Question about Tritton X360 Warhead 7.1 Headset
Headset won't stay powered on - Tritton X360 Warhead 7.1 Headset
My PS3 headset won't charge it stays lit for 3
If there was no change using a new charger, I would suspect the battery is shot
Apr 23, 2013 | Radio Communications
Why won't my motorola finiti connect to my PS3?
I'm having this problem and need help please for my 12 yeatr old son
Jun 10, 2012 | Motorola Mobility FINITI Headset
My Motorola H730 won't stay charged
Jess
Are you charging with boom closed and closing boom when not in use?
Mark
Motorola Support
May 29, 2012 | Motorola Mobility H730 Bluetooth Headset
My 220 will no longer power on. It shows the red light when connected to the charger but unplugged won't come on
That Plantronics Explorer 220 headset is an older model, it may just be worn out. The Plantronics M20 would be a good replacement to look at, here is the link:
Plantronics Explorer M20 Headset
Good luck from Headsets Direct!
Oct 04, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My 220 won't turn on. Red light stays on when charging but when unplugged won't do anything
The link below on page 7 has the sequence for turning on your headset (Explorer 230 and 220 work the same). If you're still having problems, then it needs to replaced.
Plantronics Explorer 230 User's Guide
When I try to charge my headset, the indicator light flashes red instead of staying solid. Please help me, I love this headset and I'm so upset it won't work for me..
If this is not charging correctly it may be that the battery is no longer functioning properly. The batteries are non replaceable on this headset. If this is still under warranty (1year) you should be able to get a replacement
Here is a link to the User's Guide.
Aug 30, 2011 | Plantronics M100 Bluetooth Headset
Motorola H700 for Treo 700
4 zeros is the pass key. try powering off and on your phone and headset put your headset in pair mode by holding down on the power button until the blue light stays on.
Feb 04, 2008 | Motorola Mobility H700 Wireless Headset
Motorola H350 User Manual
On your bluetooth headset, hold down the power button until the light stays on steady. (it will blink when you initially power it on, but continue to hold for another few seconds for the steady light!) Your headset is now in pairing mode.
On your RAZR, press Menu > Settings and Tools > Connections > Bluetooth > Handsfree > Look for devices. Your phone will then scan for any bluetooth devices that are in pairing mode. When your headset pops up on the list, highlight it and press ok to connect.
If the device asks permission to bond with the phone, select yes. It will then prompt you for a pin code. The pin will be 0000 .
Jan 08, 2008 | Motorola Mobility Bluetooth Hands Free...
Tritton X360 Warhead 7.1 Headset Logo
Top Tritton Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Tritton Radio Communication Expert? Answer questions, earn points and help others
