Question about DHD NTX-2118 Car Audio Amplifier
High Input Pin in?
I don't have the connector for the amp's high level input. Is there a way to tell what pin is what? Or is there a way to get this cable?
    Problem Solver:
  • 5 Answers
If you're just using the amp for subs just use the low level RCA outputs and cables from the deck to the amp. If your deck doesn't have the outputs, then you'll need to buy a high level cable. Check the website of the amp manufacturer and the deck manufacturer and find a cable that works with both. If they don't sell it direct, then get the product # for it and search around online audio suppliers for it, or bring the deck and amp to your local audio store and they should be able to get you a cable that works.
Posted on Oct 08, 2007
Jet sound equalizer js 214 wire color code
Black wire is ground, Red with 5a fuse is hot. Green/black is L Ground BTL, Grey /black is right ground BTL, the RCAs are left and right low level inputs. Then there is the 5 pin connector. It has a red wire for +12v, two black wires for input grounds, a green wire for left Hi input and a gray wire for right high input. If you install using traditional common ground high level, then you don't used the two BTL wires. Just connect the wires from your 5 pin connctor. If you use the low level RCAs for inputs, then you only need to connect the red and black from your 5 pin connector.(Plus the main red and black) Make sure the switched on the bottom of your EQ are set correctly. COM for common ground and LOW for RCA input or High for Green/Gray wire input. If you are using a floating ground the select BTL and connect the two BTL wires to the floating grounds of your stereo. There is also a line input adjuster so you can adjust your input sensitivity to match your reciever. I have the owners manual if you have any other questions.
Feb 01, 2012 | Car Audio & Video
Can you give me technical specs for LCD TV TH-L32E3A. Thanks
The proof copy of the Owner's manual includes the specs for the TH-L32EA and is available from: http://www.panasonic.com.au/Support/Customer+support/Downloads+and+documentation . Enter the model number under keywords and then click search (do not use the drop down menus).
Specifications
Power
Power rating AC 220 - 240 V, 50 / 60 Hz 0.33 A
Normal (Home) mode 42 W
Standby condition 0.2 W
Display
panel
Aspect Ratio 16:9
Visible screen size 80 cm (diagonal)
698 mm (W) × 393 mm (H)
Number of pixels 2,073,600 (1,920 (W) × 1,080 (H))
Sound
Speaker 160 mm × 42 mm × 2, 8 Ohms
Audio Output 20 W (10 W + 10 W )
Headphones M3 (3.5 mm) stereo mini Jack × 1
PC signals
VGA, SVGA, WVGA, XGA
SXGA, WXGA ······ (compressed)
Horizontal scanning frequency 31 - 69 kHz
Vertical scanning frequency 59 - 86 Hz
Receiving Systems /
Band name
PAL B/G Reception of Off air broadcasts
Digital TV 7 MHz VHF / UHF (Australia) free-to-air TV broadcast reception
PAL 60 Hz
M.NTSC
NTSC
Playback of NTSC tape from some PAL Video recorders (VCR)
Playback from M. NTSC Video recorders (VCR)
Playback from NTSC Video recorders (VCR)
Aerial - Rear Standard Belling & Lee connector
Operating Conditions Temperature : 0 °C - 35 °C
Humidity : 20 % - 80 % RH (non-condensing)
Connection Terminals
AV1
Input
AUDIO L - R RCA PIN Type × 2 0.5 V[rms]
VIDEO RCA PIN Type × 1 1.0 V[p-p] (75 Ohms)
COMPONENT Y 1.0 V[p-p] (including synchronisation)
PB/CB, PR/CR ±0.35 V[p-p]
AV2
Input
AV3
Input
Audio
Output AUDIO L - R RCA PIN Type × 2 0.5 V[rms] (high impedance)
Others
HDMI1 - 3
Input TYPE A Connectors • This TV supports "HDAVI control 5" function.
PC Input HIGH-DENSITY D-SUB 15PIN R / G / B: 0.7 V[p-p] (75 Ohms)
HD / VD: TTL Level 2.0 - 5.0 V[p-p] (high impedance)
DIGITAL
AUDIO OUT PCM / Dolby Digital, Fiber optic
Card slot SD Card slot × 1
USB 1/2 USB 2.0 TYPE A Connectors DC 5 V, Max. 500 mA
ETHERNET 10BASE-T / 100BASE-TX
Dimensions (W × H × D) 769 mm × 514 mm × 207 mm (With Pedestal)
769 mm × 480 mm × 75 mm (TV only)
Mass 11.0 k Net (With Pedestal)
9.5 k Net (TV only)
(See page 73 of the manual for the specs as a table - I used Proof 2)
I hope this helps.
