Question about Little Tikes Climb and Slide Castle
HOW DO YOU GET STUBBORN PIECES APART
DO I TURN UNIT UPSIDE DOWN TO USE MALLET?
  • 4 Answers
Maybe spray a little WD-40 or silicone spray in the cracks first. Then MAYBE very gently tap with a rubber mallot or tapping a board over the stubborn piece. The board spreads the blow around-less likely to create a dent.
Posted on Nov 21, 2013
How do I remove the glass cover for the light in my Jeff oven. I have tried following the instructions in the manual but it will not unscrew.
they get jammed with carbon from cooking i work on these all the time and sometimes have to smash with a hammer to remove it itf you tap it with a piece of wood or a rubber mallet you might break the carbon enough to free it make sure you are turning it the right way as people turn it the wrong way when its upside down.
Feb 19, 2017 | Neff Ovens
Taking spindle nut off 01 escort
You mean the big axle nut? You need a stout 1/2 inch breaker bar and the proper sized deep well socket on the nut. Loosen the nut while the car is still on the ground, you may even need a cheater bar on the breaker bar-the axle nuts are torqued down mighty tight-about 200 foot pounds. Once you break it loose, then raise the car on jackstands, remove the nut and washer, and push the axle back from the spindle. If the axle shaft is stubborn and won't move yet, put a piece of wood on the end of the shaft and rap it pretty hard with a mallet or hammer.to break it free from its tight fit inside the spindle or knuckle.
Nov 09, 2012 | 2001 Ford Escort ZX2
Does anyone have a diagram for the ET200 nail gun? I took it apart and can't put it back together.
I could not find one on the net. I would go to the Arrow web site and use the "contact us" link to send them an email requesting a diagram.
http://www.arrowfastener.com/
Mar 05, 2012 | Arrow ET200 Electric Brad Nail Gun
I have two chess freezers that both worked last spring and they got empty so I unpluged them and clean them. Now nither one of them will come on and get cold. not even a little bit I turned one upside...
I don't know if this will help, I have found this to be common Problem and have checked several things on units I have encountered. First you need to know the safe way to check for power with the panel off the unit. A Voltage tick will work in a pinch, Some models have contactors or relays these can be the core problem... Next with a gentle tap with mallet on the compressor has fixed a few ( Not even going to explane why?) Last and this is not that hard to understand... Are you sure the power is on to that plug.... Fixed a few that for no reason the breaker was tripped or off... worth a check!
Aug 21, 2010 | General Electric GTR16BBSR Top Freezer...
Fellowes 3011001 shredder stopped shredding. tried to remove shredded pieces but could not.
First, try switching to reverse, alot of times, stuck paper will come back out in reverse. Then unplug the unit, turn the head upside down and with a small flathead screwdriver, knife, or tweezers, dig out pieces of paper. It takes alot of effort but by digging small pieces out, a little at a time, you can get most of the paper free.
Nov 15, 2009 | Fellowes 3011001 Shredder
My sump pump hums, but the propeller doesn't turn.
yes the pipe is the same size all the way through, if it is just humming and there is nothing blocking it, the motor could be going bad and doesn't have the power to turn the pump,, did you check to see if the shaft could be bent> like as if a rock may have gotten stuck but broke loose before you took it apart
Jul 08, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Unit only works upside down!
there is a water level next to the ocilater make sure that the canal is clean. try some water and vinegar
Apr 07, 2009 | Venta VS 100 Humidifier
Trying to take apart a crosman marksman repeater 4.5mm to clean. the bolt action will not come off. any suggestions?
Turn the gun upside down and look at the back of the bolt action. Now take a flat head screwdriver and pop out the little gold piece. walla. youre done"BEWARE" i did this and i cant find the manual for the pieces.
Apr 06, 2009 | Sport & Outdoor - Others
How to remove motor from bosch wfo 2867 washing machine@?
Remove back panrl. Remove drive belt, remove 2 10mm motor bolts. Turn machine upside down. Remove bottom cover. Disconnect power lead to motor, disconnect earth lead, gently tap motor out with mallet. Brush mountings then accessible, remove and replace brushes.
Aug 11, 2008 | Bosch Washing Machines
Won't shut off after shredding.
I FIXED MINE!!! Hey folks same problem AS1018CD would not shut off. CURE: Take apart and clean electronic eye. PROCEDURE: 1. Unplug. 2.  Remove shredder and turn upside down. 3. Remove 6 phillips head screws on back of unit ( 1 is under sticker in middle peel back sticker to access screw. 4. Carefully separate unit. 5. Pull off shredder piece. It is a snug rubber grommet fit and just lifts off( gears everything comes off as one piece. 6. Electric Eye is exposed remove screw holding in and gently slide out and wipe clean. Do both sides. While apart clear all debris and wipe entire unit as clean as you can. Put gear assembly back on grommets. Put top and bottom back together. Replace screws. Plug in. FIXED :-)
Sep 14, 2007 | Aurora Electronics AS1018CD Shredder
Little Tikes Climb and Slide Castle Logo
90 people viewed this question
Top Little Tikes Toys Experts
 Russ Hill
Russ Hill
Brett Duxbury
Brett Duxbury
Bill Boyd
Are you a Little Tikes Toy Expert? Answer questions, earn points and help others
