Question about DeLonghi EAM3500 Espresso Machine/Coffee Maker
Eam3500 steam nozzle o rings need replacing
Gidday, I need to replace the 'O' rings on the steam nozzle as they are not fixable but I have no idea where to start or exactly which model other than being an old one about 4 -5 years old.
    Champion:
    Habit-Forming:
  • 275 Answers
The nozzle should screw out anti clockwise allowing access to o rings, persevere anything can be repaired.
Posted on Nov 21, 2013
2 Suggested Answers
caroldon
  • 17129 Answers
SOURCE: My DeLonghi EAM3500 display "general alarm" and
It is best that you contact the customer care of DeLonghi and post your request. you can also register your product for support.
The power supply can be sourced after the price is confirmed as these are available only with their spares department.
click on;
http://delonghiusa.com/support/
Posted on Oct 19, 2011
My iron keeps going on to standby while using it. Any ideas as to why?
use the following ideas
As with many small appliances, regular maintenance makes a dramatic difference in how trouble free your electric iron will be. Even so, things can happen.
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
God bless you
May 22, 2013 | Irons
Ep93-11 steam cleaner replacement nozzles
please go to http://www.eureka.com/en-US/Customer-Service/Videos/
and proceed with common sense for troubleshooting and replacelmente nozzles.
God bless you
Jul 15, 2012 | Euro-Pro EP93 Steam Vacuum
When I turn on the steam valve, nor hot water nor steam comes out (not one drop), it doesn't make it to the nozzle and instead it goes directly to the drip tray. Coffees dispense works...
Hi, sounds like either you have a blocked or fauly solenoid, or micro switch or the water inlet side of the boiler is bocked. This is easy to fix. You need to be able to get to the inlet on the boiler, undo the water line and drill it out using a 3mm drill bit. Dazza
Sep 15, 2011 | Gaggia Titanium Espresso Machine
Steam nozzle not working
Check the end of the steam valve, if that is not blocked, check where the wand connects to the valve, on some models they inserted a teflon piece that was supposed to hep the machine with steaming but that gets blocked, remove and throw away.
Apr 16, 2010 | Saeco Royal Professional Espresso Machine
My Delonghi Prima Donna won't dispense milk only steam.
I've just had the same thing happen to me today. The one thing I noticed was there is a broken rubber ring which appears to have fallen from around the milk spout.
I'm off to the Service Centre tomorrow so will hopefully have some good news shortly...
Aug 23, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Machine will not **** up the milk,just steam comes out when you try to make coffee
remove and clean the O Rings.
I had the same problem, removed the o rings where the milk frother connects to, there is a green, red and black rubber O ring. Remove them and get a toothpick and clean around where they sit. You will notice a hard milk build up like when you get on your teeth. This is what is causing your problem.
........ o rings.........its as if were working on the space shuttle!!
Jul 17, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
EAM3500S will not froth milk ?
Here's what I did... with great success:
If you've cleaned all the milk deposits from around the o rings and you still have a problem then its almost certainly the milk spout (the little pipe that directs foamy milk into your cup)
Detatch the spout and get a 2.5 mm drill bit and use it to clean all the milk deposits out of the part that plugs into the lid. Rinse through with water to clean away all the bits of hard milk.
[If you put water through the spout before and after, you will notice a dramatic difference]
Doing this completely fixed the problem for me (I had about 3 years of milk build up in mine!).
Aug 16, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
Water from steam nozzle
I purchased a Talea Ring in February this year and have exactly the same problem
Jun 05, 2008 | Saeco Talea Giro Espresso Machine
DeLonghi EAM3500 Espresso Machine/Coffee Maker Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
