Backspace button does not work
I can only delete if the cursor is in front of the character, when I press backspace nothing happens
Not working sound divice
Posted on Nov 21, 2013
4 Suggested Answers
  • 51 Answers
SOURCE: backspace doesnt work
in all likelihood your shift key is stuck. try pressing and releasing both shift keys in an attempt to "free" them. Also, check to ensure that "sticky keys" is not enabled on your computer(pressing and holding the shift key for about 10 seconds should pop up a window if it is. if the window appears, just make sure that the key is not "stuck" by windows).
Solution: mechanical agitation for your shift keys to attempt to free them, and a good thorough cleaning for all of your keyboard with canned air and/or a lint free cloth damp with dilluted isoprophyl alchohol to prevent this from happening in the future with these or other keys. Alternately, replace your keyboard.
Posted on Jun 30, 2008
SOURCE: backspace key
you might have sticky keys permanetly stuck on, ive had this problem, it worked after i held down shift and press the backspace key, then it worked nomally again. hope this helps.
Posted on Jul 15, 2008
  • 165 Answers
SOURCE: my hp keyboard's backspace malfunctions.
Hi friend, in this case I would recommend you to please try and connect any external keyboard to teh system and check if you have the same issue with the external as well. So, that we can isolate the issue if it is hardware or software issue.
Posted on Dec 09, 2010
Delete character
You have this backwarrds. The backspace key (<-) deletes from right to left. Try using the the Delete key
May 11, 2013 | Apple iPad 32 GB WiFi Tablet PC
When I am trying to delete a word or backspace problems occur
I have a logitech wifi keyboard and in some instances including your problem , if I press the insert key, it behaves itself for a while
Apr 29, 2017 | Acer Aspire 5551 Notebook
Cursor problem,Automatic deleting problem
it sounds like your mouse is highlighting your text automatically. try disabling the trackpad and using a wireless mouse, if that solves your problem then you can adjust the trackpad settings to shut off automatically while you're typing.
Jun 25, 2012 | Computers & Internet
Backspace button emachines
Press the backspace key and see what it does. It will delete characters.
May 28, 2012 | eMachines Computers & Internet
What is the equivalent key on the mac for backspace
The delete button actually acts like backspace. Pressing fn + delete will delete the character ahead.
if it helps please leave a 4 thumb rating .
May 29, 2011 | Computers & Internet
I have the casiofx-115 es I would like to know how to delete an input without starting the whole equation over
Use the Replay buttons. If necessary, use UpArrow to bring the cursor on the command line, then use the left arrow to backspace. Press DEL button to delete the character following the cursor.
Apr 12, 2010 | Casio Office Equipment & Supplies
Hi text gets deleted as I type in my toshiba satellite pro A120
u r keypad is likely to b defective or ur ram..
lightly strike the keypad using ur hand..
but itz better to seek professional supervision esp of ur system admin/vendor....
Oct 31, 2009 | Computers & Internet
Changing the Cursor Appearance
I had this same problem on my TI 89... You must have accidentally set your calculator to insert mode. To switch it back to the thin cursor, input the following keystrokes... Go to the "2nd" key to enter second function mode. Then press the button with an arrow on it pointing to the left(The key that you use to backspace). Do you see the "INS" lettering above the backspace key? There's your solution :-)
Apr 07, 2009 | Texas Instruments TI-89 Calculator
Emachines Keyboard Model No. KB0511
Here you go:
Enter
The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock
Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
Moves the cursor to the left one space each time it is pushed; does not delete the
character.
Moves the cursor up one line each time it is pushed; does not delete the character.
Moves the cursor to the right one space each time it is pushed; does not delete the
character.
Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
Jan 02, 2009 | E-Machines eMachines Desktop PC
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
