Question about Microsoft Windows 7 Professional 32Bit OEM FQC00730
Free donwload dlink lan driver di 39d5 - Microsoft Windows 7 Professional 32Bit OEM FQC00730
Do I need the power cord to my D-Link router to set up my computer?
From the port marked "Wan" on the back of the D-Link, install a lan cable to the cable/dsl modem.
Insert the lan cable from Dlink port labeled "1" to the PC.
The Dlink, cable/DSL modem, and PC should all be powered on.
I believe the router comes with a CD/DVD. Insert this into the PC to set up the router.
Be sure to read through your Dlink manual for additional instructions.
Dec 25, 2011 | D-Link AirPlus DI-524 Wireless Router
I have a d link d1 514 router. I'm unable to open 192.168.0.1. if i put the internet connection wire in LAN then I'm able to get internet access using cable but if i put the wire in wan, I'm not getting...
carry out the resetting of the dlink router
then use lan cable to gain access to dlink router,
set up the internet conenction (i.e. your internet provider modem plugged into the dlink router also)
if it has a built in wizard then just follow the on screen instructions
you will need to define SSID (wireless network name) and passkey (password for the wireless connection)
and the your done. disconnect the laptop from wired connection and connect via wireless
Oct 16, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Can connect to DLINK adsl2 router via wirless but
Make sure your LAN connection is not disabled,
make sure that you are getting a valid IP address form the router
If you need commands for this let me know, also which OS are you using
Jan 31, 2010 | D-Link DI 514 Wireless Router (DI-514)
Please explain how to connect LinkSys D-Link wireless broadband router Model No. DI-713P with Comcast broadband modem and Dell OptiPlex 360 Desktop? I am using Windows XP-Pro. Thanks, dana
What is Comcast Modem's Model?
if your modem is not a Modem Router:
here is the link where you can download the manual...Mid left of the web page.
http://support.dlink.com/products/view.asp?productid=DI-713P
if you have Modem Router?
Bridge your Dlink router by changing the IP Address of Dlink Router and connect it wired to the LAN port.
send me your email add so that I can send the instruction How to install.
Mar 20, 2009 | D-Link DI 713p (DI-713P) Wireless Router
Wifi problem of DIR-300 dlink
just open the dlink ip homepage and configure the wireless settings
sagar
Jan 27, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Where can I get a free d-link DI-624 installer online?
There are multiple revisions of the DI-624, each with version specific drivers, firmware, installation guides, and other resources. Please use the descriptions below to identify your revision.
The links will take you to the drivers and install guides.
Note: The revision is located on the label on the bottom of the device next to H/W
The DI-624 Rev. A has 2 antennas.
<img src=http://support.dlink.com/prod_img/revisions/DI-624v.jpg>
Driver here: http://support.dlink.com/products/view.asp?productid=DI-624
The DI-624 Rev. B has 2 antennas.
<img src=http://support.dlink.com/prod_img/revisions/DI-624_revBv.jpg>
Driver here: http://support.dlink.com/products/view.asp?productid=DI%2D624%5FrevB
The DI-624 Rev. C has only 1 antenna.
<img src=http://support.dlink.com/prod_img/revisions/DI-624_revCv.jpg>
Driver here: http://support.dlink.com/products/view.asp?productid=DI-624_revC
Dec 25, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Drivers for DI-524 Wireless Rourter D-Link
You can find donwload here:
http://support.dlink.com/products/revision.asp
follow the instruction.
me this help,
melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
May 21, 2008 | D-Link AirPlus DI-524 Wireless Router
Driver downloads
You can download it here from Dlink.
Please choose the revision of your router to continue to the download section.
Mar 06, 2008 | Computers & Internet
Microsoft Windows 7 Professional 32Bit OEM FQC00730 Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
