Question about Refrigerators
I need to wire up a new thermostat in a kelvinator fridge model no c350c-r3
4 Suggested Answers
lojacksdad
  • 121 Answers
SOURCE: finding thermostat for Kelvinator model c-7-r
you can go to the parts store and get a universal thermostat very easy to install
Posted on Apr 23, 2009
  • 37 Answers
SOURCE: Need to find a termostat for Kelvinator Model #KNT14JSWO
go to sears.com
Posted on Apr 25, 2009
SOURCE: where abouts is the thermostat inside the fridge
It sounds like you have a cyclic defrost fridge,Kelvinators were originally fitted with heat assist thermostats,so in order for the fridge to come back on a yellow wire heater was run around the cooling evaporator in the fridge compartment start running again at approx +4C so when the element fused the fridge did not start again until approx +12C.So instead of replacing heater a different thermo was used that came back on at +4c deg regardless.Kind Regards.
Posted on Jul 09, 2009
My Kelvinator Opal Freezer is not getting cold, I think the compressor is not kicking in ?.
Probably the thermostat. You will need a multimeter to see if there is a circuit across the thermostat. There should be 2 wires and an earth to the thermostat. if you bridge the 2 wires together. (NOT the Earth or green wire) the thermostat will be bypassed. If the thermostat is faulty, the fridge will start but will not turn off when it reaches temperature. You will then need a new thermostat. Make sure its unplugged before you play around with it.
Nov 20, 2016 | Kelvinator Refrigerators
Without Replacing the complete freezer can you replace the thermostat on a kelvinator N501C-R3 refrigerator
you can change the thermostat with out replacing the freezer and where did you get this model number look up correct number and the following link can asist with part replacement
Unable to locate part or model N501C
Aug 29, 2016 | Kelvinator Refrigerators
Freezer serial # 845440256 age?
Replacement thermostats depends on whether the fridge is a double door or single door model. You can buy this part from your appliance parts store/supplier.
Feb 20, 2014 | Kelvinator Freezers
Wiring diagram for a Kelvinator 330
There's only 2wires and it shouldn't matter which terminal on the cold control u connect it to. If there's 3wires one should b green and it's a ground wire
Nov 30, 2013 | Electrolux Kelvinator Cyclic Defrost...
Kelvinator c302f-r fridge is freezing everthing
sounds like thermostat if its non frost free model,otherwise it is temp sensor.need model number to clarify.
Apr 25, 2012 | Kelvinator Refrigerators
I have a two door kelvinator it freezes the food aside
Ok, your thermostat is buggered, the fridge wont turn off becaust it hasnt been told from the thermostat, easy DIY but be aware DISCONNECT the power first and unplug from the wall and do not kink the thermo tube when replacing. Buy the same thermostat and take a pic of where the wires go before removing the old one. Hope that helps, if you need help, call me on 08 9523 0552 Russ and I can help further.
DONT FORGET TO VOTE, I JUST HELPED YOU FOR FREE
Mar 02, 2011 | Kelvinator Freezers
Looking for kelvinator n500t wiring diagram
My Kelviator fridge was freezing things solid, I was told that the thermostat needed replacement as we have no electrician availiable, I bought a new thermostat. I removed the two screw holding the thermostst/light control, took off the cover then made a diagram of the thermostat wiring. After I removed the old thermostat the light control sprung out of its position and I can't see where it should go. Can I obtain a picture of this.
richard.fuller@clear.net.nz
Oct 11, 2009 | Refrigerators
Where abouts is the thermostat inside the fridge there are white and yellow wires that go to either side of the fridge and the yeallow ones are broken what are these wires for it is a kelvinator C375vm
Jul 09, 2009 | Refrigerators
Finding thermostat for Kelvinator model c-7-r
Apr 23, 2009 | Refrigerators
Refrigerators Logo
15 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
