Question about Coffee Makers & Espresso Machines
ECAM23.450 insert infuser assembly - Coffee Makers & Espresso Machines
4 Suggested Answers
  • 3 Answers
SOURCE: DeLonghi Magnifica always asks "Insert Infuser Assembly"
on my machine, the two screws that attach the infuser receptacle to the insides of the machine came loose. You can see those two stainless hex socket screws when you remove the infuser by grabbing its two red tabs and pulling it out. Just use a hex shaft
screwdriver (size 3mm or thereabout) to tighten them.
Posted on Apr 18, 2009
SOURCE: insert infuser assembly alarm on De longhi coffeemachine
Did you try tightening the 2 hex screws behind the infuser?
Be gentle though. Mine felt tightend but thenIput just a bit more pessue on them and got an eigth to a quarter more turn out of them. Found this solution on this site
Posted on Sep 07, 2010
mnwarfield10
  • 452 Answers
SOURCE: delonghi magnifica rapid cappuccino model EAM
try cleaning any old bean dust ect with vacuum ... refit or replace infuser lot better . if still no good you need someone to check pcb assy ... bsc appliances 07779933829 we cover repair service anywere via post.
Posted on Feb 27, 2011
Delonghi magnifica rapid cappuccino model EAM 3400.S KEEPS SAYING INSERT THE INFUSER, I HAVE PUT THE INFUSER IN AND IT HAS CLICKED BUT IS STILLS SAYS INSERT THE INFUSER
Nov 28, 2010 | DeLonghi EAM3400 Espresso Machine
'less coffee' error message
The infuser assembly can only be removed with the machine turned off. The infuser needs to be removed and cleaned at least monthly; more often if you use your DeLonghi at lot.
Jun 14, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Leaking water
Check for two loose screws holding the backplane that holds the infuser unit. With the machine OFF, open the door and press the two red buttons to pop out the infuser. You will then see two 3 mm hex head screws attaching the backplane. Check that they haven\'t come loose; if so, you\'ll need a hex socket to tighten them. Then re-insert your thoroughly cleaned infuser and see if that has stopped your water leak.
May 28, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi coffee machine making an aweful noise,
Hi. Husband asks: When you first turn the machine on at the power point, does it make a motor sound and then stop, or is the awful noise apparent at that time.
If the awful noise starts as soon as you turn it on, then most likely there is a motor problem which will need to be seen by a Service Center.
To locate information about De'Longhi in your country, refer to http://www.delonghi.com/
May 24, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Can't remove infuser to clean it
Turning off the power with the button is not enough. Instead, to remove the infuser: unplug the machine, wait a few seconds, plug it in again and turn the machine on. Even though you are technically turning it on, the machine will sense it was not turned off in an ok way, so it will "properly" shut off (and unlock the infuser).
May 06, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Insert infuser assembly alarm on De longhi coffeemachine
Jan 15, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
DeLonghi "Insert infuser assembly" error
Easy Fix - Delonghi Coffee machines which have built-in coffee grinders often suffer from a problem that produces an error, "Insert infuser assembly" that appears at random times.
The problem is usually caused by distortion of infuser lifting mechanism limit switch mounting (Orange colored plastic)!
The mounting is very close to the water heater so with heat and pressure from the infuser lifting mechanism the mounting gets bent over time. The switch mounting (Orange colored plastic) gets permanently distorted so the striker arm on the lifting assembly only just presses the micro switch button causing the error message "Insert infuser assembly".
To easily fix the problem on ESAM 5500 machines and should work on other similar machines:-
    1.Unplug the machine and remove the rear cover screws and remove.
    2.Slide out the two side covers.
    3.Remove the grinder lever screw in the top cover coffee bean compartment.
    4.Carefully lift the top cover pushing it slightly back so it does not stick under the front cover (you may have to loosen the 4 front cover screws on the side).
    5.The limit switch is clearly visible on the top (see photos).
    6.Wedge some insulated material (wood, plastic etc, I used bamboo) between the heater assembly and the switch mounting so the switch is in a VERTICAL position. The thickness of the packing is around 3-4mm (see photo).
    7.Re-assemble the machine and enjoy your coffee. JTS
    Alwar, Rajasthan
    India
Apr 01, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
The machinge keeps asking to insert brewing unit but it seems to
The infuser does go in at a slight angle "11:45" ish. Be sure the tabs on the sides of the infuser "pop" back out when it's in place. Try unplugging the machine if all else fails and it will do a self diagnostic. You could also call Delonghi tech support.
Jan 02, 2009 | DeLonghi EAM3400 Espresso Machine
Magnifica gives Generic Alarm Message - Infuser stuck
My infuser was stuck in the down position, When I called customer support the told me some easy steps to fix this problem..try calling them
Nov 28, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
DELONGHI 3500
delonghi 3500 turns, runs diagnostics and then shuts off. Won't turn on unless you pull the switch. Any Ideas?
Jun 03, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
Coffee Makers & Espresso Machines Logo
98 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
