Question about Dishwashers
How to remove the drain pump in a Bosch SMS50E12AU dishwasher
  • 833 Answers
SOURCE: Dishwasher draining - Bosch SGV4313GB/17
This is generally because of a stuck diverter solenoid. The water goes to the pump and then is either sent to the wash arms or the drain. Also, check the drain.
Posted on Feb 11, 2008
  • 105 Answers
SOURCE: bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Posted on Feb 24, 2008
SOURCE: Bosch SHY56A05UC Drain Pump Replacement
It's not easy. I just look at my sister-in-laws and I think the tub needs to come off. I plan on working on it this week.
Bruce
Posted on Feb 25, 2008
  • 98 Answers
SOURCE: How to change a drain pump in Bosch dishwasher?
Are you sure you need the pump? I have written a guide you should review before you go through the hassle of the pump. Read it thoroughly and follow the directions. If you replace the pump and it is not the problem, you'll be going through all of these steps anyway.
<a href="http://www.squidoo.com/Bosch_Dishwasher_Drainage_Problem_Fixes">It is here.</a>
Posted on Jul 23, 2009
  • 457 Answers
SOURCE: Bosch dishwasher will not drain
drAIN AND CANCEL BUTTON WILL RESET UNIT;)
Posted on Feb 25, 2010
Removal of bosch srv53c drain pump
Try viewing this video if it helps. I am assuming you have already bought the new drain pump.
Dec 18, 2012 | Bosch SRV53C03UC Built-in Dishwasher
My Bosch dishwasher is making a loud grinding noise when it drains
This video will explain what is wrong and how to repair yourself.
Bosch Repair video
Feb 16, 2011 | Bosch Dishwashers
Water still remains in the dishwasher even after cleaning up the drain?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Feb 09, 2011 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
My bosch dishwasher will not drain and makes a humming noise
Humming noise is an indication of your drain motor getting power but not spinning. Either your drain pump is defective and needs to be replaced, or something is stuck in the pump preventing it from draining out the water. Either way you will have to take the dishwasher out and get at the pump from the bottom of the machine.
Jan 31, 2011 | Bosch SHX4AP05UC Dishwasher
Water in bottom of bosch dishwasher will not drain. How do I get this water to drain
Hi
Dishwasher not draining issue occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. To access the drain pump, please follow the procedure---
1. Drain pumps are mounted to sumps in the front of dishwashers --they're easily accessible from the front of dishwashers by removing toe kicks.
2. Tools needed: small flat blade screwdriver (for unlocking terminals).
3. Remove toe kick/base cover, pull up terminal cover and disconnect wires (using screwdriver to unlock locking terminals).
4. To remove pump, pull latch (on circular collar) & rotate pump clockwise (cw).
5. To install new pump, insert @ 2:00 position & rotate counterclockwise (ccw).
6. Clean water & debris from base, then check float operation.
7. Connect wires, then install base cover & toe kick.
Daniel
Jan 26, 2011 | Bosch SHU9915UC Dishwasher
Bosch dishwasher not draining
Hi
"Dishwasher not draining" issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please note that dishwashers don’t drain out the complete water such that heating element doesn’t overheat.
Daniel
Jul 22, 2010 | Bosch Dishwashers
I have a bosch shu33a dishwasher and its not draining at all. it washes the dishes but the water wont drain out
Remove the lower front panel and you will see the drain hose leaving a tiny pump and heading out of the dishwasher space into the sink space where the drain line is attached to your drain line.
Remove the clamp on the drain line closest to the little pump and then unscrew the pump. you are looking for an obstrution in the form of a piece of broken glass, a bone, or something else which is preventing the pump from pumping the water into the sink drain.
please rate my answer as a fixya!
Feb 25, 2009 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch Dishwasher pump keeps emptying
Disconnect the power to the unit. Remove the lower access panels and check the tray under the dishwasher. You will probably find it is full of water. Use a towel or a sponge to remove the water. There is a float that will stop the operation of the unit and run the pump if water is in this tray. Test the unit. If there are no leaks, check the drain hose under the sink. THE DRAIN HOSE MUST RUN UP TO ABOVE THE TOP OF THE MACHINE THEN TO THE DRAIN. If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overflow into the tray under it.
If there is no water in the pan under the dishwasher there may be a problem with the pressure switch at the side of the pump housing but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
Go here for Bosch Dishwasher Parts: http://www.repairclinic.com/Bosch-Dishwasher-Parts
www.RepairClinic.com
Feb 11, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
I have a Bosch free standing dishwasher (can't find the model #) that doesn't drain the used water when finished. Are there any diagrams that I can access to check how to remove and check the drain?
just remove the screen from inside you will see a torx screw to the left side of the sump remove it. pull the protective cover of the drain pump impeller. once removed you can see if anything is in the drain. if the impeller seems fine you eithe have a bad drain pump or something is in your drain between the dishwasher and the sink clogged.
Dec 19, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher
1. Check for a clog in the air gap:
That's the silver dome on the back of the sink. Not all homes have an air gap for the dishwasher. (Though it is highly recommended!) Lift off the silver cover. Unscrew or unclip the plastic cap on the top. Look inside. Toothpicks are often found there.
2. Check for debris in the sump by:
Remove the lower rack, the lower spray arm, and screens. Use a #15 Torx bit to remove the cover over the drain pump suction. The hole leading to the drain pump is on the left at the bottom. Remove any debris you find.
3. If you find no debris, you almost certainly need a drain pump. After clearing any clogs, if you hear the drain pump humming, but it doesn't turn, replace the pump.
Comment back if you directions for this.
Mar 12, 2008 | Bosch 24 in. SGS43C12 Classixx...
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
