Canon mx320 my printer with new cartridge do not ale to print.may help me,please thanks
  • Televison & ... Master
  • 10,291 Answers
Push the menu button several times until the Maintenance meny comes up. Then push the + button to select the options the the ok button to execute the option.
Posted on Jan 08, 2014
Where is reset button on MX320
Switching it off, or better, remove the power cable for 30 seconds should be enough to reset the printer. But when even new cartridges are giving trouble you should check the contacts. Not only from the cartridges, but the ones in the printer (cartridge holder)
Jan 28, 2015 | Canon PIXMA MX320 Color USB InkJet Printer
Shows an error - Printer error 5200
I didn't find MX320 in my area but I think MX300 is similar to the MX320. The following is the reset ink counter for a MX300:
1. Disconnect the power cable
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The printes turns into a kind of factory mode...(wait for about 10 seconds, utils it says "Idle")
6. Press the ">" (next to the "OK" button) once."Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print..
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back and the ink level in the canon Pixma MX300 have full again.
Hope it will help.
Sep 19, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
I have fault 5200 on mx320 it won t work.
Try these solutions:
  1. Power off printer, wait 5-10 minutes than turn it back on.
  2. Try reseating print cartridges (remove them and then put them back in)
Removing cartridges:
Installing cartridges:
If I helped you, please rate my answer :)
Sep 06, 2011 | Canon PIXMA MX310 All-In-One Printer
My print is Canon MX320. I just changed a new ink, but the error 5200 occured. Do you know what happened? Thanks.
Error 5200 indicates that the print head temperature has exceeded the specified value. Turn off the printer and then turn on, if error still persist replace ink cartridge or print head.
Jan 30, 2011 | Canon Office Equipment & Supplies
My canon mx320 multi function printer doesnt want to scan. it shows a U051 code and refuses to work.does a printer need tp have ink to scan?? i dont think so. pl help
Need to reset the cartridge.
How to fix the printing problem when Canon PIXMA MX320 series detected the errors in your cartridge?
After refilling the cartridge, the next thing to do is to reset the cartridge. This will clear your printer from displaying common printer errors like U041, U042, U053, U051 and U052. The importance of the "reset the cartridge" procedure is to avoid the printer from detecting your cartridge as reused one. The steps below is recommended to do after refilling an ink cartridge.
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
For error U162 or U163 All functions of the all-in-one printer will stop and your printer will not work.
1. Turn off your printer an turn it on again
2. After the printer initialize try to copy or print. The error will appear.
3. When the error is displayed on the display panel of the printer, Press and Hold the STOP/RESET button and wait until it self restart.
4. Release the STOP/RESET button the the printer is restarting.
5. Wait for a few seconds and the pending print jobs will commence.
Please give this solution a good ratings. thanks
Dec 06, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
My canon mx320 says error 5200
Hi Good day!!! Do this steps
1. Turn off printer
2. Open up the top cover and move the print head to the center
3. remove all cartridges and then turn back on wait a few seconds now your printer will find the missing cartridges now put it back one at a time nice and slow make sure you insert the cartridges properly after that close the cover and see if your printer is back to normal.
Hope my solution helps you
Thank you for using FixYa
Don't forget to vote
Nov 05, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
How do I change the ink on the Cannon MX330? I cant find where the cartridge is
I am writing this to enquire in regards to Canon Pixma MX320. I bought a Canon Pixma MX320 about 3 weeks ago, and I have brought it over to overseas. I am wondering if it is possible to change from the general ink cartridge that this particular printer use, which is PG510 and CL511 to another similar ink cartridge, which is PG810 and CL811. This is because, where I am living right now, doesn't have the particular Canon Pixma MX320, but instead Canon Pixma MX328 and MX338. The Canon Pixma MX328 and MX338 uses the PG810 and CL811. So, is it possible to substitute from PG510 to PG810 and CL511 to CL811 for Canon Pixma MX320? Thank you for your help.
Aug 29, 2010 | Canon PIXMA MX330 Multifunction InkJet...
How do you replace the ink cartridge on my Canon pixma mx320 printer?
Lift up the top lip cover together with the scanning unit cover to expose the cartridge carrier.
Open the ink locking cover. Gently pinch and pull up the cover of the cartridge carrier.
8bc22ce.jpgAfter that replace the ink cartridge...
I hope that instruction will be of help.
Please rate this answer.
Thank you for using Fixya
Jun 07, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Dell Photo 964 All in One Printer
first u see cartridge is ok or u can install a new cartridge then aling from both the side first u give print of aling page and then scan the aling page i think this well solve the problem
Aug 19, 2009 | Dell Photo 964 All-In-One InkJet Printer
Televison & Video Logo
Top Televison & Video Experts
