Question about Ovens
My Gaggenau steam oven gets way too hot. Yesterday my baking disch made out of glass broke into pieces when i took i out. You can't put your hand on the door, because it's too hot. What could be causing this problem?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
The thermostat needs to be checked because it is not regulating the temp by the sound of that
Posted on Nov 22, 2013
SOURCE: top oven front glass broken want replacement
WHERE CAN WE BUY REPLACEMENT GLASS FOR AN OVEN
Posted on Oct 08, 2008
ginko
  • 19396 Answers
SOURCE: how do i replace the inner glass on the oven door?
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
Part here: _.gif PS2087058
Posted on Apr 08, 2009
  • 327 Answers
SOURCE: Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
Posted on Jun 02, 2010
SOURCE: Condensation in oven door glass after steam clean
No solution--but I have the EXACT same problem--brand new oven and first time steam cleaned used. Wondering if you got any resolution with this...
Posted on Dec 12, 2010
SOURCE: How to get the glass front back on oven door of Whirlpool range
Ok. Heres what I was dealing with....Dissasembled. NOW (after you scrubbed everything to your liking try this.
1: With the door laying "oven" surface down on a flat surface. Gently place glass sheet/pane down squaring it up evenly as you can.
2: (Might sound strange) Grab the door handle and reposition it where it needs to go and slide the glass in the "ledges". Even everything up square as possible. Insert screws(2), but do NOT tighten all the way.
3: Now you have 2 (L & R) uprights. Insert "handle" end of uprights first, then align carefully the "tips" into the holes, and then snug the oven handle screws.
4: Carefully align the metal "base" channel/seat with the glass so the window/glass seats on the bases slots/shelves. Align all holes and insert screws (4 - 2 screws on both sides of base), finally align the center screw and tighten snug.
5: Replace door on Range Unit ande get cookin again!!
Hope this helps. I think its a poor design to let anything inside the door. Nice Range/Oven unit. Just a bad door design in my opinion.
Oh Yeah. The door hinges only took me 4 months to figure it has built in hinge locks. THEY are VERY convenient and once you know how they work. They are an AWSSOME invention for what they do!!
Posted on Jan 19, 2013
My built-in Amana Oven which is electric is overheating. would that be a thermostat problem?
It could be a thermostat problem. If you have a standard dial type thermostat then this is more than likely the problem. if you have an electronic control then it could be a welded relay on the control board or bad oven sensor.
Sep 25, 2014 | Ovens
My oven door glass was dirty, from the vents in the oven door..so we took off the oven door, took apart all the screws and cleaned the glass. First of all, don't know if we got the glass pieces in the...
the glass pieces should only fit back in one way, holes will only go one way , as far as the hinges, the need to be locked open in order to replace back into the unit, there is either a small hole in corner of hing that when pushed wll align with another hole in hing allowin for a thin blade screwdriver to be inserted adn hold in hte locked position,... the other way is a small locking mechanism is loacated on the top of hinge that when fully extended will lock hinge open for reattachment... you would need to REALLY PRESS that hinge to lock in place..
Oct 09, 2010 | KitchenAid 30 in. Architect II Series 4.3...
How do you clean the inside glass on the oven door
You need to take the door off and apart. Glass is very hard to clean as the dirt bakes on it, so if you want it to look like new then just buy a new piece of glass.
Jun 05, 2010 | KitchenAid KEMC308 Electric Double Oven
Broke the glass front to my Dacor CPO230B wall oven. the manufacturer no longer makes the part. What would the solution be to this problem.
If you dig deep enough on Google, you'll find someone who has the part. As with all manufacturers, none of them make the entire product. Bic makes pens for "off brands", Staples products come from a myriad of manufacturers, Kirkland, the house brand for Costco, all come from various sources. Hopefully, the part that's ordered will fit. We've also located the entire door. So just in case the front glass is not available, the door is, and that's an expensive alternative. I've also considered going to a glass company to have a piece of tempered black glass cut to size. My entire dilemma stemmed from changing the interior bulb in the bottom oven, when putting the door back on, it slipped in my hands and the rest is now history.
Dec 01, 2009 | Ovens
Large oven doesn't heat up. Heating element gone??
Hi, In a word yes. As for who you can contact, I'd suggest only an authorized b/s/h (bosch/thermador/gaggenau) service provider. I used to be one for over 10yrs. but now work exclusively for sears...I'm not sure if I made a good choice or not yet, lol ! I digress. It is quite possibly not even the element as the gaggenau have cut-outs (they are actual thermal fuses that cannot be reset, they must be replaced) built into the bake circuit that can open often times. This of course unless you're certain the bake element is defective. Check your local directory under appliance service or a vendor who sells that line may be well equiped to direct you for quality service in someone they trust and are proficient. Hope that helps, good luck. macmarkus :)
Nov 10, 2009 | Gaggenau EB294/295 Electric Double Oven
Oven not working
hey, turn the oven on and see if you see an orange glow at the bottom. this would be your glow coil. exactly like the broil. if you do, take an amp probe and check the amp draw to it. it should be over 2.9 amps. if no glow or low amps replace and start baking. enjoy
May 17, 2009 | GE JGRP17 Gas Single Oven
Gaggenau Ed 220/221 Error Code F 70
I had the same fault F70. Poured several liters boiling water no result. I decided to take the oven out the kitchen and put on the table. Be carefull, its edges are sharp. You need to disconnect water supply, first close the tap, then remove the water pipe from the oven by hand. Remove also the drain pipe from the sewage connection. You cannot detach it from the oven. Unplug power supply. Then start unscrewing the top panel. Once removed you can unscrew also the side panel left side (by looking at the oven from the front door side) and finally remove the back panel. You will need a special screw driver as the screws are star type.
I found out that there was some little water on the bottom panel of the oven. There is a safety sensor which is in contact with the bottom panel on the left side of the oven near the electronic board.
If this get wet, the faul code F70 appears.
Also some water was in the hole of the level sensor in the pump chamber next to the other sensor (white plastic box)
So dry all the water with the help of kitchen paper and finally with hair dryer.
Put back all teh parts and voila', it works again.
Feb 20, 2008 | Gaggenau ED 220/221 Electric Single Oven
Ovens Logo
46 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
