magic Chef MCWC30MCG Compact Wine Cooler
Maytag upright freezer (MQU1556AEW L1)top shelf
my maytag freezer not wotking correctly, the top shelf not cold, I bought a meat and tryed to put it on the top shelf, unfortunately, my meat went to the garbage and just the botttom shelf takes time to freeze, better than the top shelf
any help ?
Jan 02, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
I took the mouse apart and I can't put it back
Make sure the circuit board and wires are all in place correctly so they aren't preventing the case from snapping/connecting back together.
Most of the time, it's just a small piece of wire or something that is getting in the way and preventing you from closing it back up.
Devices are made so small these days that they don't leave much room in them for loose wires and all.
I hope this helps :)
Best Regards,
James Trageser
Jul 29, 2009 | Logitech Labtec Wireless Laser Mouse
E3 error message on Magic Chef wine cooler MCWC44DZ. Can I fix it myself?
Taken from another poster at Home Depot reviews and similiar to what others have found...
" Sucks that a $0.10 piece of heatshrink on the connectors could avoid this...? Bad Design.
Jun 08, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Scooter does not start with button,but start with the kick
what does it do when you push the start button?? click or just does nothing??
is there power to the starter when you push the start button??
May 05, 2009 | Tomos Se 125 F Motorcycles
Maytag MSD2756G Side by Side Refrigerator Logo
1,334 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
