Question about Sony DVP-NS300 DVD Player
Laser diode - Sony DVP-NS300 DVD Player
  • 3 Answers
Ini judi penipu ,masa lagi maen tiba2 inccoret username/pasword minta bantuan admin nya gak ada respon apalagi mau bantu login jauh dari harapan .. id : titows email : destaricamalentine@yahoo.co.id
Posted on Nov 21, 2013
Weak beam .can barely see espically when sun is shining.
How old are the batteries? The company appears to be proprietary and does not release much information.
Sep 02, 2013 | Topcon tpl4b pipe laser w/remote,red
Sc 990
SC990 [Cause]
Dirty contacts on Upper Right Cover Safety Switches. Toner gets inside the Upper Right Cover Safety Switches, which can lead to lower DC voltage being applied to the Laser Diode. Which leads to:
SC 990 eng_procon.c (when a normal Grayscale pattern was not detected 15 times consecutively during ID Sensor Grayscale pattern check) check with SP 7403 Service Code History look for Detail in history of SC 990.
LD Power not being strong enough to be read by Laser Synchronizing Detector causing a SC 322 or 326 depending upon timing.
5vdc not being fully applied to connector 403 pin 3 on the Laser Diode PCB causing an Open Cover Indication, or 24vdc not being applied fully to connector 107 pin 2 on the PSU PCB causing an Open Cover Indication.
Circuit Explanation: 5vdc (VCCD)is output from connector 403 pin1 of the Laser Diode PCB where it travels through 2 of the Upper Right Cover switches than through 2 of the Front Cover Safety switches before being applied to connector 403 pin 3 of the Laser Diode PCB where it is now used to power the Laser Diode. Lower voltage on pin 3 leads to lower laser diode output which causes the machine to raise LD Power (SP 2-103) when maximum values are reached, laser diode output can not be increased further which can lead to SC 322, SC 326 and/ or SC 990 eng_procon .c. If the voltage drops too low an open door indication is sent to the BICU PCB but a signal is not sent to the IOB PCB which tells the machine which door is open.
Note: An older Drum more than 150,000 copies can also lead to SC 990 by causing incorrect ID Sensor readings
[Resolution]
1. Clean the internal contacts or replace Right Door Safety Switches (2 of Part Number 1204 2521 and 1 of Part Number 1204 2529)
Clean and vacuum the PCU.
Clean the Toner Shield Glass, Charge Roller and ID Sensor.
Check Service history for Drum Life, if over 150,000 replace Drum (Part Number A230 9510)
Reset SP 2103 -1 thru 4 to defaults.(LD Power Adjustments)
Reset SP 2001-1 to its default. (Charge Roller Bias Adjustment)
Execute SP 3001- 2 (ID Sensor Initial Setting)
Sep 08, 2011 | Ricoh Aficio 450 Copier
I can no longer play dvd movies or play dvd games on my xbox. but it will play music cd,s.
This is probably due to the DVD laser diode being faulty. The CD laser diode is a separate diode (within the same unit). If this is the case then you need a replacement laser unit.
Mar 03, 2011 | Microsoft Xbox 360 Console
I have an rdv 1060 which will not play dvd's cd's are finecan u assist
Unfortunately, the DVD laser diode is probably faulty. a separate laser diode is used for reading CDs so these still work. The laser unit will require replacing.
Feb 15, 2011 | Rotel RDV-985 DVD Player
What is the problem if the the code 326 appeared?how to solve it?
ERROR TYPE C:
The main machine can be used
normally except for group
affected by the malfunction.
ERROR:
Error 326 C in the 2nd laser synchronization
The synchronization signal of the 2nd laser
is detected by the card detection
synchronization of the main scanning
even if the laser diodes are activated.
Possible Cause:
Faulty connection between the card
Laser detection and synchronization
the diode laser group.
Survey form synchronization
Laser out of position
Defective Laser
Group defective laser diode...
Jul 26, 2010 | Ricoh Aficio 1035 Copier
Part Number of laser diode (Mitsubishi), Sharp Copier AR-M160.
L6 code means the motor is not working. You need to replace that, which means replacing the entire laser module. They can be gotten cheaper used from your local sharp dealer. I know this because I work on these things every day, being a certified sharp tech. L6 code means motor lock or motor sense dead, not necessarily laser dead.
May 25, 2010 | Sharp (SHRAM900) All-In-One Laser Printer
I burn the dvd and then my computer says that the disc is empty, but I can burn cd's just fine?
Sometimes the laser diode for burning the cd and the dvd are seperate, and the one that burns the dvd is no good. It takes more lasing power to burn dvds than cds, and if it is a single diode, then maybe it has weakend, and can omly burn cds. Either way it is a bad diode, The whole laser assemble needs to be replace because it is hard to buy just the laser diode, and even if you buy one, you would not be able to align them properly, and they are very difficult to replace individually, I tried that once by taking a diode from another dvd burner, it did not work.
Aug 12, 2009 | HP Computers & Internet
Ps3
That would be the BluRay diode in the laser assembly. There are 2 diodes that emit the light for the laser. One is red which reads everything but BluRay and PS3 games. The purple laser diode reads the BluRay and PS3 discs. You will need to have the laser replaced or call Sony to get a box to send it in for repair or replacement. Thanks!!
Nov 09, 2008 | Sony Playstation 3 (PS3) Console
My machine will not read previous dvd's recorded on it
Hello john750,
You can try a cleaning disk, however it has been my experience that the cleaning disk will not help, but it is a good place to start from. More then likely it is a problem with the laser pickup photo-transistor, these often malfunction causing this problem. I would suggest if you are going to try to repair this yourself, you will need a multimeter, a laser meter, and a schematic. The first step is to measure the laser energy leaving the laser diode and see if it matches the specifications in the schematic, if it does not, check the bias voltage with the multimeter, this is to determine if the problem is the bias voltage or the diode itself. If the diode is bad replace it. if the diode is good then the pickup becomes suspect. Using the multimeter measure the bias voltage on the photo-transistor with and without the presence of the laser light from the diode. This will tell you if the photo-transistor is good or bad, if the transistor is bad replace it , if it is good check the components that make up the biasing circuitry.
Now This test will produce a test of go or no-go on the laser diode and the photo-transistor. One of these components or their related biasing circuitry is either bad or about to go bad, by testing the voltages and laser light levels you should be able to determine which one or if both have a problem.
I hope this helps,
Thank you,
Shuttle83
Oct 08, 2008 | Televison & Video
I have a etec dvd player what freezes when it playes
Hello tasman_s
I posted this awhile ago, but I think it may help you:
Remember, at least try the cleaning disk first.
I hope this helps,
Thank you,
Shuttle83
Sony DVP-NS300 DVD Player Logo
48 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
