Question about Samsung Dryers
Samsung DV209AGW/XAA panel lights on no error code but will not start
Panel lights on and no error code but when i press start a click is heard but will not run
SOURCE: Our dryer (Samsung Model DV218AGW/XAA)
I had the same issue with a Samsung DV209AEW/XAA.
What I found was the belt had come off and the spring on the drum belt pully had come off.
After I disassembled the whole top and front to figure out I could not access what I needed from there I discovered I needed to enter in from the vent is.
Anyway here is some info:
Rear Access:
1) On the back where the Vent comes out you have 4 total screws. 3 of them are on the outside edge and the fourth is more of a middle mount that holds the tube to this bracket. Remove all four screws now you can lift and lean this plate to remove it.
2) This will also free up the vent tube and it can be pulled and cleaned also if you desire.
3) With these items out of the way you can now access the pulley for the belt and other items.
Posted on Nov 23, 2010
rickead1
  • 1998 Answers
SOURCE: samsung dryer dv317aeg/xaa has code on display
http://www.washingmachinereviews.org.uk/fault-codes/errors-and-solutions/ use this site try this solution is what the company suggests simply folo down the list till u see your error code with there solution if this does not work u willhave t call a tech to do test on your heater as well as the wiring going to the heater
Posted on Jul 26, 2010
SOURCE: My Samsung Dryer (DV218AEB/XAA) Error code HE
invalid heating temp when running. call for service.
Posted on Sep 18, 2010
  • 291 Answers
SOURCE: have a samsung dryer model DV209AEW/XAA. I "hand
Check to make sure your child lock is off first. Hold the time and signal buttons simultaneously for three seconds. Unlikely, but do check. Some of these dryers have a safety switch that the idler pulley has to engage to allow the dryer to run. I tried to find a schematic for this model but could not get one to tell if you do have a safety switch. Look at the arm of the idler pulley and see if it is contacting the switch actuator correctly. When a belt breaks or pops off, sometimes the arm of the pulley will move to the other side of the switch actuator and will not allow the dryer to run once a belt is reistalled. I would also look to see if a wire was knocked off of the motor switch when your belt came off. Good Luck, Appliance Specialists
Posted on Dec 03, 2010
  • 352 Answers
SOURCE: We bought the model DV209AGW/XAA
This could be cause by a blocked lint/dust filter. The instruction manual should tell you how to clean it and this should be done after every cycle. this filter also allows the hot, moist air out and if it can not ecsape, the clothes wont dry!!!
Posted on Apr 04, 2011
I am receiving an error message of L5 for my Samsung Dryer DV328AEW/XAA
I have uploaded the manual for this dryer to Fixya.com and the link to same is below. The following error information is on page 26 of the manual. Good luck to you:
INFORMATION CODES
Information codes may be displayed to help you better understand what is occurring with your Dryer.
CODE SYMBOL ( L5 )
MEANING
- Heater temperature control problem.
SOLUTION
- Call for service. See below. (see contact info in manual.)
Please let us know if helpful by clicking the button below, thanks!
http://www.samsung.com/us/support/owners/product/DV328AEW/XAA
7 3 cu ft Large Capacity Stainless Drum Dryer Neat White Samsung DV328AEW...
Jul 29, 2016 | Samsung DV328AEW Front Load Electric Dryer
Over-level water error samsung dishwashere
Over-level water error Samsung DW80F600UTS - ApplianceJunk.com
appliancejunk.com > ... > Forum Index > Dishwasher Repair
Dec 14, 2014 - 10 posts - ‎4 authors
Over-level water error Samsung DW80F600UTS. ... "heavy" lights flashing which my owners manual tells me is a "over-level" water error. .... Samsung DishwasherDW80F600UTS - High Temp Error (smart auto + normal lights). Samsung DW80F600UTS, drain code on
Jan 27, 2015
Samsung DMT300RFS/XAA OE Error
Apr 29, 2014
Samsung DMT400 over level water error
Oct 29, 2013
Samsung Low Level Water Code
May 14, 2013
More results from appliancejunk.com
Over-level water error - Fixya
Jan 11, 2016 | Samsung DMT400RHS Builtin Dishwasher
How do I access the diagnostic menu on my Samsung fridge?
On the RF4289HARS, press the upper left (A) and upper right (B) corners alternately about 3 times (sequence A-B-A-B-A-B). You should then see "Engineering Mode Enabled." From there, just use the menu and press the "Self Diagnostics" button. Then, it'll show you the errors on the left side of the panel.
Good luck
Nov 14, 2014 | Samsung RF4289HARS
Error codes for DV209AGW/XAA
either a bad door switch a bad thermal shut off fuse or a bad push start switch check all with a multi meter
Aug 27, 2014 | Samsung Dryers
Model code HLR4667WX/XAA won't turn on just clicks
Sounds like you have defective capacitors in the power supply board, cheap and easy fix for those with electronics repair skills
Jul 23, 2012 | Samsung LN-S4041D 40 in. LCD HDTV
We bought the model DV209AGW/XAA as it was "energy efficient", but what is "efficient" if you have to dry the same normal load 2 or 3 cycles?
Apr 04, 2011 | Samsung Dryers
I have a Samsung Refrigerator Model# RF4287HABP/XAA. Had a Power outage and now have an error Code Reading 13-e. Was unable to find what the code meaning was? any suggestions?
On a Samsung Refrigerator model #RF260BEAEBC French Door, press and hold both "Power Freeze" and "Power Cool" buttons simultaneously until chimes sound. This will reset the flashing 13 E code.
Dec 18, 2010 | Samsung Refrigerators
Jun 07, 2010 | Samsung DV218AEW Electric Dryer
Samsung dryer dv317aeg/xaa has code on display
Jun 24, 2009 | Samsung DV317AEG Electric Dryer
Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
had the same problem, same tv... bad connection on a transistor....
Jan 07, 2009 | Samsung HP-R4262 42 in. Plasma Television
Dryers Logo
70 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