Apr 20, 2011 | Panasonic Kitchen Appliances - Others
How do I attach power amp to 1832 mixer
There are a number of configurations for a mixer like the 1832, the most common are PA system and Recording system. There are Main output jacks which carry the mix as summed in the main faders. These in a PA system would feed the pa amplifiers which drive the house speaker system for the audience. These connectors are XLR 3 pin type on the rear, intended for professional pa amplifiers which use balanced +4dbv line input level. Amplifier which have 3 pin XLR connectors for input signals can accept that high level signal. For home style HiFi amplifiers, the signal level is nominally -10DBv and balanced or unbalanced signal lines with 1/4in diameter phone plugs which are connected to the mixer by way of a second set of Main output connectors which are 1/4in phone jacks. Use whichever amplifier input level your amp has.
If you are not using it as a main PA house mixer, but using it for recording, the main output connectors go to a 2 channel recorder or computer sound card recorder. The power amp and your monitor speakers are connected to the connectors labeled "Control Room" (CTRL Rm). These output are useful for recording because the signal through the mixer can be monitored from several buses, Solo, main mix, selected by buttons provided. The buttons only affect the signal heard through the control room monitors, and not the main output which only sees the main mix so selecting "solo" does not interrupt the signal going to the recorder while the engineer in the control can be checking other signal paths through the board.
Jan 21, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
Harness available for hooking up blaupunkt bahamas to amp, the connector is a 20 pin and i cant seem to locate this part or is high level output sufficient?
Hi, look for any RCA connectors on the wiring harness or rear of radio - these are the line output connectors - If there are no such connectors then your radio has no support.
Most amps will support hi level input but your sound quality may suffer a little bit because of the extra noise introduced by the stereo amp.
May 05, 2010 | Blaupunkt Bahamas MP46 CD Player
PINs for high level input
Hello gmb_66,
You did not specify exactly which Jensen amp you have. None of the Jensen PowerPlus series I found had high-level inputs. You can go here and select your amp to download the manual. They should also have the connector for speaker inputs.
Most amps that have both high-level and RCA inputs allow you to use one or the other, but not both at the same time. If your head unit has RCA ourputs, those would be the ones to use, because they generally provide a cleaner signal to the amp with less noise.
Hope this helps.
May 24, 2009 | Jensen Car Audio & Video
Sony amp model 1652z
1000W max power
<b>
165W x 2, 20Hz - 20kHz, @ 0.04% THD + N, at 4 Ohms
200W x 2, 20 - 20kHz, @ 0.15% THD + N, at 2 Ohms
400W x 1, 20Hz - 20kHz, @ 0.1% THD + N, at 4 Ohms
</b>
OTL (Output Transformerless) circuit
Pulse power supply
Line & High Level Inputs
.3-6V Level Adjustment Control (RCA Pin Jacks) 1.2-12V (High Level Input)
80 Hz, -18dB/octave Low Pass Filter Switch
Jan 15, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony xplod amp xm-1652z high level input connection
First off, if you're using RCA preamp connections from the head unit to the amp, you don't need to put anything into the high level input connector. But if your head unit doesn't have RCA preamp outputs, then connect the front left to the white (+) and white/black stripped (-) wires and the front right to the grey (+) and grey/black stripped (-) wires. There is no need to connect the rear speaker outputs of the head unit to the high level input of the amp.
Apr 17, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
15 pin RGB Input
You are wasting your time if the component you're hooking it up to is not High Definition... Tv can't produce any better quality from connector to connector you have to up the type of signal being input.
Bill
Mar 09, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Car amp high input pinout
With a 4-pin connector - from left, facing the side of amp with RCAs and high level input:
Left speaker + input, Left speaker - input, right speaker - input, right speaker + input
With 5-pin connector - same as above, except center pin goes to ground and 2 right side pins are for right speaker.
Feb 15, 2008 | Audiovox AMP522A Car Audio Amplifier
JENSEN XA 184 AMPLIFIER
Hi, Jensen is under different ownership from when your amp was made, so it's unlikely that you'll find a replacement plug for the high-level input. A high-low converter is also called a line-out converter. It's a device that connects to the speaker wires and changes the signal to a low-level RCA connection. This allows you to use the amp's RCA plugs with your speaker wiring (through RCA signal cables). A line-out converter should be available any place that sells car audio accessories.
Aug 11, 2007 | Jensen XA92 Car Audio Amplifier
DHD NTX-2118 Car Audio Amplifier Logo
160 people viewed this question
Top DHD Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
ray gallant
Are you a DHD Car Audio and Video Expert? Answer questions, earn points and help others
